Put in headphone in computer pull out half hour after and now not hearing any sound from computer
    Guru:
  • 868 Answers
Hi abifedrik,
I see that your headset was working fine on an earlier time when you used it now you mentioned it won't even give out any sound at all.
Have you tried updating your sound drivers of maybe reinstalling the driver for your Audio card on the machine.
Possible that the driver may have kicked Off the system this happens sometimes but not that often.
Check to see if the audio driver is in device manager if it is then try uninstalling and reinstalling the driver.
If it is not detected get a fresh copy of your audio driver try installing hopefully this should fix your concern but if your grt an error installing the aduio driver then something may have gone wrong.
also checked if the headset settings are correct check if it is in Mute.
But to check further with the issue you can do a system restore on the system to an earlier dat or time when you had the Audio working o your Headset.
I hope that this will be helpful.
Have a nice day,
mvincentc
Posted on May 19, 2011
Sound from headphones on computer terrible
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards You will need to open up your computer to check the back of the input headphones plug look for dusty and bad soldering or loose connections. b> Computer Headphone Jack Has Fuzzy Noise b> When building a computer system, making headphone and microphone jacks are one area where computer manufacturers use the lowest-cost parts. When it comes to computer audio, no perceivable difference in sound quality exists between that of ordinary parts and higher quality ones. Very low-quality parts, or parts that are installed with sub-par wiring, however, can lead to fuzzy sounds and static on headphones.
Symptoms and Component Isolation Start the diagnosis by using different headphones in the jack. If the fuzzy noise or static problem persists over multiple headphones, even if it doesn't happen with all of them, it's probably within the jack on the computer. This is also probably the case if the static increases when you do other things on the computer, like dragging windows around on screen with your mouse, then stops when you stop dragging windows. Causes b> The leading cause of headphone jack static is electromagnetic interference from other components in the computer's case. When electrical devices draw current, they also generate a magnetic field. Overlapping magnetic fields cause static. To combat this effect, the manufacturer provides for the components on motherboards to be grounded - the wiring from the microphone jack will have an extra lead that goes directly to a grounding agent. When your computer headphone jack has a fuzzy sound, or static, the ultimate cause is usually bad grounding on the wiring that the jack plugs into. Rewiring The Jack b> If you're comfortable with a soldering iron, and know enough about electronics and wiring, you can remove the wire to your microphone jack and put in one with heavier shielding, or a better ground. If you're not comfortable with this, a computer repair shop may be willing to tackle this for you; the actual cost in labor is about an hour to an hour and a half of labor time. It may be less if the shop technician is familiar with this sort of repair, as opposed to only knowing how to swap cards on the motherboard. Using Different Ports for Audio Cheaper alternatives exist than rewiring the headphone jack on your motherboard. One of them is to put in a dedicated sound card - which will cost $15 or so, and you may have a compatible one from an old computer that can be scavenged. This will require researching the make and manufacturer of the card to download compatible drivers off the internet, and then installing them on your computer. If you have an unused USB port, the easiest solution is a pair of USB headphones. This has the advantage of working with future hardware as well.
How to reduce static in my audio http://www.miracletutorials.com/how-to-reduce-static-in-audio/
Feb 27, 2013 | Computers & Internet
My speakers dont work at all. the only way i can hear things is if i put headphones
Probably the volume of speakers is turned down.
1. Go to Start
2. Open Control Panel
3. Unplug the Headphone
4. Open Sound and Audio Device
5. Find "speakers" under Playback device (normally it on AUDIO tab)
6. Click on the button "Volume"
7. Pull all the slide bar to the top.
8. See if you hear sounds from the speakers
Mar 20, 2011 | HP G60-230US Notebook
No sound device in macbook air
Apple menu (top left) System Preferences > Sound > Output tab select the Internal Speakers
check your output volume and make sure the Mute checkbox is unchecked.
Plugin a pair of headphones. If you still have no sound. The sound board needs to be replaced, which is attached to the logic board. Meaning the whole logic board needs to be replaced.
Jan 20, 2011 | Apple MacBook Air
Doesn't work with Skype
Fixed it: the microphone on the headphone was switched off - it's a bit of a design weakness in the Logitech headset: it's easy to unintentionally turn the microphone off while putting the headset on. The lower half of the right headphone's central medallion is a button - indicated by a crossed out microphone icon.
Dec 25, 2009 | Logitech ClearChat Pro USB Headset
It plays through built in speaker even when headphones are plugged in
Try a different set of headphones, it sounds like the computer is not recognizing that the headphones are plugged in. Does the computer put sound out through the headphones as well?
Jul 31, 2009 | Acer Aspire One Netbook 8.9" Notebook
Cant get sound through my headphones when i plug it in my computer
You need to check the headphone jack on the case before you try to use it again. It may have a wiring problem, Shutting down the computer is a serious problem and could do a lot of damaged to windows program and you computer.The way to reset the case headphone jack is to go int the control panel and search for the sound control device. go to the advanced options and put in the type of device you want the sound to come from. There is also the possibility that the headphone jack was damaged when you had your problem and will no longer function correctly. Hope this helps you with your problem.
May 17, 2009 | Microsoft Windows Vista Ultimate Edition
Problem with sound
Wait you are confusing me.. You mean that u can always hear the sound when you connect the headphone?But not from the laptop speaker?
Dec 01, 2007 | Acer Aspire 3680 Laptop
Aspire 3680-2574 Headphone jack
right click my computer--> properties-->hardware-->device manager-->sound devices-->find realtek hd audio-->right click-->disable-->OK
wait at least 3 min
repeat and enable
Oct 09, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
