Question about Refrigerators
I am installing a gasket on a viking freezer model# DFFB304L I have looked at the trim etc how does this gasket attach I did not see any screws or clips do i have to remove all of the stainless trim the bottom looks locked in by the door hinge. do I have to remove the door?
  • rkraft44 May 20, 2011
    I found that the gasket on this model had no screws it simply pushes in place it has a spine on the back that fits into a grove that is why the corners and the rest of the gasket perform so poorly
  • 11,800 Answers
The door gasket is pinched between the door frame and the internal panel that is hold in there with screws. To simplify the operation take out the screws from the upper half only (top and half the sides), take out the old gasket from that part, reattach the screws from the top and remove all the others, take out the old gasket completely and insert the new one. Now reinsert all the screws - make sure the gasket sits well, you will not be able to rearrange it afterwards.
You should keep the door attached to the freezer, it will make the job easier.
Posted on May 19, 2011
How do i get a gasket replaced on a sears kenmore freezer model 31165
Order the new gasket using your model number- 31165 is not a valid/complete model. Remove the door and lay it flat on the floor, then remove the screws from the upper half of the door perimeter- DO NOT remove all the screws at once or you will be unhappy! Pull the top half of the old gasket away from the door, then put the top half of the new gasket in place and screw it back down. Next, remove the bottom half of the screws and pull the old gasket off, then put the bottom half of the new gasket in place and screw it down. If you try to do it all at once, the door will flex out of plane and won't lay flat when you re-attach it. You might need a hair dryer to soften the gasket if it was deformed during shipping. If you have a newer, press-fit style gasket, just yank it and press the new one in... Door Gasket 241872513
May 20, 2016 | Kenmore Freezers
Freezer not cooling properly. Temperature alarm went off. Turned off now.
Look inside freezer on the rear wall to look to see if there is frost buildup. If yes then unplug and manually defrost defrost for about 3 hours if you only open freezer or place hot water in a bucket and place inside freezer and close the door. Let me know by answering my post here, Thanks John T.Appliance 911
Contact
click below for parts breakdown
I have a feeling the problem could be 1 of three things=> WR9X520 Defrost Timer, WR51X465 Defrost Heater or the WR50X0131Defrost Thermostat
May 28, 2015 | Viking Professional VCBB363 Bottom Freezer...
Condensation in the right door of my VCFF136 the gasket is teared, I don't now what caused what first?
Condensation is cause by warm air meeting cold air. I would suspect the door gasket was the cause of the condensation. When looking this up, I found many different models under this number, part number 67003547, this gasket is black in color and is a push on, means no screws required to change.
I hope this helps
Oct 15, 2013 | Viking VCFF036 Bottom Freezer French Door...
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
If equipped, remove window crank.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
Separate linkage rod from latch handle.
Remove front door trim panel from vehicle.
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
The freezer gasket is no longer sealing properly allowing frost to buildup around the edges which eventually falls into the refrig area, thaws and leaves a puddle. Can we replace the gasket?
Yes, the gasket is replaceable, for modest cost and difficulty=easy.
Where to get new gasket: take exact Mfr. & model number (and serial number) of fridge
to your nearest
major appliance parts store (see yellow pages). Call them, to see if they have your replacement
gasket in stock, or may need to order it.
How to replace gasket: pull back inner edge of gasket until your see the 1/4-in hex head machine
screws attaching it to the freezer door. Using nutdriver, unscrew old gasket's screws, and
install new gasket by reversing the procedure, starting with the top middle screw, and proceeding
around the edges.
Its a "nutdriver project." If for some reason the screws are too rusted to re-use, an equivalent screw
(just match the diameter and length) is easily
(and inexpensively) obtained at your nearest hardware store - you won't even need to return to the
appliance parts store.
This procedure works for most standard freezer-over-fridge units - you can include your exact
Mfr. and model number in your next query for more precise info.
Jul 04, 2011 | Refrigerators
I needed to replace climate control unit on1997 Grand Am GT. Concerned with how to remove the cluster face panel w/o breaking it.
Let me know if this helps out.
Heater & Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the screws securing the cluster trim plate to the instrument panel.
  3. Tilt the top of the cluster trim plate downward releasing the clips that mount the bottom of the trim plate to the dash. Remove the trim plate.
  4. Remove the screws attaching the accessory trim center plate to the dash.
  5. Tilt the top of accessory trim plate downward releasing the clips that mount the bottom of the plate to the instrument panel. Remove the plate.
