Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool 9500TC Front Loader Washer. Can't wash garments due SUDS Display. Can't use any washer functions due to SUDS display.
  • 552 Answers
Run a cycle with white vinegar this will clear the suds. Make sure you are using HE soap if not the unit will over suds.
Another common issue is the drain pump filter. If it gets clogged the sud error will come up as well. If you have water inside the pump may need to be cleaned. Simply remove the three screws ont he bottom of the lower access panel and then twist the handle on the filter. If water is inside the washer, it will come out when the filter is pulled out.
Good luck with your washer repair friend.
Posted on May 19, 2011
My washer is showing a f32 ,f71 codes what does that mean
Sd Error Suds Detected (Stored Error Code F71) Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle. The suds reduction routine removes extra suds and assures proper rinsing of your garments. If the code remains and the wash cycle dial is ?ashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press START. Do not add detergent.
Ld Error Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Is the pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.
Mar 02, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water will not spin out. Code says 5d
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Cabrio washer is showing a 5d error and not spinning or draining well. What is the problem?
Sep 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Suds indication
Hi!
For a top loader, a general rule of thumb is to lay clothes loosely inside the washer until they reach the top of the agitator. For a front loader, fill it until it's full, with minimal compression of the clothes.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
SD error code won't go away
Manual says -
"Sd" (Suds Detected)
directions.
Let me know if this helps, or you would like more information/help.
Feb 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Suds on display screen
run washer with no load or detergent to be sure no suds remain use HE detergent only..if you are suds is not an issue remove lower panel and clean pump ..turn white knob counter clockwise ..electronics can get confused sometimes too
Jul 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Display panel reads SUDS
The SUDS message relates to overdose of detergent detected during the Wash Cycle. This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds. If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent. Check the drain hose and make sure it is not plugged or kinked. Good luck!
Oct 28, 2006 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
73 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
