Question about Proform Exercise & Fitness
I have a Pro-form treadmill with model number 831.297380 and I am replacing the belt from the 800 number on the machine. My machine has a incline button connected to a hydraulic pump, the instructions does not show this pump connected to the side rail. How do I remove the cable connected to hydraulic pump and reconnected it after I replace the new belt or do I need to take off the left side rail and not the right?
SOURCE: Pro Form 745cs Treadmill does not incline
My jack screw needed to be adjusted. It is a long screw about 1" in diameter. If you take the cover off, you should clearly see the jack screw. If you adjust the incline with the cover off, you should see the jack screw rotate. One end of the jack screw may have come out allowing the screw to rotate freely and not raise the incline. If you can reengage the screw, it may work. I don't know if this will help, but I needed to do it.
Posted on Jan 11, 2009
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
SOURCE: I have a Sears Pro Form 730si. The treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
Posted on Aug 21, 2009
SOURCE: pro form service manual?
Please type in your model number on this page to get the free downloadable manual:
Hope this is helpful
Posted on Sep 12, 2009
  • 832 Answers
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
Posted on May 31, 2010
ProForm Space saver treadmill was closed while inclined, belt skips and moves to side
see the video and proceed according. God bless youlube the rack and pinion of elevation motor, and adjust the small POT attached. see the diagram attached.
Apr 05, 2013 | Exercise & Fitness
No lights on the top panel of Treadmill Pro-Form 345s
1) replace the old batteries by new ones. clean the contacts batteries very well
2) tight the ribbon cable for keypads and clean it
3) tight the upper connector vs lower connector
4) adjust the REED switch, see the diagram clean it, test for open or faulty and tight the connector.
Jan 22, 2013 | Proform Exercise & Fitness
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
Hi, our proform 790 tr treadmill is aorund six years old and the walking belt and height motor seem to be going. Is it worth replacing these and is it fairly straightforward?
Changing a walking belt takes about an hour for someone who has done it before. Check the walking deck for scratches, damage as well. Often times if the belt is worn out, the deck needs to be replaced as well. Belts vary in price depending on the make and model of treadmill. Parts can be ordered by calling the number found on the model number sticker on the treadmill. There are 10 different machines with the 790t model name. To get the correct parts find the actual model number (will start with "H"). The parts come with replacement instructions.
Belt $105 Deck $190
As for the incline motor, it is very rare to change that part. It may just require calibration. Start the machine . Press incline up and hold, remove the safety key. Now reinsert the safety key. The machine should rise to full incline then back down to minimum. Once the cycle is complete, the treadmill should work normally. If the incline sensor is defective, the motor will have to be replaced. Incline motor $150.
Feb 26, 2011 | Proform 790T Treadmill
Where cai i get an owners manual for a pro form xp 400r bike
To get an owners manual you can one of two things. First, go to in the manuals link. There you can type your model number/model name found on your machine usually on the bottom of bikes and ellipticals, and underneath the belt when the machine is in spacesaver position on treadmills. It will give you a PDF version that you can download for free. You can also call for a hardcopy but it will cost around $20 with tax and shipping. The number is 1-800-999-3756.
Aug 10, 2010 | Exercise & Fitness
Treadmill not working properly. Incline keeps slipping.
there is a plastic spacer at the rack area on the incline mtr- this white plastic spacer has broken, only recourse u have is to unplug the white wire on incline mtr, and never have a incline, or replace incline mtr when you find out how much the mtr is you might want to walk with out incline- if you was in my area, I have them cheaper
Jan 07, 2010 | Proform Quick Burn Pro Treadmill with 12...
Pro form service manual?
Sep 11, 2009 | Proform Sport 1000 Folding Treadmill...
Exercise & Fitness Logo
49 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
