Question about Apple iPod Photo MP3 Player
I was given a ipod but no manual i don't how to get all of the old music off so that i can put my own music on it
My ipod 120GB can only load 20% of my 1000songs befor freezing I did all that iTunes Trouble shooter said but to no avail. is their a way to fix this without sending it in or should i **** can my po
It will probably take an hour or two to sync 20 gigs of music.
I am sure your 4,178 songs are somewhere around 20 gig.
It takes roughly 6 - 8 hours to put 80 gig on.
Imagine how long it took to put my 130 gigs on.
Word of advice, make sure you turn the settings to manually manage music.
You don't want to lose all your music cause you hook it up to another computer and it syncs with its itunes.
installing more computer ram might be an option
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
also check the usb leads for secure dust free connections
if you scroll to the bottom toolbar while syncing your ipod select task manager application to see whats running if you see something running that should not be running select end now also in the applications see whats ticking over
you might have a virus
To disable automatic updating:
1. Connect iPod to your computer
2. Open iTunes.
3. Select iPod in the iTunes source list, you know in that left column where your playlists and ipod are located.
4. right click on your ipod and select the Options button.
5. Select "Manually manage songs and playlists."
No more long updating each time you connect your ipod.
(Although you might have to wait one more time to do this step but im sure you can do it intermittedly while its updating)
to re enable
1 - Select the iPod in iTunes.
2 - Tick Manually manage music and videos.
3 - Select the Music under Library at the top left of iTunes.
4 - Reselect the iPod and uncheck Manually manage music.
Also, uncheck Enable disk use.
Also remember in the Manange you own tracks mode you need to disconnect your ipod by clicking on the "eject ipod" icon in the bottom right or next to your ipod icon.
The ipod will continue to flash "do not disconnect" if you don't click the eject icon.
Not that my way is hard but there might be a quicker and easier way to load tracks in your ipod when its switched to the manange your own tracks mode.
If there is I would like to know
hope this helps
Oct 03, 2012 | Audio Players & Recorders
Ipod takes hours to sync
2. Open iTunes.
to re enable
hope this helps
Sep 22, 2012 | Audio Players & Recorders
Is there any way to get music off of a first generation Ipod w/ the click wheel. I had the Ipod linked to my wife's Itunes, now we are getting divorced. I got a new Ipod touch and want to retrieve
Rob Pegoraro had a write-up on how to do this in the Washington Post a number of years ago: (click here)
Beware, if you never upgraded your songs to be DRM free and you don't know the username and password for the iTunes account, then these songs that you're recovering will be unplayable.
Feb 06, 2012 | Apple iPod Touch 8GB 32GB 64GB 3rd...
My 5 year old sister was playing with my ipod and she locked it and forgot the pass word i tryed many diserant passes and now my ipod is disabled and says connect to itunes... but when i connect it to the...
Hi keekeerose20...
If you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Please take time to rate me thumbs up.
Sep 23, 2011 | Apple iPod touch
Hi, I have a cortex DJ Mix 300 but only some of the songs on my ipod are being picked up on the database when I load it up. It doesn't seem to make a difference whether the files are MPEG or other...
There are different digital formats and some are not compatible to transfer file names... It is frustrating isn't it?... run into this all the time. To fix the probllem you would probablly have to buy a music editing software packaage that you could edit the files and put them all in the compatible mode.
Aug 06, 2011 | CORTEX DMIX-300 Mixing Deck For iPod, MP3...
Can my rx-817v home theater system be connected to an ipod or is it too old?
Any iPod or MP3 player at its most basic level is just an ordinary analog audio source.
For just listening, any audio device with a headphone/earbud output can be connected to any available analog Line Level input (except PHONO) with a simple adapter. They don't tell you that in the iPod manual because they want you to purchase expensive accessories like docking stations.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
You'll still have tyo navigate the music on the iPod. Life is cruel like that.
Aug 05, 2011 | JVC RX-817V
I don't know how to get or put music on my pandigital I don't have any music on computer or a mp3 or ipod. How do I get music
You could try iTunes, Amazon, or many other sites if you want to do this legally.
Unfortunately, many people use illegal sites to get music for free (Limewire, Media Fire, etc.). These are illegal if you are getting free music from them and you should avoid using them.
Jul 19, 2011 | Computers & Internet
I was given a 60GB Ipod serial # 4J54723STXL. I
For how to use your ipod, you can download the ipod Feature/guide manual here: http://manuals.info.apple.com/en_US/iPod_Features_Guide.pdf
To put music on your ipod you'll need to download and install iTunes, which you can download here: http://www.apple.com/itunes/download/
c@rl
Nov 26, 2009 | Apple iPod Photo-60GB Power Hot Sync and...
Apple iPod Photo MP3 Player Logo
11 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
