Question about Speed Queen AWS17NW Top Load Washer
How do you remove the timer/dial of the Speed Queen washing machine/
SOURCE: Squeaky Washing Machine
There are many possibilities but a common one is a worn out idler wheel. 6b657f1.jpg
Posted on Jan 11, 2008
appldoctom
  • 311 Answers
SOURCE: Maytag Washing Machine Cycles Out of Sync with Dial
ive fixed lots off washers over the years[15,000 service calls] and was careful while taking parts off if i wasn't fulmilure with that model,but most timers and knobs have a key way so the knob can only go on one way.if thats not true for you, try this.turn the timer shaft till the washer is at the end of the wash cycle.[finished the load,it would be the final spin ,maybe five minutes long.when thats done the timer advances to off]now knowing that thats an off position set on your knob and then manuly turn it to the off position of the next cycle if it wont run you did it. if not you will have to go to the end of that cycle and remove knob and set to next notch in the knob,until you find the sweet spot.hope this helps God bless,tom
Posted on Feb 27, 2009
  • 84 Answers
SOURCE: My speed queen top loader is leaking water during
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
Posted on Jan 12, 2010
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
Posted on Jan 13, 2010
SOURCE: speed queen washing machine mod kaw693 repair manual
do you know where I can obtain a repair manual for my Kleenmaid KAW693 I need to replace the seals and bearings as it leaks a bit of water and makes a screeching noice when agitating. My email address is kerryn12@optusnet.com.au Thank you
Posted on May 06, 2010
Hi i have a speed queen toploder washing machine
It might need to be rebalanced or your connection are not tight.
Feb 01, 2017 | Speed Queen Washing Machines
I have a speed queen top loader washing machine it start with the washing sickle and the timer stop when it must start to spin or rinse and i replace the timer with a new one
There is sometimes a pause between wash and spin. This allows a little time to pump the water out before starting to spin. Do you hear the pump running between wash and spin?
How do I replace the timer knob on Speed queen AWM351W-3062 ?
The problem may be mechanical failure of the timer rather than the knob, especially if you have to push or pull to start washing.
Aug 20, 2016 | Speed Queen Washing Machines
Speed queen AWN552 completed one load without a problem but machine won't start for 2nd load.
Does it fill with water? When you try to start a load, does the timer run?
Nov 09, 2012 | Speed Queen AWN542 Washer
Speed Queen HD comercial washer
Its sounds like you need a replacement knob, if you can turn the disc behind it to start a cycle and the machine times out find the timer is probably still good, do a Google search for Speed Queen parts, and buy the correct replacement knob.
Mar 30, 2008 | Speed Queen AWS52NW Top Load Washer
Speed Queen AWS17NW Top Load Washer Logo
117 people viewed this question
Top Speed Washing Machines Experts
Dan Webster
Dan Webster
Coss
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
