Question about Kenmore Refrigerators
REFRIGERATOR MAKES A LOUD VIBRATING NOISE WHEN SHUTTING DOWN
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about the clunkingor thumping in refrigerators...
Refrigerator Clunkingin back
heatman101
Posted on May 20, 2011
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
Our Samsung fridge srs757dw is making weird noises(it hums loudly). When the Freezer door is open it stops but as soon as it closes the noise begins again. What do you think is the problem?
Sometimes this can be due to vibrations within the duct , possible that the ventillating fan is frosted and so makes the noise with the door closed. So shut down fridge for few hours to defrost and check.Also make sure there are no loose screws or clips on the back panel and the evporator section that can cause vibration.
Aug 30, 2011 | Samsung Televison & Video
GE top freezer refrigerator: motor has become very loud and refrigerator vibrates. However, when I move the cold control to a lower number, it gets slightly quieter and vibrates slightly less.
Please make sure it is level, the compressor is designed to run on level ground. Also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise.
Find out where the noise is loudest. if it's under the fridge, it's the compressor.You have to check the coil for the compressor and if it's inside the freezer, it's the fan bearing.
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 20, 2009 | Refrigerators
Loud buzzing noise on a Magic Chef compact refrigerator help!
Disconnect power from unit. Remove the cover at the bottom, rear. Examine all refrigerant tubing for contact with other tubing or other surface. Carefully adjust the tubing to prevent contact vibration.
Sep 12, 2009 | Magic Chef CTB1821AR Top Freezer...
Kenmore Coldspot 69182990 - knocking noise
check te rubber mounts at the bottom of the compressor
the rubber rots after some time and the compressor moves on shutting down as the knocking could be that noise
May 20, 2017 | Kenmore Refrigerators
Refrigerator making a loud noise
You probably just need new mounts. They are the rubber feet that the compressor sits on.
Mar 27, 2009 | KitchenAid Refrigerators
Refrigerator makes loud noise when motor is shutting down
Check for dirt, vacume throughly. Visually inspect fan blade, for anything not normal.
Mar 11, 2009 | Refrigerators
Compressor makes a loud grumble an vibrates when it shuts off
There are springs inside the compressor that suspend the motor. When one or more of those springs break then the motor will knock against the casing when it shuts down and loses centrifuge motion. The compressor will continue to run up until the point the it beats itself to death, which could be next week of next year. There's no way to tell. The only solution is to replace the compressor.
Oct 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
LOUD HUMMING NOISE
Here's my thoughts:
Make sure it is level.
Could be some things inside the fridge vibrating against each other.
Geno
Feb 09, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Refrigerators Logo
90 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
