Question about Trendnet TEW 652BRP Wireless N Home Router (710931600599)
I've changed from Windows XP to Windows Vista and
  • Trendnet Master
  • 7,733 Answers
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Posted on May 19, 2011
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
Upgrading windows vista to windows xp in presario 115DX
You cannot 'upgrade' Windows Vista to Windows XP - that is technically a 'downgrade' and would need you to save all your user data on Vista then format you Windows drive then do a clean install of Windows XP.
If you try to install XP over the top of Vista you will have lots of problems because of the difference in architecture and boot manager changes.
The only alternative would be to set up a dual-boot installation where you install XP alongside Vista but would be best done on either a separate disk partition or on a second disk. Normally such a dual-boot configuration would start with having XP installed then adding Vista as the second operating system.
Jan 11, 2012 | Compaq Presario CQ56-115DX Laptop
I've been at this all day and still have'nt gotten my laptop to reset to a factory default setting. Can you please guide me through this process, step by step. Thankyou.
You can always restore the computer to a point when it was working fine.
For a laptop when you say factory defaults we've two things
1)Factory defaults on the Bios - as soon as u turn on the laptop we press F8 key or DEL(depends on the brand of the laptop) to get to the BIOS and you've an option to revert to the factory defaults.
It is advisable not touch the BIOS if you are not sure about this firmware
2)The operating system (lik windows xp,vista & 7) there is nothing called factory defaults for this all we've is a installation of the Operating system itself. However we can revert or restore back to last know good configuration mode.
How to start your computer by using the Last Known Good Configuration feature To start your computer by using the Last Known Good Configuration feature, follow these steps:
  1. Start your computer.
  2. When you see the "Please select the operating system to start" message, press the F8 key.
  3. When the Windows Advanced Options menu appears, use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then press ENTER.
  4. If you are running other operating systems on your computer, use the ARROW keys to select Microsoft Windows XP, and then press ENTER
Aug 18, 2011 | Computers & Internet
Cannot connect to internet router is working properly it is connected to my regular computer but cannnot get singal for my notebook
Hello, bevybuns5!
First thing, make sure your WLAN card is turned on, however, without knowing your specific laptop model, I can't help locate it for you. After that, check your router's wireless security code, and assure that you're entering it correctly. Then, if you still aren't able to connect, try manually unplugging the ethernet cable from your PC, then plug the Ethernet cable into the laptop. If you get a signal, skip to the third paragraph, if not then read the next paragraph.
If you aren't getting a physical connection, it could indicate that there is something wrong with some type of software, or operating system settings that aren't allowing you to connect to the internet (leave the network cable plugged in for troubleshooting). Try checking firewall settings (windows firewall is infamous for blocking almost all connections at will). Then, if you're using windows xp, go to the start menu, open the run command, and type "CMD" without quotes (if you're using Vista or Win7, then just type CMD in the search box at the start menu. When the command prompt screen appears, enter this text without quotes "ipconfig /all". If you have an IP address, subnet gateway, and IPv4 configuration, then you're ready for the next step (if not, let me know in a comment, and I'll leave the instructions for that solution). If you're using xp, then right click computer, click properties, go to the hardware tab, then click "Device Manager" (for Vista/Win7, just type Device Manager in the start menu search box). Scroll down (if you have to) to Network, click on it, find your physical network card, right click and uninstall it (don't worry, this won't hurt anything). Wait for a few moments, then right click anywhere in the Device Manager window, then select "scan for new hardware". This will find the NIC you just uninstalled, and reinstall it (with original drivers, unless you've upgraded your Operating System, then you'll have to get the drivers from the manufacturers website via your desktop). Reboot the laptop, and try connecting with the LAN cable again. If this solution doesn't work, leave me a comment describing what you've done, and any error messages that have come up.
If you recieve a signal from the LAN cable, and still cannot connect via the wireless card, then back into device manager we go! For xp users, go to the Start Menu > right click Computer > click Properties > go to the Hardware tab > then click Device Manager. For Vista/Win7 users, open the Start Menu, then type Device Manager. Scroll down and find your wireless card, and if you've tried the solution in the second paragraph, you know what we're gonna do. Right click it, Uninstall the wireless card, wait for a few moments, then right-click anywhere in the Device Manager screen, and select Scan for New Hardware. Reboot the system, and you should be working!
