Question about Pioneer SX-205 Receiver
Ive got a pioneer sx2o5 rds a cupla weeks ago i was using it wen it suddenly switched off i opened it up and seen a glass fuse inside by the power button side was burnt out i covered the fuse with tin foil 2 c if it wud work temporarily it turnd on for a few seconds then then went off exactly the same way as b4 i also noticed smoke coming from the centre of the amp i managd to replace the glass fuse and wen i turn it on it keeps saying overload then turns it self off then bk on repeating the process ive looked inside and there is a pair of 2 prongd white chips in the centre of the board 1 of them looks burnt and is crackd im wondering if this is the problem or what it mite b and wat i can do to repair it and wer i can get the parts in bristol thanks luke
5 Suggested Answers
nfandres
  • 168 Answers
SOURCE: overload
well based on the specification of the unit u can use only 100 Watts x 2 for stereo and 100 Watts x 5 for surround. but u used 250 Watts x 2, this alone will overload the system. u may have blown the power amplifier ic/transistor not the fuse, otherwise there will be no display at all.
Posted on Feb 02, 2007
SOURCE: pioneer vsx-d511 amp error
I've had the same problem for over a month and have yet to find the time to get to it. However, I there may be a fuse on the circuit board that needs to be replace. That's just my guess.
Hope it's the solution.
Posted on Sep 17, 2008
smarthome2
  • 1114 Answers
SOURCE: i turn on my Pioneer VSX-D509S 5.1 surround amp
Disconnect all your speaker wires from the back of the receiver and turn it back on. If it shuts off, you need to have it serviced. If not post a comment and I can walk you thru troubleshooting. Hope this helps
Posted on Jun 24, 2009
caroldon
  • 17130 Answers
SOURCE: My pioneer vsx-519V-k amp won't turn on. Just
Have you checked within the set, the fuse and if the standby circuit is working. thre could be a failure of this sub votage which is required for the switch on of the main power. If you do not have any standby indication you must check this section, however if you arre getting the standby you would have a failed output or a shorting that is triggering the error amp to swtich off. If you are familiar with the circuits you can check but I would suggest that since you will need more experience to look into the main board for tracing the fault. In such case check for the service centre nearest to the place you are in using a google search for Pioneer - Audio systems- sevice. Helpful I hope. Good day.
Posted on Jul 06, 2010
Is it possible to change the fuse in a sewing machine?
the only fuses ive ever seen inside a sewing machine was located inside the foot switch assembly and ive taken apart a few dozen now , but now ive seen quite a few broken power cords and sockets in that few dozen , seems the power cords sure take a beating on these ?
Jan 14, 2016 | Sewing Machines
I have a bush AE56DW oven bottom oven was working, but now only the fan works and there is no lights or heat coming out?
have the very same problem on my bush stove though have just found the problem out, on the oven switch looking inside has all the wires but what hidden and needs taking out it s fuse near the knob and cannot be seen until taken out and your see this thermal fuse blown this stops all power to inside stove light no power then to thermostat oven temp everythings dead,
ive tested everything untill ive looked at replacment parts and then your shown a fuse of 240 vol when do they put this in such a place clear to have use all have to call out an engineer, ive beaten the system
Apr 05, 2014 | Ovens
Hi ive knocked a large glass of drink over mixer.do u have any tips.its a djm 500.theres no sound and its doing all sorts of crazy things.like chanels round wrong way etc etc`ive tried to dry it out.it...
What was the drink?. If is was something like coke then it's going to need a full strip and clean as coke is very corrosive.
If it was plain water then I'd still strip it and put it somewhere warm for a couple of weeks to ensure it's REALLY dry before using it further.
You might need some new faders / switches etc depending on the severity of the spill.
http://stores.ebay.co.uk/methleykev
May 19, 2010 | Pioneer DJM-600 Silver Professional DJ...
Had to change p/supply installed new 680w apower reinstalled powered up fine shut down moved to where pc would sit plugged in and nothing pulled apart again checked connects powered up fine shut down and...
you could open up the power supply and look for any fuses that may have blown, the ones ive seen are the glass type and are cheap to replace and easy to find at radio shack just take the blown fuse with you and replace with the exact amps. and make sure that everything is unplugged from the wall and be very cautious around the large cylinders inside the power supply aka "capacitors" they can hold a residual charge and WILL harm you
Jan 13, 2010 | EliteGroup GF7050VT-M Motherboard
I have a mark 3, Y reg seat ibiza 1.4s,with an array of wierd electical problems. the radio keeps turning itself on, even when the car's ignition is off, the keys out, and the doors locked. It flattened my...
Ive got the radio problem, having to remove the radio fuse each time I get out of the car - its the blue 15amp on the top row of the fuse board. As for fixing it, heard its either down to the radio switch or diode? Taking mine to garage though.
Jan 09, 2010 | 2001 Volkswagen Golf
Pioneer avh-p7500 switch live
i dont know too much about these, but what i do know is, most of these units have a small 1 amp continuous blow glass fuse inside the unit, i would have a look to see if yours has it, and also look for any signs of over-heating on the PCB
Aug 13, 2009 | Pioneer AVH-P7500 Car DVD Player
NAD 304 AMP...No Sound at all on both channels, Black marks on inner case.
This may be a silly question, but the pre-out/main-in jumpers are installed, yes?
Sep 25, 2008 | Audio Players & Recorders
No power in my Daewoo Monitor
Hi, Youo have zeroed in on the problem area. It looks like a power supply problem. More often than not, there is a fuse inside. If you would venture to open the unit up, do a visual check on the fuse. If it is busted: 1. Clean - no burnt/scorching/black marks inside the glass tube, then you can simply replace and hopefully the unit will be operational; 2. Dark smudges - or small burnt metal pellets inside the glass tube, then it is possible that you have other defective components that caused the fuse to blow. Normal components that are known to go bad are the big capacitor and or the power transistor regulator. Most current designs uses a switch mode power supply where your mains AC voltage is converted to DC that powers a circuit that eventually produces a lower DC voltage say 12VDC for use of the monitor. Should you venture a DIY (do-it-yourself), pls remember safety precautions when working with powered electronics. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Sep 25, 2007 | Daewoo F227B Monitor
Pioneer DEH-PB40MP No Power
hey, indeed this sounds like a couple of fuses gone bad. I dont know this accurate model, but it shouldnt work any diffrent. Anyway, with the stereo UNPLUGGED remove the covers and inspect inside, especially in the vicinity of the power transformer. The fuses may be glass cylinders with metal caps. There are other types, but the only ones you should probably try to mess with are the glass type, usually about 5/8" long by 1/8" wide. They should ONLY be replaced with the same type. Somewhere on the cap will read something like 3A, 4A, etc. This is the ampere rating. Replace only with same rating. It is foolish and dangerous to just go out and grab whatever fuse is laying in your car's glove-box, for example. There may be a couple fuses. As I said, there are other types of fusible devices, but they would require a tester and some limited knowledge of electronics to test. The glass-bodied fuses can usually be seen to be either good or bad by looking at the filament inside.
Mar 18, 2006 | Pioneer DEH-P840MP CD Player
Pioneer SX-205 Receiver Logo
78 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
