Question about Sony VAIO PCG-K35 Notebook
Sound drive - Sony VAIO PCG-K35 Notebook
Western digital humming sound
I'm 99% sure the heads are seized to the platters on this. The buzzing, or humming sound you hear is the spindle motor trying to spin up, but it can't. This is also why the drive is not rotating. Definitely do not power this drive up any more if the data is important to you. If this is one of the smaller Passport style drives, it's pretty common for them to literally rip the read/write heads off as the drive tries to spin up. Professional data recovery is the only option in these cases.
Jan 06, 2013 | Western Digital My Passport Essential...
HARD DISK NOT DETECTED, WHEN STARTED SOUND COMING FORM HARD DISC
Most likely, hard drive failure.
If a portable, re-seat the drive, then reset the bios defaults, and see if the hard drive is detected.
If a desktop/Tower, re-seat the cable connections to the drive and the motherboard, reset the bios and see if the drive is detected.
If the "Noise" from the drive is a grinding sound, a repeating Click, or a laser sound similiar to a star wars movie then almost guaranteed drive failure.
Jul 31, 2011 | Samsung (SP0822N) 80 GB Hard Drive
Seagate Barracuda ATA V 120GB. Using this as an internal storage drive (slave drive). Drive spins up but not seen in BIOS. Drive has clicking sounds every few seconds which sounds like the head searching....
It sounds like a problem with the card on the drive. You could try replace the card with one from an identical drive just to see the result you will get. I have read a lot about what they call "the click of death". So it could well be time for a new drive ckanca. The fact that the bios isnt detecting the drive points to the card. You sould also ensure there is no dirt on the cards contacts with the drive body (by removing the card and cleaning them aswell as ensuring they all make proper contact).
Dec 23, 2010 | Seagate Barracuda ATA V (ST360015A) 60 GB...
My WD800 external drive sounds like it is not "spinning up" and I hear a constant clicking sound coming from the drive. Is it "toast"?
The drive is toast, that is a common sound from a western digital drive when the heads are banging against the platters.
Nov 11, 2010 | Western Digital External USB 2.0 80 GB...
Hard drive powers up, light comes on makes a crackling sound then goes off.
Crackling sounds are usually electrical. Does the unit smell burnt?
If the sound is actually a ticking sound, then the heads inside the hard drive are banging and the drive needs to be replaced.
Data retrieval for drives making clicking sounds are very costly and require a data retrieval company.
Jan 23, 2010 | Buffalo Technology Computers & Internet
Ibm pc did not sound i need a sound drive for install i already formate the sys dont get the drive
ibm pc did not sound i need a sound drive for install i already formate the sys dont get the drive
May 18, 2009 | IBM 16 bit for ThinkPad Sound Card
Sound drive problem soun resive but not sound controle panal not sapport mute , sound pilace no acer laptop formate after no sound sound drive what is the problem
GO IN SOUND IN CONTROL PANAL SELECT SOUND
GO PROPERTIES
GO TO UPDATE DRIVE
FOLLOW INSTRUCTION IF NO LUCK
GOTO ADDRESS BAR
TYPE IN MANUFACUTES NAME
ENTER
LOOK AT ALL INTERNET OPTIONS SETTING DRIVES, FOORUMS, ETC.
CHOOSE THE BEST ONE FROM THE BEST FITS YOU.
Jan 28, 2009 | Computers & Internet
I have a Medion MD8830. Although I have good sound for music through Creative MediaSource and Soundblaster - cannot get anzy sound from the DVD player when playing DVD's. Do I need to download another...
Do you have seperate DVD and CD drives?
Can you get sound when you play a CD on the CD drive?
If you answer yes to both of these questions, this might be your answer.
This applies to IDE drives, not to the new SATA.
In order for the sound to get from the player there is a cable that connects the drive to your sound card. This cable is probably connected to the CD. Move it to the DVD drive since the DVD drive will also play CDs.
Sep 28, 2008 | Computers & Internet
Hard disk sound
HELLO SIR
 CAN U PLZ TELL WHATS IS THE SYSTEM U R USING.ANYWAYS U CAN TRY SOLVING THIS PROBLEM BY ENTERING INRO BIOS MODE AND U NEED TO TURN ON THE ACOUSTIC MODE.
U MIGHT BE HEARING SOUND  DUE TO FAST ROTATIONS INDISE THE HARD DRIVE.OTHER WISE THE SOUND IS NORMAL.IF IT IS CLICKING NOISE PLZ CONTACT UR VENDOR.MAY BE HARD DRIVE MIGHT REQUIRE REPLACEMENT.
Oct 24, 2007 | Toshiba (HDD2188) 80 GB Hard Drive
Sony VAIO PCG-K35 Notebook Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
