Windows media player 11 hanging considerably in vista hp 32
Just the other day, I started experiencing an odd issue with wmp 11. when I start the program, the cpu hangs at 45-60 %, with no correlating tasks in the task manager to be found. the "now working" activity icon for the mouse blinks on and off repeatedly during this hang-up, which can last anywhere from 1-5 minutes... any thoughts? could this be driver related?... anre there any known program incompatibilities to be aware of?
SOURCE:
SOURCE: Counter Strike Game
instalar counter-strike
Posted on Apr 15, 2008
rockitman187
  • 2559 Answers
SOURCE: windows media player and windows sidebar is no more working
To repair media player in Vista,You will need to reinstall vista as the media player in integrated into the operating system.
You can not download a windows media player for Vista,It will not install.
Please rate this fixya
Posted on Jan 25, 2009
  • 189 Answers
SOURCE: windows media player 11 shuts down
remove and install again. Probably some issue with supporting dlls or missing files.
Posted on Mar 10, 2009
SOURCE: vlc player gets hanged.
  1. OK, remove VLC Player
  2. Remove K-Lite codecs (VLC doesn't need them)
  3. Install these codecs designed for Vista
  4. After installing, restart, and play all video and audio files with Windows Media Player
Please vote if this helps.
nLinked
Computer Support Services
Posted on Jun 08, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Vista - Windows explorer hangs during start
Sounds like a corrupt start up. Install your Vista disc and boot from the cd. After it loads windows it will give you several choices of what to do, choose repair startup and let the disc do its magic. When it is finished it will give you other choices after that. Take the disc out and restart and see if that takes care of the problem. If it doesn't, load the disc again and maybe try a early restore point, say a week before the problem started or think back to what happened to make this problem occur in the first place and go back to that restore point. You can pick earlier restore points then what is initially shown to you, just take your time. When restore is done, make sure to remove the disc.
Posted on Sep 02, 2009
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Error when trying to download MS strrets and trips 2006 w/ GPS lo
I have used every version of streets & Trips since 05, and have never had any issue with Win Media Player, currently using streets 2009 on one machine with Windows 7 RC1, which has WMP 11, and on another PC streets 2008 and Vista with WMP 11. You may need to change your default program settings for media back to WMP if you ever had another media player installed.
Jun 13, 2009 | Microsoft Streets & Trips GPS 2006 x GPS...
Cannot install WMP 10
http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx
Two thoughts, go back, use Restore in system tools or download the WMP 11 (the link above)
going to 11 may just fix everything for you...
I was thinking you may have selected the wrong version like XP-64...the one you want is the first one on the page win xp
May 04, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Windows Media Center proplem ( unknown Audio Error 80040155 )
Go to start : All Programs: Accessories: right click on Command Prompt, click run as administrator. click continue: you should see C:\Windows\system32> type there regsrv32 wmp.dll It should look like this C:\Windows\system32>regsrv32 wmp.dll
(make sure to put the space in between 32 and wmp)
An info box will appear. Click Ok then restart.
That should fix it!
Mar 23, 2009 | Microsoft Windows Vista Home Premium with...
Sansa e260 and Windows Media Player 11 Issue
What you need to do is to uinstall the device completely from the computer..once you have the device remove, open your windows media player click on tools, options, go under privacy,clear the history and caches...and then reinstall the device back...let me know if that doesnt help yo
Please rate accordingly
Thank you
Computerrrep
Aug 16, 2008 | SanDisk Sansa e260 MP3 Player
Windows media player can't play .wmv files
  • Firstly a UPS is an abbreviation for Uninterrupted Power Supply - meaning emergency backup power in the event of a mains power failure. This is not a type of PC.
  • Secondly - Windows media player does not support every type of movie format, as Microsoft Update it from time to time, some formats will still not be supported, these are known as codecs.
  • Thirdly, codecs to support your particular format can usually be downloaded and added to Windows Media Player, however i can not think of any reason .wmv files are not supported by Windows Media Player.
You could try re-downloading the latest version of Windows Media Player from one of the links provided below.
WMP 11 will support the latest codecs, but if for some reason you find yourself needing the older version, use WMP 10.
You will most likely have to remove your current version of WMP, and you can do this by using Windows Add/Remove programs.
  1. Click on the Start menu button ( bottom left corner of your screen. )
  2. Click on Control Panel.
  3. Click on Add or Remove Programs.
  4. Click on Windows Media Player in the list.
  5. Click Remove ( right hand side of the listing )
Microsoft WMP 11 is available by clicking on this link:
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Microsoft WMP 10 is available by clicking on this link:
http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx
WMV 11 is available by clicking on this link:
http://filehippo.com/download_windows_media_player/
Feb 05, 2008 | Computers & Internet
Syncing
It is possible that you do not have Windows Media Player 10 or 11. If you do have WMP 10, then try resetting the GoGear first (with GoGear turned on, find a small paperclip or other such device, and press it into the reset hole; it works when the player turns off). Try syncing again.
If you have WMP 11 or Windows Vista, perform a firmware upgrade:
just open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website; click on the Update tab - this will give your player the firmware upgrade.
If these methods fail, reply to message using FixYa website (not my personal e-mail).
-Tha Mp3 Doctor
Jan 13, 2008 | Philips GOGEAR SA6045 MP3 Player
Computers & Internet Logo
235 people viewed this question
Ekse
Marvin
Marvin
