Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
I have an LT1042 Cub Cadet. It works great for about 15 minutes and then the pto clutch quits. I push the pto switch in and pull it out and it works for 5 minutes and then I have to repeat. It eventually gets so that it does it every few seconds. I have replaced the pto switch and no improvement. Is there a relay causing this or is the pto clutch getting bad? Any ideas?
  • 11,800 Answers
The clutch fails because one of its components overheats and the electrical contact is broken. The most likely part to fail is the clutch itself and that is easy to check: just pull the relay out and short it with a thick wire .
If that fixes it then you need a new relay - replace it
http://cgi.ebay.com/Cub-Cadet-PTO-RELAY-SWITCH-Blades-LT1040-LT1042-/200595264757
If you still have problem the clutch is near its end of life. Just buy a new one - you will find it in this page, at about 2/3
http://www.psep.biz/store/cub_cadet_electric_pto_clutch.htm
Posted on May 19, 2011
I have a LT1042, cub cadet. PTO clutch burnt up. I replaced it and the solenoid, fuse, and relay. Thinking that when PTO clutch burnt out that something else like a wire or sensor went out also.
Check all the safety switches u have a bad one look under the seat first that one is a common problem so I take it your PTO won't engage I bet your old PTO is still good the safety junk they put on these mowers fails a lot causing problems running your mower also look under the back side by the tire there is another safety switch that gets corroded that's switch is the one that will not let you mow in reverse if you want to bypass it u can just put the wires together then beware your mower will work in reverse also I hope this helps you have a great day Regards Chris
Aug 03, 2016 | Cub Cadet Garden
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
I need part no. for manufacture date 2005 cub cadet lt 1045 modle ps-sv600 0009 pto clutch
I have a 2005 Cub Cadet LT1042, Spec. No. PS-SV590-0003, but my parts manual also lists part numbers for the LT1045. The clutch part no. given for your model is 717-04174.
Hope this is helpful.
Paul
May 10, 2013 | Oregon Scientific Electric PTO Clutch for...
I have no power to the pto on my LT1042 mower I found broken wires and fixed the but still no power. Where are the fuses that would blow? I only found one fuse and its ok
Did you check for power at the pto switch? Start with checking that, then check the wire from the PTO switch to see if it has power all the way to the PTO clutch. If there is power to the clutch, and the belt is good and routed properly it's probably the PTO clutch.
Aug 11, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
How to replace pto clutch on cub cadet LT1042
before you replace it check the wires on the old on mine broke one inch from the clutch but you only need to remove the center bolt then it pulls off but when you but it back make sure its locked into the part that holds it from turning
May 09, 2012 | Cub Cadet Garden
Hi...I have a 2005 Cub Cadet 2042. With the switch in ''normal'' and the PTO engaged, when going forward cutting the grass the PTO will disengage for no apparent reason. You have to push the PTO knob in...
In the cub cadet, the PTO power is maintained via a latching circuit that includes a reverse switch and a reverse relay. Locate the reverse switch that senses whether the tractor is in reverse -- either it's come loose, become misadjusted, or it's failed, or the wiring and connections are loose. You could bypass the switch to confirm this as the problem.
Jul 10, 2010 | Cub Cadet Garden
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Oct 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
509 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
