Question about Panasonic Cell Phones
I have a Panasonic Model KX-TG9391 2-line phone with a base station and 2 remotes. Suddenly the phone only rings once and goes dead. If I rush I can pick up the caller. I can also make outgoing calls. It does not now go to the answering machine. It worked perfectly and this just happened?
  • Panasonic Master
  • 17,129 Answers
Seems that the fault is related to problems in the dialer section or the processor.
You must first of all check the line voltage to the phone, if the voltage is less when the call comes in the ringer will be deactivated. This can also be a failure of the RINGER unit IC. Also if the call cuts off after a ring then the fault can be linked to the processor as the mode selection for the answering machine is also not working.
Also check the voltage using simulated calls, check to see if only the ringer cuts or the entire phone cuts off.
if so there is possible problems in the processor. Solder and check.
Posted on May 19, 2011
Panasonic voice mail setup for model no. KX-TGA500W phone
Hello Lynda,
Trying to get the answer to turn off your BASE FEATURE...
KX-TGA500W appears to be a WIRELESS "remote"
handset that operates from your wired BASE...
A typical base will be KX-TG + (4 digits).
In ORDER to PULL an owners manual...
I am required to know the MODEL NUMBER of
your base station...
The ONE Panasonic PHONE that is connected with
a modular jack... (to the wall.. off to the central office
("CO")) and out to your friendly telephone network... via
telephone cables...
I need the BASE model number:
From thence I will be able to access your owners manual.
In the MEAN TIME:
I'd suggest that you PHONE HOME and let your phone
ring no less than 12 times... before you can say with CONVICTION... that you don't have VOICE MAIL.
It assumes a level of PHONE COMPANY
competence & skill... (I doubt).
Trust... but VERIFY.
I am here daily please comment me back... or repost your question with the BASE model number.
We can do this...
Carnac the Magnificent
Mar 20, 2017 | Panasonic Lands Phones
My panasonic home phone only rings once, it used to ring normally and would also say what number is calling. please help.
We recommend you unplug the Panasonic base unit and make a test call from another number. If the line disconnects after 1 ring then you have either a telephone line problem or another device connected to the telephone line is the problem.
Mar 03, 2014 | Panasonic (KX-TG1032S) Phone
Panasonic KX-TGA711E
this sounds like you are either out of range of the base unit or your base station isnt plugged into the mains, ensure you have the base station plugged into the power and the phone line from the wall socket is plugged in, the base station controls all the handsets, if it isnt plugged in they wont work, good luck
Aug 05, 2009 | Panasonic KX-TG1033S Cordless Phone
I have the kx-tg 4500 4 line base unit phone. Line one flashes but does not ring or display caller. The other lines work fine. The handsets show no activity ie they don't even flash if a call comes in on...
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
Aug 05, 2009 | Panasonic KX-TG4500 Phone
Panasonic base unit went dead
THROW IT AWAY.  I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE  HAVE BEEN COMPLETELY USELESS!
Mar 10, 2009 | Panasonic KX-TG4500 Phone
Dead handsets
i had the same problem with my KX-TGA650 and called repair out and they said it wasn't seating on the home base to charge, we'll see. i'm looking for a manual for this phone lost mine and cost prohibitive to order from panasonic. and download pdf is just too large.
go to website and it tells you that only a same model is able to be used with the base unit. hope this helps.
martha
angelml@sbcglobal.net
Jan 05, 2009 | Panasonic KX-TGA650 Cordless Expansion...
We have had a panasonic KX-A141ALM (two handsets) for about 6 years. Yesterday they suddenly had no dial tone. We checked all plugs & connections, the handsets are charged and we have now changed the...
Hi There, me too. I have the same models. one is on our fax machine and the other is remote. One does not ring, sometimes does not answer, other times it won't ring out. bugged if i know, i'm investing in another handset but am unsure if the later models will pair to the base station............good luck
Jun 09, 2008 | Panasonic Lands Phones
Panasonic Phones are on mute and will not work
The following is generic for most cordless phones:
Did you check to make sure that the phone is not in the intercom mode? If this phone has a base station speaker phone, make sure it is not on mute. Some of these phones have a fax connection. Make sure your phone line is not accidently pluged in to the fax section. Also if the phone has a fax monitoring feature check the the setup menu that the fax is not enabled. If the phone has an answering machine mode, make sure that this feature is turned off.
In the worse case:
There may be a defect in the X-Mit section of the phone. I would suspect the fault to be in the base.
Jerry G.
Apr 09, 2008 | Panasonic KX-TG5632 Phone
Cell Phones Logo
Top Panasonic Cell Phones Experts
Rommel Balcita
ray gallant
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
