Question about Delta 36-979 10" Left-Tilt Contractor's Saw
Delta 36 979 motor turns slowly and then reset button trips out.
    Sergeant:
  • 281 Answers
This is simple to fix.It sounds like you need to replace the brushes.There are two types of brushes ones that are easy to change and one that have small holes in the front part of the brush housing that require a small piece of wire that runs through the holes and keeps the brushes in place for reassembly.The wires length will depend on the vent that is used to pull the wire out when the armature is back in place and the front piece is bolted back together.While the armature is out blow everything down with compressed air and use a hacksaw blade to clean the grooves between the metal plates on the armature and add a thin coating of grease to both ends of the armature If they need it you might want to clean out the holes that the armature ends seat in.Thank you for choosing FixYa.com and Good Luck! If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Posted on May 19, 2011
Quit running when I turn the switch on nothing
1- You likely overheated the motor find the small red button on the end of the motor and push it after the motor cools down some
2- You tripped a circuit breaker in the electric panel, go to the panel and look for the breaker that does not line up with the rest of them and move it off then back on.
3- If your outlet has a GFI on it go reset the GFI reset button.
Nov 07, 2013 | Delta Saws
Delta 31-250 saander dc drive motor doesn't work
You have probably tripped the breaker for the drive motor. If you have the manual, it shows you the location of the reset button on pg. 20. The reset is a small white button above the drive switch. You can download the manual from this link: http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&ved=0CG8QFjAJ&url=http%3A%2F%2Fwww.redmond-machinery.com%2FManuals%2FDelta%2FDelta%252031-250%2520-%2520OM.pdf&ei=VfcfUba3FYeXyAHGrYFI&usg=AFQjCNGcOLvprmIo_af4ofEd10DBnJ7ocQ&bvm=bv.42553238,d.aWc
Dec 10, 2012 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
MY ROCKWELL 10 INCH TABLESAW SUDDENLY QUIT WORKING. IT TRIES TO COME ON WHEN I HIT THE START BUTTON, BUT BLADE TURNS 1/4 INCH THEN STOPS. CONTACTOR STILL HUMS THEN THE BREAKER TRIPS. PLEASE HELP!!
If the blade turns freely by hand,check the motor brushes.Most high quality power tools have easily replacable brushes,and they usually only cost a few bucks.
Sep 15, 2012 | Delta Saws
My delta table will not start. I just used it yesterday. I don't understand. The power source is good. What is it?
Hi, check the motor for any external reset. Some have this, and others have the internal overload. If the motor is cool and its been off, it must have tripped the overload. Find the reset and your back in business!! Good Luck.
Shastalaker7
Mar 11, 2011 | Saws
Delta table saw motor trips breaker
The motor needs a new start capacitor.
Apr 09, 2009 | Saws
Motor starter is tripping the breaker
this problem has to be solved by process of elimination first make sure the voltage used is the correct voltage the next step is to disconnect the motor wires from the starter and turn on the power if the starter engages u have a bad motor if breaker trips starter or power cable is shorted a direct on line 220 volts rated at 20 amps motor starter will work just fine or contactor and overload relay at 20 amps 220 volts ( GE, allan bradly,merlin gerin,legrand are some brand manufactures
Apr 05, 2009 | Delta 10" 3 Hp, 230V, Single Phase, Right...
Correct wiring for delta wired motor
check & confirm the following
1. delta connection of the motor is done properly, with the combination of different windings.
2. check the quality of the 3 pole mcb or check with other one.
you can call me in 00971508105450 or mail me a00971508105450@hotmail.com
Mar 13, 2009 | Electrical Supplies
Delta table saw
The reset button is normally a thermal overload, using a bio-metallic strip to break the circuit. If it is old or has popped a few times it might have 'weakened' abit. Try replacing the thermal/reset button. If it still happens then something might be overheating and causing the problem.
Oct 12, 2008 | Saws
Delta 36-979 10" Left-Tilt Contractor's Saw Logo
131 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
