I need to change my BIOS to make my CD-ROM or DVD-ROM to be first in the boot sequence order. How do I access my BIOS to change them
    Problem Solver:
  • 17 Answers
When you turn the power on press F10 until you enter the bios screen (usually blue)
if F10 does not work try the other "F" keys (F1, F2, etc.) different PC's have different buttons but its usually an "F" button
Posted on May 19, 2011
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
How to restore system
im assuming you have the recovery disk
Restart the computer and press the pause/break key on the keyboard.
This key will slow down the boot process and allow you to see the motherboard BIOS access key that you'll need to press in order to access the motherboard BIOS.
Press the respective motherboard access key and check the motherboard BIOS for a boot sequence.
Change the settings in the boot sequence so the primary boot device or the first boot drive is the CD-ROM or DVD-ROM drive.
Insert the system recovery disc into the disc drive.
Restart the computer and allow it to boot up before doing anything.
A black screen should show up with the words Press any key to boot from disc CD/DVD.
Press a key to have the system boot from the recovery disc.
Allow the system to load.
Follow the on-screen instructions on how to install the rest of the operating system.
There are many different settings for you to choose.
If the operating system is just a little out of whack, you can choose to repair it.
The system recovery disc will contain important drivers and software for all the components connected to the computer system.
If you do not have a system restore disc you can search the Internet for drivers and software that are packaged for your specific eMachines model.
Restore the BIOS to their default settings so the hard drive is primary boot sequence.
This is an optional step.
You can leave the CD-ROM drive as the primary boot drive, but it will slow down the startup process by a few seconds.
hope this helps
Sep 30, 2012 | E-Machines W3503 PC Desktop
I have acer aspire 3000+ and cant change bios setup to boot first from cd rom and erecovery doesnt work
Why can't you change the bios setup to change the boot order or boot sequence?
Also you can change the boot order or boot sequence temporarily by just rebooting the laptop then watch the screen for which key it says to hit to change the boot sequence or boot order, then hit that key when you see the message.
May 08, 2012 | Computers & Internet
I tried to install windows 7 on my HP Pavillion DV9, but it's not booting from CD-ROM, i tried using a USB CD-ROM, but it's still not booting. pls I need assistance.
Try to check if the windows 7 disc that you are using is not just an upgrade disc. Make sure that it is a bootable disc. Try to use other bootable disc to test. Also make sure that the boot device priority is set CD/DVD drive.
Hope this helps.
Jun 06, 2011 | Computers & Internet
How can i boot my dell studio from cdrom so i can reinsall from external drive?
Turn on the machine, press F12 once the Dell splash screen is displayed, the boot menu will show up. From the Boot Menu, use up-down arrow keys on the keyboard and highlight the CD/DVD/CD-RW and press Enter.You will see another menu, select "Boot from Cd-Rom" and press enter to select it. The system will boot up from the CD-Rom. Please note that this settings is only for one time boot, once the system is restarted, the boot sequence will be restored to the previous saved settings. If you wish to set it from the Bios, enter the Bios settings by hitting F2 or Delete (should be shown at the bottom of the Dell splash screen) while you see the Dell Splash Screen. In the Bios settings menu, go to Boot options and make the changes with the boot sequence.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 21, 2011 | Computers & Internet
Dell demension 8300 pc
make sure boot sequence is cd-rom first and possibly disable hd
Jun 22, 2009 | Dell Dimension 8300 PC Desktop
Dell b130 upgrade to new hard drive trying to boot of from cd-rom but wont..... need help
did you change the order in the bios setinbg?put the 1st device for boot to be the CD/DVD-rom not HARD drive, to get into bios try F2., ESC, ,F12 . and in the bios setup change the order put 1st boot device to be CD/DVD-rom, then try again to setup Windows.
Mar 13, 2009 | Dell Inspiron B130 Notebook
I have a dell inspiron b 130 and my cd rom was pulled out by my son i wanted to know how can i boot my computer from the new cd dvd rom i need to format my laptop
you can configure it on the bios settings of the unit itself (possibly F2 or F11)
Then go to boot sequence then look for the removable device.
Then save your settings and restart your laptop. It should be working now.
Feb 26, 2009 | Dell Inspiron 8200 Notebook
How do I Access BIOS screen in a IBM PII-6862-84U?
As the computer boots press the DEL key to access BIOS
note: some systems you must press F2 or Esc
In BIOS under the BOOT tab options change the Boot order so that the CD drive is First
Select EXIT and Save Changes to reboot
note: make sure the CD is in the drive BEFORE you reboot!
(it sounds obvious but a lot of people forget)
If the CD is bootable it will start its own boot sequence.
Feb 21, 2009 | IBM I System Board (61H2600) Motherboard
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
David Payne
David Payne