  6. Remove the screws attaching the control assembly to the dash.
  7. Remove the control assembly from the dash.
  8. Disconnect the control assembly electrical connectors.
  9. Remove the control assembly.
To install:
  1. Install the control assembly.
  2. Connect the control assembly electrical connectors.
  3. Install the control assembly attaching screws.
  4. Push the mounting clips into place and roll the top of the accessory trim plate upward into position.
  5. Install the screws attaching the accessory trim plate to the dash.
  6. Push the mounting clips into place and roll the top of the cluster trim plate upward into position.
  7. Install the screws attaching the cluster trim plate to the instrument panel.
  8. Connect the negative battery cable.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 40; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Jan 23, 2011 | Pontiac Grand Am Cars & Trucks
Need to remove door panel. How?
Door Panels - REMOVAL & INSTALLATION
The many different design interiors make it impossible to list each fastener location. The trim panels that must be removed are held in place by screws and clips. These locations vary from model to model. After removal of all the fasteners that you are aware of, if the trim panel is still firmly attached, you probably missed a hidden fastener. If this happens, gently and carefully pry the area looking for the location that doesn't flex. The location that does flex is where you'll find the fastener(s) you missed. Screws and retainers are usually hidden. Handle trim, reflectors, light lenses and other plastic pieces usually cover the main retaining screws. Take great care with the plastic trim panels. Plastic trim panels are usually very hard plastic and extremely easy to crack. The following steps can be used to guide you through the removal and installation of the trim panels, but you may need to alter these steps to your specific needs.
  2. Pull the inside door handle to the open position, unfasten the screw and remove the handle escutcheon.
  3. If equipped with manual locks, remove door inside locking rod knob.
  4. If equipped with manual windows, insert a suitable window regulator handle removal tool behind the handle. Disengage the retainer, then remove the handle.
  5. If equipped with power windows and locks, use a small flat-bladed prytool to carefully pry the switch plate up, then detach the power component electrical connectors.
  6. If equipped, remove the screws inserted through door armrest and pull handle assembly into door inner panel or armrest hanger support bracket.
  7. Lift the seat belt trim panel up and remove the hidden retaining screws.
  8. Remove the outside side view mirror trim plate retaining screw. Lift the panel up to disengage the retaining clip, then remove the trim panel from the door.
  9. On styles with courtesy lamps located in the lower area of the trim panel, disconnect the wiring harness at the lamp assembly.
  10. If equipped, use a suitable tool to pry the reflector plate from the side of the door panel.Remove bottom trim cover retaining screws, then remove the lower trim cover.
  11. Remove any necessary electrical connector CPA clips, then unplug the electrical connectors.
  12. On styles with integral armrests, remove the screws inserted through the pull cup into the armrest hanger support.
  13. Unfasten the door trim panel retaining screws. The locations of the screws will vary depending upon the year of model of vehicle. The screws are usually hidden, so be sure to look carefully to make sure you don't miss any.After all of the trim panel retaining screws are removed, slide a suitable trim panel removal tool between the door panel and door perimeter to carefully disengage all of the trim panel retaining buttons. Make sure to position the tool close to the fastener, or the trim panel may be damaged.
  14. Carefully lift the trim panel away from the door, checking to be sure all of the retaining buttons and screws and electrical connectors are unfastened.
To install:
Before installing the door trim panel, check that all trim retainers are securely installed to the panel and are not damaged. Replace damaged retainers as required.
  1. Connect electrical components where present.
  2. To install the door trim panel, pull door inside handle inward; then position the trim panel to the inner panel, inserting the door handle through the panel hole.
  3. Position the trim panel to the door inner panel so that the trim retainers are aligned with the attaching holes in the panel, and tap the retainers into the holes with a clean rubber mallet. Install all previously removed items.
  4. Install the remaining door panel components in the reverse order of removal.
  5. After installation, connect the negative battery cable, then check for proper attachment and operation of electric components, if so equipped.
Hope helps (remember rated and comment this).
Jun 29, 2010 | 1987 Oldsmobile Delta 88
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
I NEED HOW TO INSTALL A gasket ON THE DOOR OF A HOTPOINT, GASKET WR24X450.
look at the door gasket, look underneath the gasket and you can see how it is attached. either with a clip or the plastic itself is the one holding the gasket. unscrew all screws holding the gasket, order a new one and install backwards. if there is no screw, there is a grouve in the plastic wall where you can insert the gasket. just slowly pull the gasket and push the new gasket in to the grouve.
Feb 15, 2008 | GE Hotpoint Top-Freezer Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
