Question about Cycling
CAN it be tightend up . made stiffer? - Cycling
  • 2,334 Answers
Make clear what you want to do. Make, model, e.t.c.?
Posted on May 19, 2011
2000 gmc jimmy steering is getting stiffer. The power steering pump does't make any unusual sounds and the oil looks good. Recently had 4 new ball joints,idler arm and pitman arm installed. The vehicle has...
Hi and welcome to FixYa!
The new under chassis parts installed can cause the steering to be a little stiffer. It is normal and it tends to go soft when the ball joints gets pressed.
Hope this helps and thank you for using FixYa! Have a good one!
Mar 18, 2011 | 2000 GMC Jimmy
I replaced the front shocks the front is still very bouncy
trey a set of genuine mercedes europeon spec shockers as they will be a lot stiffer as these vehicles are different in little things like this to our europeon versions which have stiffer shocks as us europeons do not like bouncy vehicles
Mar 07, 2011 | 2004 Dodge Sprinter
Adjusting twin cam back shocks the best setting
There is no single "best setting". It depends on you and your riding style. Heavier riders sometimes need a stiffer suspension. Same goes with those that do a lot of "Two Up" riding. Some riders seem to prefer a stiffer suspension because of their riding style. While others want the nice soft ride. The adjustment of the shocks is a personal type adjustment. Just try different positions under different conditions until you find the best for you.
Good Luck
steve
Nov 09, 2010 | 2001 Harley Davidson FXDL Dyna Low Rider
Shock absorrber bolt had to be tightend last rear
There is a rubber grommet that has broken. Take to a shop as those can do a lot of damage.
Mar 24, 2010 | 1997 Buick Skylark
When carrying passengers my 2007 nissan quest rear suspension bottoms out even on small dips, any suggestions
get stiffer springs or install air shocks you might even want to check into airbags because 2007 is not that old that it should be needing springs already must be weak factory setup. if you carry lots of passengers get stiffer springs.
Jan 07, 2010 | 2004 Nissan Quest
The dial on my washing machine is getting stiffer
its usually gunked up behind the dial thats causing friction... usually removal of the dial and cleaning will help...
Dec 18, 2009 | Hotpoint Aquarius WD63 Front Load...
How do you stiffin the rear shocks on a 2002 honda shadow?
Not positive about this bike... I have an older bike that has a step positioner that requires a special tool (you can use a pair of channel-locks). The higher you go the stiffer the ride the lower you got less tension on the spring, so the easier the ride. New bikes (like yours) sometimes have a nitrogen filled assist canister with a flat head screw. That flat head screw should have an arrow pointing in both right and left directions, on one end is a pos. (+) symbol and the other is a minus (-). Turn toward the pos for a stiffer ride, toward the min a softer ride!!
Good Luck
Jun 16, 2009 | 2002 Honda VT 1100 C Shadow Spirit
1994 sl1 saturn burning oil
Sound like you solver that problem...your the champ.
Jun 07, 2009 | 1994 Saturn Sl
85 cj 7
You said stock height, does that mean you have stock suspension aswell? If I were you I would install stiffer shocks all the way around and add or replace the stock front stabilizer bar with a stiffer one. You may also consider installing more rigid leaf springs in the rear.
Hope this helps
Sep 10, 2008 | 1983 Jeep CJ7
Cycling Logo
24 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
