Question about Fitnex T30 Treadmill
My treadmill t-30 keeps on posting error 7. I can't find my manual, so what does this mean? Thanks!
For the Fitnex T30 treadmill, the error 7 (listed err7 on the display) code means that there is a fault with the incline motor. My problem was the incline motor had burned out probably from usage, and during my research, this seems to be a weakness for the T30 model. You can remove the front plastic cover, unscrewing the 4 phillips head screws to reveal the electronics board, belt motor, and incline motor. With the power on (do not touch the board or wires 'cuz you could be electrocuted) check the board located next to the power switch. If the board's two lights are lit green, then your incline motor has probably ceased to live. Just in case, make sure to check with a flashlight, all those capacitors. One of them could have blown out and I'm not sure whether the green lights would indicate that. If one is blown the cylinder end will be bulged as if the cylinder 'popped'. You can see that the cylinders are stamped with a plus-sign. This is a built-in weakspot to allow an 'explosion' to puff out that plus-sign stamp. It will be fairly obvious if one has kaboomed. Make sure the wires are intact as well. Use a dustsprayer to blast all the grime and dust off the board and wires and motors. If all looks good, it's probably your incline motor itself that has gone kaput. Now let's get that motor out! Turn off the power and remove the power pIug from the outlet! First, I removed the grounding screw (green wire), unplugged the 4 prong main switch and 3 prong secondary switch from the motherboard that connect to the incline motor. [Just a footnote, inspect the connections of those wires into the incline motor just to be sure. If all is well, continue motor removal]. Next, use wrenches to remove the top nut and bolt securing the incline motor. Then, gently tip the entire treadmill on its side and do the same to remove the nut and bolt from the incline bar across the bottom of the treadmill. Now flip the treadmill rightside up. Remove the incline motor. I ordered the same motor, used and rebuilt, from sbarker (Ebay id), sbarker10 (Amazon id) for $54, shipping included. You're not going to get a better deal than that. A new replacement motor from a exercise equipment store online wanted $200 which is just not worth it. From order to arrival, took 4 days. Follow the same procedure in reverse order to install your new motor. Everything should work fine. If you're still getting the error than there must be a wiring issue between your board and the incline motor, or the board itself is faulty, but then that's beyond my knowledge of this particular problem. Don't worry though, with what I've found, the incline motors are poo-built, so if you're getting this error in the first place, I'd bet the farm it's a burnt incline motor. Good luck
Posted on Jul 28, 2011
What does error code R5232 Failed mean on Vision Fitness T9600HRT treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 04, 2016 | Vision Fitness Exercise & Fitness
I have a fuel fitness tread FT94 and an errow code keeps coming up E6. What does this code mean and how can it be fixed ? tread mill will not start up
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.Check for treadmill error code
Mar 08, 2016 | Exercise & Fitness
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
Error E6 on Healthstream treadmill
Mar 16, 2012 | Exercise & Fitness
E5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Nov 24, 2011 | Exercise & Fitness
MESSAGE "ERROR SPEED STALL" KEEPS COMING UP
returned the machine and got our money back, thanks.
Jun 20, 2009 | Bowflex Treadmill Series 7
Hi, have lost the manual for my treadmill York T500 treadmill. Error 7 keeps coming up...what does this mean please?
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
Apr 20, 2009 | York Barbell Home Use Fold-Up Treadmill
Fitnex T30 Treadmill Logo
156 people viewed this question
Top Fitnex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Fitnex Exercise and Fitnes Expert? Answer questions, earn points and help others