Aug 02, 2011 | Computers & Internet
I just bought this asus K42F series and I cannot connect to the wifi here in our house. the wifi is functioning properly because my friend's laptop was able to connect to the same wifi. and my asus...
Change Your Wireless Channel
If you're using a Linksys router, you'll need to browse to the address of your router, which is probably set to http://192.168.1.1 but could be assigned to another address. You can run a quick ipconfig command at the command prompt to check:
In my case the address is different (because I changed it, of course), but what you're looking for is the Default Gateway for your Wireless connection, and then go to http:// in your browser. Enter in the password that you hopefully remember, and head to the Wireless -> Basic Wireless Settings tab.
My router has two separate bands, but your router might just have a single band here. In my case, what I've done is set the 2.4 GHz band to only be used for Wireless-G, and the 5GHz one to Wireless-N only. Since I'm not having any problems with the Wireless-N settings, I've left those on auto.
Where I am having a problem, however, is my Wireless-G devices-so what I've done is chosen channel 9, since it's the only channel that's not being used by any of my neighbors, who are using mostly channels 1 and 6, though a few are using 11 as well.
Channels 1, 6, and 11 are the most common channels to choose, and most routers will use one of them as the default channel-but the general idea is to be as far away from everybody else as you can.
Note: I've also configured my router for 20 MHz only on the 2.4 GHz Wireless-G band, just because that was the only way it would let me choose the standard channel manually.
If you are using a different router, the IP address will generally be the same, but you'll have to figure out how to change the Wireless channel without any screenshot tours. It's usually fairly easy, though, once you know what you're looking for.
Fun Technical notes
Jul 18, 2011 | ASUS K42F A1 Notebook
I cannot connect to the WIFI at work, but I can connect to my WIFI network at home, and other public networks. The wireless network at work is pushed by a D-Link 8200AP with a WAP security, just like it is...
Your laptop cannot connect to your work's wireless network because the security settings (ir WAP) in the D-Link is different to the security setting in your Netgear.
The wireless card in your laptop will need the settings changed to suit the D-Link's wireless settings ie the SSID and WAP.
You will need to change the wireless card settings in your laptop back to the Netgear's wireless settings to connect to your wireless network at home.
Some wireless cards allow you to set up different profiles for different wireless networks which allow you to switch wireless networks easily by just selecting the profile for the network you want to connect to.
Jun 25, 2011 | Apple iBook G3 Mac Notebook
I have drivers for windows vista but they can not be installed on windows 7. I need install my router on windows 7
If you have the Windows Vista or Windows XP driver, try installing in Compatibility Mode. Here's a tutorial I've posted recently (click HERE.), but please select Windows Vista instead of Windows XP. There isn't problem even if you select Windows xp, but since it's windows vista driver, that should work perfectly.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 26, 2011 | Linksys Wireless-G WRT54G Router
My laptop is hp pavilion dv2500 notebook pc. I ve changed vista to xp. but after installation of Xp Professional i didnt do anything . but my sound, internet, wireless, blutooth..etc not working. i think...
Hi, you can download the drivers here from hp, select your model number and download the the drivers for Windows XP, either 32 or 64 bit installations.
Apr 15, 2011 | HP Computers & Internet
How to connect Linksys WRT150N to laptop on DSL
Click the link below for proper cable connections in setting up your wireless network.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Good Luck!
Thanks.
Mongkey
"Understanding explains better..."
Jan 18, 2011 | Linksys Wireless-N WRT150N Router
Wireless Adapter
Are you sure that you installed the windows xp drivers and not the vista drivers? There may be no xp drivers for your laptop, and if thats the case, you'll have to switch back to vista. Make sure you know 100% that its the xp drivers.
Sep 18, 2007 | Acer (D10709-002) (D10709002) 802.11g/b...
Trendnet TEW 652BRP Wireless N Home Router (710931600599) Logo
80 people viewed this question
Top Trendnet Computers & Internet Experts
David Payne
David Payne
Lynne
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
