Question about Chi Mei Corporation CMV-633A LCD Monitor
CAN YOU TELL ME IF WHEN THE MONITOR IS TURNED ON THE LIGHT IS BLUE THEN IT CHANGES TO AN ORANGY RED INSTEAD OF THE GREEN TO SAY IT IS ON WHAT DOES THIS MEAN
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 20, 2013 | Home
I cant see the red color on my lg LCD (flatron l1919s). instead there is like a blue light in the screen (all the pictures and faces are blue, and red events are black).
Failing internal components (but first before sending in for repair, check the computer graphics card is ok, as this, or the VGA cable to monitor may be suspect)
In effect what is happening is that the hardware that controls the spread of green and red pixels on the screen has failed (happens over time), this will need repair or more likely replacement
Apr 20, 2011 | LG Flatron L1919S LCD Monitor
My screen is green i was going to change monters didn't work so i put it back and it turn green.help please.
Red, Green, and Blue are the colors sent from your computer to the monitor. Sounds like red and blue are not working. If you've tried a new monitor, I'd try a new video cable next. Then clean the connector on the back of the computer (compressed air). Finally, replace either the video card or the computer.
Oct 04, 2010 | Computers & Internet
Monitor colour problem
the VGA cable connecting from moniter to the computer is faulty so replace new
May 25, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
Laptop screen has been invaded by green and red/purple germlins
Sorry to tell you but you are describing exactly what an LCD looks like when it has been fractured. Does it work with an external monitor? If so you will need to have it repaired. Call the Fujitsu support number (800)-fuj-itsu and they can tell you where a repair center is in your area. The call is free. Have your serial number handy.
Mar 09, 2009 | Fujitsu AMILO PC Laptops
My moniter screen has turned to blue screen and i am not able to
On your CRT back PCB thers three transistor on for red green and blue its possible that your blue transister is faulty. Try moving your cable see if the colour changes it can also be a faulty 15pin plug
Have a nice day
Dec 24, 2008 | HP Compaq FS7600 17" CRT Monitor
Monitor is blank but green light is on
if you disconnect the data cable while the monitor is on, you should get a red and cyan message telling you to check the cable, that assures you that the problem does not coming from the monitor, instead check th video card.
Jan 23, 2008 | HP Pavilion M70 17" CRT Monitor
Chi Mei Corporation CMV-633A  LCD Monitor Logo
Top Chi Mei Corporation Computers & Internet Experts
giarcnameloc
Level 1 Expert
Jax Planet
Jax Planet
Are you a Chi Mei Corporation Computer and Internet Expert? Answer questions, earn points and help others
