Question about Belkin Computers & Internet
I have a wireless g mimo router and the man in the shop told me after setting ot up I could remove the ethernet cable so it was completely wireless but if I remove the cable I lose the Internet. Please help me if you can thanks Lynne
    Sergeant:
  • 359 Answers
You have to setup your router for wireless access. Then setup your laptop to find your router and connect. Refer to your router manual and it will tell you how to do this. It's pretty easy just diff for each router.
Posted on Aug 14, 2008
I want to know if there is a receiver that will allow me to hook up directv to my belkin wireless g plus mimo router without getting a 50 feet eathernet cable/ is there a receiver that can be hooked up to...
Yes... the device you are looking for is called a "wireless ethernet bridge". They allow ordinary wired ethernet devices to communicate wirelessly. They are also known as "wireless gaming adapters" for XBox 360 and Playstation 2, since niether have wireless cards
Oct 29, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have wireless broadband with a Belkin ADL2+
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Jan 18, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to you secure a belkin G + MIMO router
Click Here
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My laptop connects to the router but the internet doesn't always work. The connection is perfect yet most of the time it won't go anywhere. Sometimes if I move the laptop around a few inches it'll work for...
Greetings,
If the laptop is hooked up by ethernet cable and the problem happens when you move the laptop, you either have a bad ethernet cable or a bad ethernet port in your laptop.
Probably the best thing to do in your situation is since you have a wireless router, enable wireless on your laptop and use that instead and work wirelessly.
Let me know if you need help setting it up.
Aug 31, 2009 | Belkin F5D9231-4 Router
We have WiFi set up at our house from the main desktop, we have 2 laptops that have built in wireless cards. We put in another desktop in the guest room for our guests to use but instead of buying a usb...
hey there joselko,
i'm chris from sw scotland. i have the same setup - 2 wireless laptops and a pc physically connected to the router with an ethernet cable.
you just plug the ethernet cable into the 'out' hole in the back of the router and into the ethernet port in the back of the PC. then start your PC. go to control panel, then internet settings, then hit the 'connection' tab, then click the radio button that says 'never dial a connection'.
you may have to reboot, but not necessarily.
both the laptops should continue to work wirelessly and the PC should now connect directly to the internet using the router.
if you have any problems, feel free to call me on 01776840273, and ask for chris, i'll be glad to help. you can also skype me on christophergrams or using the skype number 01414165437.
good luck.
chris
Dec 12, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Arimex comcast router won't talk to belkin wireless g plus mimo router
Comcast has a little known "trick" that they use when setting up users. Here's how it works:
When Comcast first comes to setup your new cable modem service, they insist on connecting it to your computer and "testing" it. Most people think nothing of it, and that it's good customer service ...truth be told, what they are doing is attaching your computer's MAC address to that cable modem, so that you cannot create a wireless network. This is because they want you to pay them $150 to do this for you.
In this situation, since the modem is a modem/wireless router in one, my guess is that the MAC address on your machine now does not match the MAC address on the new router, which is what Comcast has stored in their database(s).
Try this: on your computer (while connected to the modem), perform a release on your IP address (start, run, cmd, then type "ipconfig /release"). Disconnect the ethernet cable from the computer. Turn computer off completely. Hold down the reset button on the cable modem until it performs a reset. Once it's back up and running, boot up your computer with the cable back in the ethernet port.
The cable modem should assign a new address to your computer. However, that may or may not work ...this is an easy workaround with a Linksys router, but not necessarily with the all-in-one devices.
Worst case scenario: contact Comcast and notify them that the new modem is not recognizing your computer's MAC address and that it needs to be updated in their system. They will scan your computer (through the telnet interface on your modem) and get your computer's MAC address, then (hopefully) make the necessary changes on their end.
After that, everything should work flawlessly. If not, insist on a Comcast tech to "fix" the service that you are paying for.
Good luck - hope this helps :)
Sep 29, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
CANNOT CONNECTTO BELKIN G+ MIMO
Hello, Connect a crossover ethernet cable from the computer to one of the LAN ports (usually 4 grouped together) on back of router. Connect a crossover ethernet cable from DSL modem to the WAN port on the back of router. Enter The default address for a Belkin Wireless, 192 168.2.1 into browser address window. Hit enter, it will then ask for a password only. For default leave it blank and hit enter. You can change it later. This lets you into the settings. Look for WAN settings and make sure the "Dynamic IP" is selected. Save this and refresh the link. Bring up a browser and check for internet connection. There's a number of changes that can be made here. Let me know what happens.
Mar 13, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Mimo Router
If you're connected to the router with excellent stregth then the problem most likly lies in the routers connection to the internet. Check your DSL, Cable modem and make sure the connection to the "Internet" port on your router is good. Try switching out the Ethernet cable if nessciary.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless router
OK classychick,
do you have a wireless card in you PC/ laptop? If you have you should set this to the same settings on your router.
eg. SSID = {whatever you want}
WEP encryption 64 bit = {10 chars from a-f and 0-9}
or WPA encryption = {a word}
Has the wireless on the PC/Laptop been turned on?
Cheers
Tim
Dec 13, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
57 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
