Question about Garden
Hi I have a Toro 7-25 rear engine mower. When I got it would not crank at all so replaced starter solenoid now it cranks but would not fire took coil and had tested they said it was bad bought new coil and now it is still just cranking and not firing it is sounding like it wants to, also i pulled the plug wire off while cranking and there does not seem to be any spark to the plug. I am kinda at a loss of what to do now can you please help.
SOURCE: FIRE and FUEL........NOT CRANKING !!!!!!!
check your ignition fuses but i think your problem is between your module and ignition switch if you got safty switches on there any one of them can cause that also.
Posted on Dec 06, 2008
Caesarfix
  • 141 Answers
SOURCE: 1991 JEEP WRANGLER WONT START
Take the distributor cap have someone crank the car and look if rotor turns, look at rotor conditions, I am sure that you have replaced it, hot wire from positive on the battery to positive on the coil, if car starts after you have a problem on the key, Is it fuel getting to the injectors? after You replaced so many things,if your rotor is not turning when You crank the engine, your timing chain must be defective or timing gear,
Posted on Jan 21, 2009
  • 4 Answers
SOURCE: 2007 Toro LX 425 Riding Mower, slow cranking.
check the starter see if it is going bad or not?
Posted on Apr 18, 2009
mcgyver468
  • 710 Answers
SOURCE: 98 dode ram wont crank no spark
May have no spark due to a bad crank sensor, which is responsible for spark when it gets a pulse through the cars' computer.
Posted on Apr 24, 2009
  • 24 Answers
SOURCE: 1993 Jeep Grand Cherokee engine problem
If the crank sensor (reaR at bellhousing) is dirty, will not start, clean up and visually inspect
Posted on Apr 29, 2009
Toro zero turn mower,motor quit running,replaced fuses,no start,crossed post on selnoid,engine cranked,no response with key,just clicking,battery not dead.Ingtion module bad?
Are you sure battery is not worn out? you can have power in the battery but if it does not have 12 volts the starter will not work. If that's not the problem check the starter solenoid.
Oct 24, 2015 | Toro Garden
Why wont my lawn tractor restart? Starter doesnt even turn over. I did everthing I'm supposed to do before getting off
as it is supposed to do for your safety .sad but apparently you did not set brake or turn off the blades . it will not turn over if the electric clutch for the blades is ON
May 16, 2015 | Toro Zero Turn TimeCutter MX Series MX4260...
How do i install a starter cylonoide on a toro timecutter rear engine lawn mower that has a kawasaki 22 hp motor i dont know were the green and blue wires go
do you mean a solenoid? if so then the 2 wires fix to the spade terminals on the solenoid just below where the 2 large red ires are bolted to the solenoid
May 06, 2015 | Toro Garden
Why is the car not starting
not enough voltage in the battery to turn the engine over.
Sep 07, 2014 | 2011 Toyota Camry
Why won't my riding lawn mower crank over?
Hi if you have got it cranking remove the plug and check for a spark the plug must be earthed to do this if you have a spark it must be fuel pore a small amount in top of carb make sure ign is switch on hope this helps.Ron.
Jun 20, 2014 | Craftsman 420cc 30 6-Speed Rear Engine...
Toro timecutter starter
I think this is going to be like an automotive starter.
You will need to check 3 things.
The ring gear where the starter gear cranks the engine, the starter gear that engages the ring gear, and the overrunning clutch or bendix , which is the springy part that kicks the drive gear into the ring gear.
When you remove the starter from the engine, you will see the drive gear on the end of the starter that was inside the motor.
The drive gear is about the diameter of a half dollar or a silver dollar. it should not be chewed up, it should look like a good gear. Inside the place where the starter attaches, you should see a ring gear, with a flashlight, and those teeth should look good and not chewed up.
On the starter you removed, behind the drive gear and usually inside the starter is the bendix or overrunning clutch , which will push the drive gear into the ring gear when you crank the starter. These parts often fail every few years.
Some people fix them, most people replace the whole starter.
Be blessed.
May 05, 2013 | Toro 52" 27hp Z Master Zero Turn Lawn...
Owners manual for a toro cv14s
go here https://lookup3.toro.com/request/request.cfm they have a link where you can print your own owners manual for free....good luck
Apr 05, 2010 | Toro Lawn Mower With Toro Power Tools
Have same problem, turn key and does not crank
it is very possible that your battery cables are corroded or too small - this is a common problem with MTD machines, they cut costs by using cables that are marginal at best. i suggest replacing the battery cables, then you know that you're getting full battery power to the starting system. then you can check other things if that doesn't solve it. first rotate the engine by hand, sometimes the starter gear gets stuck in the flywheel. check the solenoid, pull the white [or yellow] wire from the solenoid, run a jumper wire from that terminal to the big terminal with the battery cable attached to it, it should crank the engine. if it doesn't crank, replace the solenoid. sometimes, there's a relay in the wiring harness that fails, but rare
Sep 24, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Have a Mitsubishi starter for a small 3 cylinder (Toro Mower)
Removed starter and tested with new battery and jumper cables...starter worked fine. Replaced battery and cleaned cable attachments...unit started as usual.
When starter throws this would indicate that the interconnect circuits are intact..the engine still would not turn...that leaves the battery, the cable, or a siezed engine. The engine flywheel turned easily...no siezure. That left only the battery and cable. Battery was 3 years old...cable was corroded...bad combination. Battery was replace and corrosion removed from the cable terminals...started first crank.
Apr 12, 2009 | Diesel Garden
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
