Question about Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW 4PORT MANAGED SWITCH
I have a error code # 51031. I'm unable to find a
  • Netopia Master
  • 7,733 Answers
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Posted on May 19, 2011
I can't get connected to Netflix.All that pops up is error code 51031
This problem is usually associated with trying to connect a Wii game console to Netflix. If this is the problem you are experiencing go to this site and you'll find the answer on how to connect your console.
http://www.nintendo.com/consumer/systems/wii/es_na/windows/error51030.jsp
Dec 30, 2014 | Netflix
Tip
Nintendo Wii Error Code 51031 This error code means that the wireless network...
<span>Nintendo Wii Error Code 51031</span><br /><br /><span>This error code means that the wireless network within range is not configured or is not compatible with your Nintendo Wii.</span><br /><br />-Make sure the router you are using is compatible. You can see a list of compatible routers by clicking <a href="http://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp">here</a><br /><br />-Make sure the SSID(network name) you enter into the Wii settings matches the SSID of your router. This includes making sure capitalization, spaces, or special characters match exactly.<br /><br />You can log in to your router by going to the gateway address of the router(usually 192.168.1.1 and type this into your internet browser), and going into the wireless settings section. Check what the SSID is. This is what you should set on the WII.<br /><br />You can view my tech article on connecting and changing Wii network settings by clicking <a href="http://www.fixya.com/support/r9198848-connect_nintendo_wii_internet">here</a><br /><br />-In your home network, your router may not be assigning an IP address to your Wii console. Power cycle the equipment. Turn off all devices(modem, router and Wii). After 10 seconds turn on the modem, after 30 seconds turn on the router and after 30 seconds turn on the Wii. Try to connect online.<br /><br />If you are not using DCHP but instead have your home network setup to assign a IP address manually, you will need to setup the Wii with the IP/DNS addresses. You can set your manual settings in the Wii network settings menu. See the link above to my tech article.<br /><br />-Your router firmware may need to be upgraded. Visit your router manufacturers website and see if any updates are available.<br /><br />If after all the above steps you are still having trouble, you may want to reach out to Nintendo Technical Support at 800-255-3700<br /><br />I hope this article was informative!<br /><br />-G33k<br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /><span style="font-weight: bold;">Nintendo Wii Error Code 51031, Error Code 51031, Wii 51031</span>
on May 25, 2011 | Nintendo Wii Console
Why can't I connect to Netflix?
Your not connected to the Internet!
What is error code 51031 on the wii
Error Code 51030, 51031, 51032
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
Nov 26, 2011 | Nintendo Wii Console
Error 51031
Welcome to Fixya. To fix the error 51031 please follow the steps on the link below
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51031&system=Wii&locale=lang
Thanks for using Fixya.
Sep 27, 2011 | Nintendo Wii Console
I get error code 51031 unable to find access point. What do I do?
The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
Check for interference that may be preventing a successful connection.
Check to see if the router you are using is a known to be incompatible.
I recommend using a different router if possible.
Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
Login to your router's settings,
Look for the section for SSID (typically in the "wireless settings" area).
After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necessary to get the connection to work properly.
The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary.
Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufactruer's website; consult the manufacturer for more information.
Jul 02, 2011 | Nintendo Wii Console
How do I set up the Wii to the internet?I keep getting error code 51031
Hi.
That error code is usually linked to your Wii's MAC address not being added to the MAC accepted list on your router.
To do this it depends on what router you have, but for most, you can have a direct link from your computer to your router.
Open a internet browser and go to (192.168.0.1)
On most routers this will be its set up page, you have to go to the wireless page and add your Wii's MAC # in there.
Your Wii's MAC address is located in the 'Console information' Wii page
You should just do this after your done....
1) Power on your Wii, go to the settings menu (by clicking the little Wii button in the channel menu)
2) Scroll over to 'internet settings'
3) Select 'connections', and pick 1, 2, or 3
4) In there select 'search for wireless access point'
5) Pick your router, enter your key (password) for your router if you have one.
6) Test the connection
Regards.
Jun 08, 2011 | Nintendo Video Game Consoles & Games
This error means that the router within range is not compatible or not configured properly. Please see my tech article I wrote by clicking below, It will go over the steps needed to fix this issue.
Error Code 51031 Nintendo Wii
Regards,
G33k
May 24, 2011 | Nintendo Wii Console
My error code is 51031 can you tell me whats wrong
This error code means the wireless connection within range is not compatible or not configured. Please visit the following link for tips to resolve this issue.
Click Here
Regards,
G33k
May 10, 2011 | Nintendo Wii Console
Error code 51031
Error Code: 51031 - I had same problem. Worked one day, not the next. I went into Wii Settings/ Internet/ Connection Settings/ Conection 1,2 or 3/ Clear Settings. Then click 'Search for access point'. Click on your your home internet (Sky, Virgin, O2 or whatever), input WEP (written on base of router) or private password if you changed the WEP when you first got broadband installed in your house and it should connect.
Did for me.
Jun 10, 2008 | Nintendo Wii Console
Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW 4PORT MANAGED SWITCH Logo
47 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
