Question about Mtd Garden
I have a ranchking pro rider with a hydrostat tran ifound the fill tube but i need to know what kind of oil and how much to hopefuuly fix my problem the mower won;\'t go
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
youcandoit2
  • 11 Answers
SOURCE: I HAVE HUSQVARNA 1548 RIDING MOWER HYDROSTATIC
You may have a drive belt that is worn or broken. Check the drive belt for slack condition see if it is not slipped off idler pully wheels or the belt tensioner. I had one that was streched out and was very slack on the pully wheels - I had it replaced with new one and was fine to go. There is a device on the back of your tractor to release the transaxle for manual pushing your tractor about with out starting the engine. Make sure the device is positioned correctly for running mode (engine) - There is a symbol on the back to help you know what to do. The tractor manual has good trouble shooting info and if you don't have one, try googling for it with the model number of your tractor - you will be able to download one free to your computer for viewing it.
Posted on Jul 17, 2009
  • 16 Answers
SOURCE: Rider won't move Hydrostatic
Ahh a Craftsman, out of my league slightly as they are not brought in to the UK.
From what I gather these are a Sears product so it would have been delivered to you "Dry" .ie no oil or fuel etc. Have you checked the Hydrostatic Fluid level? What type of Oil did you put in there when you built the machine up? If you have used the wrong grade it would give these type of problems. Most Hydro units on lawn tractors (here in the UK anyway) often just run on Engine Oil not Transmission Oil but this should be stated in your instruction manuals for the machine
Posted on Oct 15, 2009
  • 9 Answers
SOURCE: I have a MTD Yardman 46
Check the drive pulley rubbers for worn spots causing slippage
Posted on Oct 22, 2009
  • 202 Answers
SOURCE: I have a Husqvarna Pro Rider 15 ride on mower,cuutting deck broke
You may find this helpful. A complete manual you can download and use for this and other repairs.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqom88hoen2003_1140142-26rideen.pdf
Posted on Dec 23, 2009
How to fill hydrostatic transmission fluid on Poulan Pro
How do I check the transmission
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fill Hydrostatic Transmission in Lawn Tractor
http://husqvarna.custhelp.com/app/answers/detail/a_id/387/~/maintenance---what-type-of-oil-is-used-in-the-hydrostatic-transmissions%3F
Craftsman Hydrostatic Transmission Fluid Change
Jul 28, 2012 | Poulan Garden
Forward & reverse doesn't work on my Vangard lawn tractor, model 280777.It is a hydrostatic. Does it need hydrolic fluid? Where do I add the hydrolic fluid at?
i dont see there being any difference in what they take . on the standard lawn tractors they are not designed to be serviced easily like the gt craftsman tractors .. this will more then likely require removing the rear axle out of the rider and keep in mind there is a vent tube on top that will be cable tied to the frame . since this is a hydrostat it wont be as big of a pain as the geared versions ... other then tipping the axle over to let the fluid pour out the vent tube im not sure of any other way to remove the fluid ... to fill it you do so via the vent tube ... i will see what i can find out off my mower tomarrow and post back on here ... ill post my model number for my mower and see if yours looks the same and ill also post the axle model number to help n see if yours looks the same .. since the tractor wont move my idea is that you have water in the oil for the axle and or it dont have enough oil to move ... hang in there and ill get back with you tomarrow night with the info from my rider and we can go from there ..
Nov 07, 2011 | Briggs & Stratton Garden
I have a scotts/john deere s2046 riding mower (man date 12/98) --hydrostatic trans making a groaning noise--want to fix it before it fails--is there a rebuild kit of some kind?
I would try and fill the case with 50 weight oil It might be low. The hose should come to the right side of the pully door on the middle of the tractor between your legs.
Terry
Jan 09, 2011 | Briggs & Stratton Starter Scott's Equip...
The mower gets slower and slower and then stops moving completely. I turn it off for five or ten minutes and it's okay ... occuring more frequently ....
The hydrostat transmission is low on fluid. Check your manual, some of these can be filled...most cannot. If yours can't be filled/doesn't have a fill opening, Husq is going to recommend to replace the transmission (sealed unit). There has been limited success by trying to top off the trans thru the vent tube. This is not a Husq approved repair, and is very slow and tedious. But it is a lot less expensive. Good luck!
Aug 23, 2010 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
IT MAY NEED SOME FLUID IN IT I COULD LOOK AT IT IF YOU WERE IN MY TOWN IM IN TULSA LET ME KNOW I WILL HELP
Oct 11, 2009 | Garden
Where is the hydro unit filler tube?
If you are talking about the hydrostatic drive, most of them are a sealed unit and not servicable by the consumer
Sep 17, 2009 | Garden
My murray 17 hp 42 inch cut hydrostat mower will barely go uphill
Hydrostat transaxles are very picky like the trans in your car. It must have clean fluid and be full of fluid. I am not saying to fill that transaxle to the top but make sure it is to the top of the fill line. Also it needs to be changed every few years and keep it clean to help it stay cool. If it has a filter make sure to change it when you change the fluid in the transaxle. That fluid is nothing more than 20-50W motor oil.
Aug 31, 2009 | Garden
Transmission stops pulling when it gets hot
when was the last time you had the trans serviced?
It could be seizing up from the lack of oil
May 09, 2009 | Garden
Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
