Question about Dishwashers
My GE Profile dishwasher is not cleaning the glasses on the top rack. It leaves all kind of grit and food on the glasses. I did some testing and it lookslike the wash rinse/wash assemblies are not spinning at all. I think the conduit main may be blocked or leaking at the seal. My question is, how do you remove the track (conduit) that brings the water to the upper rinse arms?
  • Dishwashers Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 20, 2011
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
Apr 14, 2016 | GE Dishwashers
Sand on inside of cups and glasses on top rack of dishwasher
it souds to me like lime scale detaching its self from the heater element.
try calgon, it should fix it
Jun 03, 2012 | GE 24 in. Profile PDW7880G Built-in...
I have a bosch dishwasher, SHU535E05UC/14. The
the spray arms are not rotating check they spin freely if they do remove them and clean any residue food deposits blocking holes for water spray.
Jan 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Dishwasher not cleaning dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 24, 2009 | Kenmore 24 in. 17462 / 17464 / 17469...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dirt and residue left on glasses
wash glases alone ad a jet dry aditive to detergant  Vitally
Jan 26, 2009 | GE Profile PDW8600J Built-in Dishwasher
Grit like residue after cycle finishes.
I had the same problem and it was fixed by switching dishwasher soap. We always used the same liquid soap for years and when this problem came out of the blue (about 8 months ago) I switched to Cascade action pacs with Dawn. It did the trick! No more residue since then. We now are having a problem with the dishwasher not draining (our unit is 8 years old), but the grit issue has been handled!
Aug 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Glasses on upper rack getting food residue during cycle
is there anything blocking the spray or plugged in the spray arms check that
Mar 28, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwashers Logo
116 people viewed this question
Top Dishwashers Experts
Owen Barnes
