Question about Microwave Ovens
How to defrost solid frozen thick steak - Microwave Ovens
  • 1,548 Answers
If you are using a microwave oven that does not have a "Defrost" program, you should run it a low power setting. This cycles the magnetron on and off and gives the heat energy a chance to disperse evenly through the steak instead of starting to cook some areas while the rest is still frozen. Put the steak in a pie plate or similar rimmed dish with a loosely fitting microwave-safe cover (plastic wrap is often used). My mother often puts an upside-down saucer under the meat so any liquid would drain off.
The next question is how long it will take to defrost. If you are up for some arithmetic and you know the power rating of your oven, we can calculate it. (If your oven has a defrost-by-weight feature, it does all of the figuring for you and you can skip the following if you want.) I'm used to doing this in metric units since I was raised as a physicist, but I'll give you conversion factors.
Numbers:
M = weight of steak in kilograms (multiply pounds by 0.4536). I'll assume you have a one-pound steak in my example calculation.
Tf = Temperature of frozen steak in degrees C. For a typical home freezer at 0°F, this is -18°. The conversion formula is subtract 32 from the temperature in degrees Fahrenheit, then multiply this by 5/9.
P = Oven power at the Low power setting. If you have your owner's manual, this is probably listed in the specification. If not, you can make a good guess by dividing the full power rating on the label by the number of power steps, e. g., if you have a 1000 watt oven with five power steps, the lowest power setting will be 200 watts and the next one will be 400 watts. Since this is a thick steak, I'd pick the 400 Watt setting.
Other numbers: Specific heat of water is 4.375 kiloJoules/kilogram per degree C (this accounts for the energy needed to bring the steak up to the melting point), and Heat of Fusion (energy needed to finish thawing once the steak gets up to 0 degrees Celsius) is 334 kJ/kg.
Formula: Defrost time in seconds = M * ((0 - Tf) * 4.375 kJ/kg/ °C + 334 kJ/kg)/P *1000 Joules/kJ.
The last part converts kiloJoules to Joules, which is a factor of 1000. Watts = Joules per second, which is where we get the time we want to calculate.
Example using a one pound (0.4536 kg) steak starting at 0°F (-18°C) in an oven on a 400 Watt setting:
T = 0.4536 * (18*4.375 + 334) /400 * 1000 = 468 seconds per pound = 7 minutes, 48 seconds
Notes: you can assume your freezer temperature is fairly constant, and the power setting you use will also be fixed, so you calculate all of this once, including the 0.4536 kg per pound conversion factor and write the number down on a note to stick on the refrigerator or wherever you like. Then all you have to do is multiply the weight of whatever in pounds by this number to get the defrost time. For thin items, use a lower power setting and adjust the formula's power value accordingly.
This is necessarily not an exact calculation because steak is not all water. That means it won't absorb the microwave energy with 100% efficiency, and the specific heat won't be the same either. However, it will get you close enough to set a reasonable time on the oven.
Posted on May 19, 2011
    Problem Solver:
  • 17 Answers
Try this video which will help you defrost foods safely. http://www.youtube.com/watch?v=eS6mRtRKG8Y
If you have extra time though, defrosting food in refrigerator is still the best way.
  • 108 Answers
You can set your microwave to defrost or 50% power to defrost steak
if this was helpful please give it a thumbs up to help others too
How do I defrost a package of frozen hamburger meat (2.25 lbs)on the Sharp Carousel R405JFK microwave ? The instructions on the front of the microwave are sort of confusing...
try defrost = 2.3 enter/start I use my sharp (not a R405) all the time to defrost meat and that's how mine works , I know its a bit confusing as defrost goes by weight not time like the cook mode does
Sep 29, 2016 | Sharp Microwave Ovens
How do i deforst chicken breast
Put in ziplock bag. Submerge in cold water for about 1hour.
Dec 03, 2012 | Microwave Ovens
Refigeration line in freezer gets so hot it glows red.
Thats your defrost element :) If you are not having any problems with your freezer staying frozen, that is normal
Mar 25, 2011 | Microwave Ovens
How do you defrost rfa52 polar white fridge freezer?
Switch off the power and place all the contents in a thick bage inside a large cardboard box, to keep it cold. Place a tray to catch the thawed ice in the apropriate place and wait.
When defrosted, wipe the surfaces down with an antibacterial liquid/spray of food grade quality and switch the power back on. Replace the frozen food, after checking the date codes, in the freezer
Jan 04, 2011 | Hotpoint Microwave Ovens
How do you defrost a samsung rs21dgrs
samsung fridge freezer problem
samsung dity help on youtube ">
Dec 29, 2010 | Microwave Ovens
Arcing from the metal plate on the right side of the oven when anything solid is place in it - such as frozen foods or a cold stick of oleo or frozen biscuit. Goes off when I open the door.
That metal plate is probably the waveguide cover. It is made of Mica and must be kept clean otherwise it will arc and burn. The reason it arcs more when solid/frozen food are placed in the oven is because solid/frozen foods do not absorb as much energy as wet foods.
Replace it if it is burnt.
Dec 20, 2010 | GE Microwave Ovens
I need instructions for the Bond Helman, (Personalized Products) Defrost Master 2000 Model # DM-02000. Can you please tell me where I can find the instructions for the defrost master?
Margi_smigie to use your Defrost Maagic 2000 just put hot water in the bottom pan, place frozen food on top and it will defrost. Turn over about half way through. Good luck. I have the mailing address for the company. jellybeanone@verizon.net if you have any questions.
Aug 31, 2010 | Microwave Ovens
I have a GE Profile JVM1790 microwave that needs to be installed. However, it will sit in front of a 3/4" thick granite backsplash that I would rather not drill holes through. Would it be safe to mount...
The front weight hangs from the cabinet above the microwave, the rear weight needs support also. It is intended to be fastened to two studs. If the granite does not go all the way up to the cabinet above, install a wood spacer, the same thickness as the granite, then extend the wall plate, at the corners, with some flat stock aluminum strips, available at most hardware stores. Fasten the aluminum strips to to wall plate with short machine screws. - If the granite goes up to the cabinet bottom, shim out the bottom frame of the cabinet to the face of the granite and use the same aluminum flat stock to extend the wall plate up to the necessary location.
Jul 06, 2009 | Microwave Ovens
Microwave Ovens Logo
191 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
