Have refurbished Dell Optiplex gx280. Plugged Dynex VGA display cable in & got nothing. Still only seeing the Dell Digital Input Self Test Feature Check bounce around the screen, as if the computer is not communicating with the monitor. Tried plugging the cable into Toshiba laptop & still no communication to Dell monitor. Suggestions?
    President:
  • 1,607 Answers
Hi!
If you are able to use a known good monitor with Dell Optiplex GX280, obviously the problem is with the monitor. If you only have one monitor, try to reseat the cable from the monitor going to the blue port if its analog (white port if its digital). if it does the same thing tried to open the chassis then reseat the video card (check this site for the instruction for the manual, http://support.dell.com/support/edocs/systems/opgx280/en/ug/index.htm)
if you still dont get anything on the screen, most likely the problem would be the video card.
If you tried to connect the monitor to a laptop make sure to toggle it using FN and F8. Toggle it three times and observe if you'll be able to see display either on one screen or both. if you're able to see something on the laptop and nothing on the monitor then its a problem with the monitor.
Hope this helps!
Posted on May 19, 2011
On dell 2405fpw, the screen just went black. Unable to select VGA input. Unable to perform self test.
You need to power cycle your LCD moniter, and then disconnect the display cable of your LCD from your system and see if yor LCD is doing the self test, if that is passing the self test that means there is nothing wrong with your LCD you need to check your system espeacially display adaptor and the drivers, you can also cross check if you have any other monuiter at home.
If your LCD moniter does not pass the self test then it means it has crashed you need to get it repaired or get the new one.
Aug 25, 2011 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
I want to connect my dell optiplex gx 280 desktop computer to my sony television, my tv manual says i can connect my computer to a port which i can easily locate on the television but i have a problem...
Every Sony LCD TV comes with VGA port (15 pin D-Sub connector) assuming you have LCD T. You can connect your monitor cable to this port & select the input on TV from the menu.
sonsunny
Jun 15, 2011 | Dell OptiPlex GX280 PC Desktop
I am looking for a schematic for a Dell Optiplex GX280 power supply. The supply is model HP-U2106F3.
I just replaced my GX280 power supply (mini-tower) with the following 400W for $30.
http://www.cputopia.com/hp-400w-dell-optiplex-gx280-mini-tower.html
The only place I can think you will find an actual schematic for the PSU is from the manufacturer.
Feb 13, 2011 | Hi-Pro Refurbished HIPRO POWER SUPPLY FOR...
Where can i get software download for VGA compatible for dell optiplex GX280?
Please visit:-
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid&SystemID=PLX_GX280
Good luck & happy computing!
Mar 05, 2010 | Dell Optiplex GX280 (99301) Motherboard
Hook vga cord to hdtv and optiplex desk top get
Try a different display setting, for example, 1280 x 800 or 1024 x 768. Once you can see (computer) display, then move onto the best resolution which your display card support for your HDTV. Good luck..
(btw, if your dell has two vga sockets, get another vga cable. Then set your computer to a dual display mode, one for your computer and the other for HDTV. this way you will never lose your display.)
Dec 09, 2009 | Dell Computers & Internet
Plugged a different computer into a working monitor and get nothing but screen filled with pixwls or dashes
Is the monitor connector VGA by any chance? Check that none of the pins where you plug the cable into the PC are bent. If none are bent, ensure the graphics card is seated correctly. Loose graphics cards can cause garbled display. Try unplug the graphics card, unseat from the motherboard and re-seat.
Sep 30, 2009 | Dell OptiPlex GX280 PC Desktop
Nothing came on monitor after switch on, all 4
Can you supply any more information?
All I can suggest with the information provided is to check that the monitor is plugged in and switched on and that the monitor is plugged into the computer with a VGA cable (try to avoid using a VGA-DVI cable adapter until you know everything works).
Jul 02, 2009 | Dell OptiPlex GX280 PC Desktop
Nothing comes up on the screen
The monitor connected to the system is set to receive video signals from the DVI port on the video card and it is not getting a signal.
Possible Causes:
  1. Monitor is connected via VGA (Blue Connector). Fix by using the input select button to select DVI input)
  2. The video cable is not connected to the correct port on the system (Or not connected at all)
  3. The monitor is on, but the tower is not powering on or failing to complete the Power On Self-Test (POST). It the power LED on the tower is NOT on, or solid or flashing Amber then the tower is not posting. Flashing amber is normally a bad power supply, solid amber is the motherboard.
Mar 01, 2009 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
