Question about AOC 2436Vw Monitor
My AOC 2436V monitor is leaning forward in it's stand. I'm trying to take the monitor off the stand, but pushing in the little hole that says "push" does nothing. Any suggestions? Is it permanently attached? I was easily able to disconnect the base from the stand.
  • 25 Answers
SOURCE: problem in my aoc monitor
pls replace control button 4no
Posted on Dec 12, 2008
SOURCE: AOC LM942
ok grab the plastic peace covering the bracket screw.. Squeeze it and pop it off.. Held on by plastic tabs..
you will need a good grip
Posted on Feb 10, 2009
SOURCE: Cannot attach base to samsung lcd monitor sw2233
It is a pain but you have to push it into the holes from the back first and the push it forward to snap it in place.
Posted on Apr 20, 2009
  • 161 Answers
SOURCE: The screen on the AOC
try changing the resolution on your computer. and there should be an auto button on the screen or in the screen menu
Posted on Dec 23, 2010
bbl242003
  • 1637 Answers
SOURCE: Hi I have an AOC M19W monitor attached to my
Top three suspects
1. Change your display cable for a new one 2. Without being able to see the screen myself, try to monitor on a different pc, if your using it as a tv, then try different channels 3. Press and hold the power button for 15 seconds then release to reset the system
Posted on Jan 31, 2011
AOC 24" 2436V slight separation effect and capacitance buttons don't work
You may have a bad cable or the cable is running too close to a power supply or power cable. This can cause distortion and shadowing. Try moving or replacing the cables or the monitor to make sure it's away from any power sources.
Dec 05, 2013 | Computers & Internet
Need plastic base for AOC LCD TV
Try searching eBay first. You might be able to purchase a generic replacement stand that uses the wall mounting screw holes.
Jun 24, 2012 | AOC L19W898 19 in. LCD TV
I got this monitor, got it all set up, only to learn that it's broken. Now I need to disassemle it to return it, but I can't get the stand off. Getting the flat base off was easy, but not the arm.
When u put on the monitor stand togother did u a snap on sound,yes mean the stand it snap in a hole and held it on somewhere.Look a latch or a knob pull or push on that latch or knob than push the stand up or down u should able to take it out.Or read the owner manual they should have sections on the stand and the base put in and take out instructions.
Oct 04, 2011 | AOC 2436Vw LCD Monitor
I just hooked up an AOC monitor to two computers. Sound is working on one but not working on my HP Pavilion. How do I resolve that? I don't have any extra speakers.
The sound goes out of the computer to a set of speakers. If the monitor has speakers built into it, then the sound comes out of them. Each computer must have a connection to the sound card (the little green hole) to speakers. If you want sound from the second computer, unplug the sound cable from the one computer and plug it into the other one.
Sep 15, 2011 | AOC Monitor
My AOC 2436V is used as an external monitor for my laptop. How do I make it center 4:3 displays on the screen with the proper aspect ration instead of stretching them to fill the screen, which distorts...
on laptop you have function key and f4 key hold the functio key and keep pressing f4 that would bring options to change view select the that you want.
Mar 04, 2011 | Computers & Internet
LG - 32LG20 - Excellent LCD TV, but the stand is junk
there are four screw holes at the back, you might want to make use of it for anchoring. I guess these models are designed for TV-like installations and not for computer desktop monitors. The base takes a lot of space too.
Aug 16, 2009 | LG 32LG30 32 in. LCD HDTV
Llay the monitor face down on the floor (I put it in the styrofoam from the package) and then put it up against a solid surface. Then push the part into the socket before attaching the round base.
I tried pushing down onto the monitor while holding it upright but that didn't work. When I called Samsung tech support the solution above is what they told me to try and it worked.
Mar 19, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor stand and power cable needed
Hi Kiran,
If the power cable matches the power cable of your computer, it's a standard 3 prong power cable and you don't need a specific kind. If it's a small circular type you will need an external AC adapter, the type will depend on the manufacturer and make of your monitor. These can be found on eBay usually. Most monitors use different types of stands, but if your monitor has the standard VESA 75 or 100mm mounting holes on the back, you can find many monitor stands that are compatible with it. The standard VESA mounting holes are usually used for wall mounts but lots of stands connect to the monitor this way. You can tell by a set of 4 holes for screws or bolts on the back that are either 75mm or 100mm apart (vertically and horizontally). Don't forget to get the right kind of bolts for the stand, if it doesn't include them.
Jun 10, 2008 | AOC Computers & Internet
AOC LM729 17" LCD Monitor Screen goes black
YOU HAVE A DRY SOLDER PROBLEM, You have to open the monitor and check the solders in the PC BOARD , mainly where theres A SMALL transformer resolder it , and try again ,that should fix it . hope it helps
Apr 20, 2008 | AOC LM729 17" LCD Monitor
AOC 2436Vw Monitor Logo
136 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
