Question about Intel Desktop Board D845BG (KD845BGPAK10) Motherboard
Sir/madam my intel 845 motherbord starting problem it has so slow boot very slowly booting a window xp platform
  • Intel Master
  • 27,725 Answers
Try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have
to check the details on your computer
click start all programs accessories system tools system imformation you will see all of your computers imformation from there another way of doing this
click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer if you see something running that you don
Posted on May 19, 2011
Dear Sir I am installaing WIn Xp Professional 64 bit on Intel motherbaord DH 61 WW with 8 GB corsair ram and after the boot hardaware error occurs and its ask to check the hardware or viruses...
The motherboard has nothing to do with your problem. Its your processor it has to be a 64 bit processor. If you don't during the installation you will get an hardware error. Your windows 7 must of been a 32bit or aka 86x platform. So put windows 7 back on (recommended) or try windows xp pro 32bit
Aug 11, 2011 | Intel Desktop Board DH61WW Classic Series...
I have Intel 845 series motherboard & I want to format my PC but when I put xp cd inside & restarts & press enter the boot doesn't start now how could i format ?
You have to change the BIOS settings to boot from your CD drive. It must have been set to boot from harddisk.
To do this you have to change the primary boot device from Harddisk to CD drive. When you restart your computer press DEL or F12 or TAB or F1(any one...Depends on your BIOS see manual or try all) to bring bios. In bios go to boot device priority and set the CD drive to boot first.
Restart your computer, it will boot from CD drive and XP setup will start.
Hope this will help...cheers:)
Sep 25, 2010 | Intel 845GE Motherboard
Gateway E3600 (Intel D845PT MB) won't boot after MS Update
This error comes when your motherbord not read properly harddrive.
for that first reconnect both connection to harddisk.Power cable and ide or sata cable.
Change SATA or IDE cable then check.
Pull cmos cell from motherbord for 10 minutes so all settings are factory defaults.
Then when you power up the computer press F1 or F2 or "del" key then you can see bios screen.
Make sure hardddrive detect in bios.
Set first boot device as harddrive.
Then check.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Intel Desktop Board D845PT Motherboard
System Problem
for it chack things like your installation media is clean ,is there any software which is stopping the process or you can format the hard disk and always do a clean install do not upgrade os
Sep 11, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
PC does not boots / does not start
Since your system reboots even if you stay in the Bios setup the problem with your system might be because of heating up of the proceesor, which might be caused if the fan CPU fan is rotating slowly or is not rotating at all. If the fan is rotating slowly change the cpu fan and try to reinstall XP
Jun 29, 2009 | Computers & Internet
I am using mercury 845 gvm motherbaord i had inserted 128 mb grafics card into the agp slow & booted with windows xp now only one vga card as to be shon in divece manger but where as i get 2 vga displays...
Dear friend You need to disable the built in agp card From BIOS, You may find it To the Integrated Peripheralsor Chipset Features Option.Best Regards Sumon(jisfy@yahoo.com)
Mar 17, 2009 | MSI 845GVM-L (MS-6714-040) Motherboard
Computer not booting
reinstall xp but select repair but if this is a bios prob you must turn off then hold down f12, or f4, or f8 depending on your cpu. hold down till you hear a beep then read screen when u get to boot config dis able hdd and network boot and make sure its boot from c.d. or floppy only. and your back. u must in the future disconnect from the cpu app before you physially pull any plug or unistalls, when you dont it gives the mothers borad a mild stroke type thing or a long term daze or confusion type state.
Mar 15, 2009 | Intel Computers & Internet
750 GB Hard Drive support on intel 845 motherboard
Hi prabhatkumar, your Intel motherboard's bios will see the drive. The question is will windows?
Do not use windows to setup the hard disk drive. Download the free bootable software for a floppy disk from the manufacture's web site. Boot the system to the floppy & format the drive. You'll be able to set the cluster size (Like windows would do) but the software from the manufacture is far better than windows. Any version of windows XP will see your total drive size. Just make sure the drive is seen while in the bios. (If it will be the primary drive make sure it is listed in the boot order).
Good day prabhatkumar!
Run into any issues just drop me a note.
Mike
Sep 23, 2008 | Intel D845HV (735858149143) Motherboard
PC is very slow booting
To ansver your question would take alot of time and it is very complex. I'm not going to do that for free.
But I can suggest reinstalling windows.
Mar 02, 2008 | Intel 845GEBV2 Motherboard
Intel Desktop Board D845BG (KD845BGPAK10) Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
