Question about Olympia Standard 300 Typewriter
How to move the space to the right side of the typewriter
  • Olympia Master
  • 3,594 Answers
I'm guessing that you want to move the R. margin. Go to the margin press but don't hold the mar rel key space or backspace to desired location, press R. mar key.
DickyO
Posted on May 19, 2011
  • 3594 Answers
SOURCE: Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Posted on Dec 08, 2008
  • 3594 Answers
SOURCE: blinking lites on line space - lower right hand
You probably need a keyboard but first try my tip under WW1000.
DickyO
Posted on Oct 12, 2009
  • 61 Answers
SOURCE: Typewriter will not space
It sounds as if the spring in the drum under the carriage has broken. Major problem.
Posted on May 01, 2010
alicantecoli
  • 22326 Answers
SOURCE: While moving, I accidentally bounced my mother's
all i can say is have a go as if not its scrap ,if you can get it apart i would hazard a guess and say that the operating mechanism under the key is damaged in some way or the key is sticking in the keyboard ,Now without having a play its difficult to diagnose and help but iam sure you will sort it out especially as you have another machine for parts
Posted on Dec 25, 2010
  • 3594 Answers
SOURCE: Problem with the line spacing
If all the settings are right and it feeds with the platen knob the plastic gear on the index mitor is probably broken the part is about 25.00 plus installation.
DickyO
Posted on Jun 07, 2011
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
How do I unlock right margin on a Swintec 7040 typewrite?
move your carriage to right margin by using "tab" or "space bar". then press "margin release" and using "space bar" locate carriage where you want right margin to be, then press "right margin".
razors
Nov 03, 2011 | Swintec 7040 Typewriter
Problem with the line spacing on my brother sx-4000 typewriter. The spacing wheel is not moving the paper down to the next line. I've moved the lever on the right side back and forth to see if it...
DickyO
Jun 07, 2011 | Brother SX-4000 Typewriter
How do i set margins
Move the carrier with the back space or space bar to the position you want a new margin then press the mar button for the left or right side as needed
Nov 20, 2010 | Smith Corona Wordsmith 100 Typewriter
Right Margin: I need to move the right margin.
Space bar to where the current right margin is. Press "margin release" key once. Space bar to where you want right margin to be. Press "margin right" once. This should work.
Aug 20, 2009 | Brother ML-100 Typewriter
Changing tabs and move the right margin over some
On the L. side of the T/W ketboard are the keysmar left, mar right,tab set, tab clear and mar rel. Space to the location thayou want th R. mar and press right mar key, if it stops at the R. mar. press and release the mar rel key. To clear tabs tab to the one you want cleared and press tab clear. To set a tab space to the position and press tab set.
DickyO
May 26, 2009 | Nakajima AE-740 Typewriter
DickyO
Dec 08, 2008 | Office Equipment & Supplies
Margins
Most electronic typewriters work the same way to change margin settings. You use the space bar to move to the desired location then press the right margin key. You should hear a beep. If you need to set it farther to the right of the current position, then use the space bar to move the carrier to the current position, once it stops moving then press margin release then space to the new position then press right margin key.
Aug 10, 2008 | Brother EM-530 Typewriter
Margin locked
check that there is nothing dropped into the typewriter that may be blocking the carrier try turning the machine off and moving the carrier by hand to the right side,if it moves ok then turn it back on space the place it stops , touch the MR (margin release button) then try spacing further to the right nad reset the right margin.
Jan 28, 2008 | Swintec 7040 Typewriter
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
Olympia Standard 300 Typewriter Logo
54 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Michael Galve
Michael Galve
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
