Question about Dishwashers
Hobart c64, 25 years old. How many gallons per minute is used at final rinse.
I have a c64 dishwaher it keeps tripping the overload for the pump motor it runs at 6.8amps on all legs motor is 5amp rating and can't find anything restricting motor is motor close to its end
Posted on Jan 25, 2012
4 Suggested Answers
  • 13 Answers
SOURCE: rinse not hot enough
145 degree is just your hot water temp and that your dishwasher hot water booster is not working assuming that this machine has worked in the past to produce final rinse water above 180 degrees. Remove the bottom panel and to the right you will see the booster tank, look for a nickel size component with a small red button on it. Try pushing on it to reset it. If that does not work, check for voltage at your heating element on your booster tank. (the thicker wires) If voltage is present then your heating elements need replacing.
Posted on Nov 15, 2008
  • 109 Answers
SOURCE: I have a three year old Hobart. I am not sure
Look on the top edge of the door to find the data plate. It sounds like an SR24, if the leds are on the left of two temp gauges. If your sanitizer pump has a tired silicone tube that is flattened from use, it will not draw chemical. if you have an air bubble in the sense board at the back, it will think you have run out. If you have changed the type of chemical or diluted it, the board will need recalibrating to suit. Put some sanitizer in a small vessel with the pickup tube and monitor the amount delivered. Usually one is looking for 50 ppm solution of bleach and rinse water.( test with litmus paper) If you have an SR24H with a booster, you don't need bleach sanitizer and holding the sanitizer button will turn the sense off.
Posted on Aug 08, 2009
Daniel S
  • 4323 Answers
SOURCE: Hobart Dishwasher Model #851017556
Hi
The rinse cycle will use around 2.27 liters (.59 gallons) of water and a full cycle in the unit will consume about 15 liters (4 gallons) on average. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 16, 2010
Water continues coming
Hobart ' Undercounter Dishwashers, Commercial ...
www.hobartcorp.com/.../commercial.../undercounters...
Hobart CorporationGlasswasher ... The LXe undercounter is ENERGY STAR® qualified, uses only .74 gallons of water per cycle and features new Smart Display technology to eliminate error codes. Loading... Highlights: Hobart undercounter dish machines are the most popular in the industry, keeping reputations spotless all over the world.
Advansys LXe Undercounter ' Hobart
Hobart CorporationGlasswasher ... The Hobart LXe Undercounter Dishwasher is designed to pack best-in-class cleaning power into a compact space, ... The Advansys LXe low-temp model features PuriRinse, a cold-water rinse that removes chemical residue, ...
[PDF]AM15 Technical Manual - Hobart
https://my.hobartcorp.com/kroger/.../AM15%20Technical%20Manual.pd...
Steam Booster, if used based on 20 PSI steam - 20 PSI water flowing. 130°F entering.... DRAIN AND OVERFLOW: Large bell type automatic overflow and drain ...
[PDF]Glass- and dishwashers - Hobart
Dec 08, 2015 | Hobart Undercounter Glasswasher w/Chemical...
Why does the Honda GX160 engine start to pulse after running pressure washer for a few minutes then finally kills?
Hi pulsing is usually a sign of insufficient water flow to the unit.
always get the largest water hose you can for the feed and check to see if your water system can keep up (if it is a three gallons per min machine grab a bucket and make sure you are getting at least 3 gallons per min before you plug the machine in.
The number one culprit for bad flow is the ez hoses or retractable hoses.
Sep 21, 2014 | Garden
Hobart SR24H dishwasher after rinse cycle the same time pampas water in and out of the dishwasher, two pipes are opened and working
Hello.
As per my personal opinion this is normal because for the final rinse you have a small booster or boiler..
When you turn on the machine..it starts fill and also the booster for the final rinse.
You start the machine..wash cycle...rinse cycle..
Now..new water(from rinse booster) is coming on the tank in order to rinse the dishes..on the same time the machine drains the excces water from the rinse(over flowing) and fills up the booster with new water.
Should be like this
Good luck
Jun 29, 2013 | Dishwashers
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
No problem, just looking for gal. per minute flow rate
It uses 1.2 gallons for each wash or rinse action in a cycle.  The water only runs until the 1.2 gallons amount is reached and then that water recycles through the pump for the duration of the action.  Start the dishwasher and time how long it takes until the water stops filling (not the entire time of the action).  Divide 1.2 by the number of minutes including seconds as a decimal fraction (i.e. 1 minute and 30 seconds = 1.5 minutes) to get the flow rate in gallons per minute (GPM).
May 29, 2009 | Amana 24 in. DWA33A Built-in Dishwasher
I have a fimco pump on a 25 gallon sprayer. It is a 2.1 gallon per min. pump. I took it out yesterday to use and it would not pump up, no pressure. Worked fine last year. I checked and the motor is...
open up the pump, take out the check valve. wash in dish soap/hot water solution, scrub with old toothbrush, rinse off, reinstall & see if that makes a difference...
Apr 29, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Quanity of rinse agent per gallon of water
none.  and make sure the heater is off and use luke warm water.
Apr 01, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Need to know AM 14 rinse cycle water useage
12 second sof rinse used about 0.8 gallons at that presurre
Feb 17, 2009 | Hobart AM14C-155 Dishwasher
Rinse not hot enough
Nov 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
137 people viewed this question
Top Dishwashers Experts
