Question about Jwin JCAM800 Webcam
Hola necesito instalar mi webcam jWIN JC-AM800 pero extravie el disco y no la puedo instalar...
  • Jwin Master
  • 10,322 Answers
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Jan 12, 2013
SOURCE: ez-305 uvt8532
gdgdg
Posted on Oct 31, 2008
Mykel_N
  • 315 Answers
SOURCE: I lost my driver for
You can download the drivers from Jwin here:
Posted on Oct 17, 2010
SOURCE: como puedo instalar los drivers de la camara web.
supongo q te paso lo mismo q a mi q la pc no te reconoce la camara y x lo tanto los drivers q trae la camara no te sirven para xp.. el problema es q tenes q encontrar los drivers de la camara q te esta tomando windows.. una opcion mas simple seria q instales windows vista o windows 7 q si te la reconocen o por lo menos te dan la opcion de bajar los drivers directamente y automaticamente.. suerte y saludos!
Posted on Jan 31, 2010
ichiboi
  • 78 Answers
SOURCE: i cant find my cd to download the softwere for my
Hi melissajap_p,
Jwin JC-AM800 webcam setup
There are 2 files on the Jwin site, one looks like a full set up and the second looks like it may have updated drivers. I would suggest trying the 2009 file first and getting the 2010 file if the first doesn't work.
Also make sure you disconnect the webcam from the pc before starting the set-up / installing the drivers, the software should ask you to plug it in if it doesn't wait for the software to fully finish and plug your cam in, windows will take over and finish the install..
Good Luck!
Thank you for using Fixya!
Posted on Feb 18, 2011
SOURCE: where do i get a driver for my jwin webcam
where do I find video hardware to download for my jwin webcam
Posted on Mar 06, 2011
Extravie mi disco de instalacion de mi flat planel webcam no puedo instalarla
intentar la descarga de cualquier motor de búsqueda usando el nombre del producto y el modelo
Aug 02, 2010 | Computers & Internet
Como puedo instalar los drivers de la camara web. Cuando conecto la webcam, la pc me PIDE que Inserte el CD pero me dice que no encuentra los archivos . Puedo descargarlos de algun lado? es una GE 98650,...
ok necesitas bajar el driver directo desde la pagina GE 98650 y si es posible el software que viene con ella si es que perdistes el disco. Verifica si a camara es compatible con tu sistema operativo.. o si ya salio un update para ella que resuelva el problema.. Todo se resolvera bajando thel propio site de la camara las ultimas drivers y actualizaciones... Por favor dale a click que mi informacion te ayudo suerte o me avisas para darte otros pasos
Dec 28, 2009 | GE EasyCam Webcam
No puedo utilizar mi camara web en el msn
mi camara se activa y todo pero la otra persona con quien hablo no me ve pero yo si la veo.
gracias por su ayuda.
Aug 12, 2009 | Computers & Internet
Necesito el driver para instalar mi webcam ksx-xvp510 puedes mandarme un sitio en donde localizarlo?
hola necesito instalar mi camara si puedes ayudarme me pide cd y no tengo la compre de segunda sin manual es una camara creative con cable usb gracias
Jun 29, 2009 | Logitech Quickcam Chat Webcam
Hola , necesito saber si puedo cambiar toda la maquina, excepto el DD y dejar este mismo como master, tengo programas que me costaria mucho conseguir e instalar de nuevo gracias
Muchas Gracias COnstantin, quizas me expresé mal, mira mi problema es que el pc, excepto el disco nos quedó chico, es decir, quiero cambiarlo por una maquina mas nueva core duo por ej, por ende con distinta placa, y el DD tiene toda la informacion y programass con licencia que necesito, entonces necesariamente tiene que quedar como master, me indicaba un tecnico que los driver de la placa podriasn darme problemas, si es así y tengo los drives de la maquina nueva ( placa) no debiera tener problemas?
agradeceré tu respuesta
gracias
Jun 23, 2009 | MSI PM8PM-V Motherboard
Gigaware 25-157
perdi el disco de instalacion dE MI CAMARA GIGAWARE 25-157
Jul 06, 2008 | Radio Shack VGA PC Camera Webcam
WHERE DOWNLOAD
my AC power Adepter for the Benq DC 3400 is damaged...
Jun 29, 2008 | BenQ DC3400 Digital Camera
Un problema con webcam
como puedo hacer mi driver se me a extraviado como mi maquina tuve que formatearla ahora como hago para instalar mi wed cam
Jun 16, 2008 | Computers & Internet
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
Jwin JCAM800 Webcam Logo
502 people viewed this question
Top Jwin Computers & Internet Experts
xalint1
xalint1
Computer Links
Are you a Jwin Computer and Internet Expert? Answer questions, earn points and help others
