Question about Canon PIXMA MP150 All-In-One InkJet Printer
How to error e5 how to go to service mode - Canon PIXMA MP150 All-In-One InkJet Printer
    Novelist:
  • 125 Answers
Hum....e5 error.
The truth is...there is no solution for e5 error.
U may see some solutions through web, however, non of them works..
The only way you can get out of e5 error, replace with new cartridge..
or...
prevent it...before you face it!!
How?
Whenever you take out the cartridge from printer, make sure unplug the power code first..
and then take and refill or whatever...
And then when you put it back....do it when power code is unplugged as well.
Personally, I refilled and used CL831 more than 8 times..
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Posted on May 19, 2011
Testimonial: "thanks, very helpful"
    Problem Solver:
  • 19 Answers
E5 means your cartridge error. May I know are you using original ink cartridge or yours has been modified before?
I assume you to refill your ink cartridge before because E5 error won't appear after replacing new cartridge.
So, you need to take out both of your ink cartridge and then use a clean cloth to wipe them. After that, slowly put in back into the printer. If the error is still there after wiping it, try to do it till the error is gone.
I had tested this way with my own printer and it works again without needed to buy a new ink cartridge.
All the best and good luck =)
Posted on May 22, 2011
  • sunandjoon
    sunandjoon May 26, 2011
    e5 error is related to circuit part.....Even if you wipe out the cartridge hundred times.... it won't change at all..
    The most important thing is prevent before it happens...
  • jili May 28, 2011
    I had tested it with my own printer and cartridges but it work out fine. I think you should try before saying it couldnt work.
Error code e5
Hi friend, I appreciate your post!
I understand that your Electrolux refrigerator is showing an "E5" error code and not cooling. "E5" typically stands for Showroom mode, you can press and hold the "Up" and "Down" keys simultaneously and that should restart your refrigerator back to normal operation. Could you reply back if that corrected the issue? Thank you. -Matt
Jul 27, 2014 | Electrolux Refrigerators
E5-42
E5- 42 Total Counter connection
1. Total Counter connector is disconnected.
2. Total Counter is defective.
3. DRV PCB connector is disconnected.
4. DRV PCB is defective.
Testing in Service Mode, under F4:
062 When CN768-5 signal level changes
to 0V from +24V, counter operates for 100ms.
Dec 19, 2013 | Panasonic DP-8045 Grayscale Copier
Maytag neptune error message e5
This normally indicates that the thermistor is bad. Try measuring it to prove it is OK. It should be 10K Ohms at room temperature (20C / 68F).
If necessary, replace it then clear the error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Sep 06, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
What I do when I Canon PIXMA MP 150 shows E5
Hi there
Canon printers MP 160 AND MAYBE OTHERS
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
May 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Conon mp160 e5 error
it.
procedure:
button pressing
the "service mode"
Try it
it.
Apr 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Cod E5
Hello there
it.
procedure:
button pressing
the "service mode"
Try it
it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 13, 2010 | Office Equipment & Supplies
Mp140 shows E5, 2 114,0
Hi there With most ( E ) errors
it.
procedure:
button pressing
the "service mode"
Try it
it.
Feb 27, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
I Installed new ink Cartridges in my canoa MP160 Printer
Hi there
it.
procedure:
button pressing
the "service mode"
Try it
it.
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
What is e5 error
E5 error code occurs in certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
Feb 25, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Maytag neptune has error code e5
What does an e5 error code mean?
Feb 22, 2010 | Maytag Dryers
Canon PIXMA MP150 All-In-One InkJet Printer Logo
1,808 people viewed this question
old marine
old marine
