Question about Schwinn Cycling
Replacing original seat for Clear Creek with Noseless saddle seat. Hoe to?
  • 2,334 Answers
All you need to do is match the seat post clamp to the seat rails. 99% of seats are compatible with modern days seat posts. If yours doesn't fit, get the adjuster.
Posted on May 19, 2011
Where can i get a saddle stem bolt that adjusts the saddle height os 10202 model
If you want good help you need to give better info. "Saddle stem bolt" is not a standard term. The "seat binder bolt" is at the top of the seat tube on a bike frame and is used to clamp the seat post, allowing one to adjust saddle height. No idea what you mean by "os 10202 model". Any bike shop or bike co-op should have one that works for your bike.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Apr 24, 2018 | Cycling
Can't find a seat that doesn't cause soft tissue tears or bony areas hurt
The body position on a tri bike is cruicial not only for aerodynamics, but for comfort as well. The saddle is the usual "sore" spot for most riders who try to find a more aero tuck. Unfortunately, there is no magic saddle that takes care of everyone's problems. Human physiology differs from person to person and saddles need to fit a wide range of riders. My advice would to try to find a bicycle shop with a saddle rental program, this will allow you to test ride a saddle before purchasing one. Also, do some research on the various saddles out there. I had to try six different saddles before settling on one that is perfect. Here are some links to saddle manufacturers:
Triathlon Bike Saddle For Men amp Women Koobi PRS TRI T1 Welcome Innovative SaddleMaker Products
Mar 27, 2014 | Cycling
I have a women schivinn clear creek bike -18 speeches , i want to adjust the seat but i couldnt make the seat go lower . Does that mean i have to get a new seat?
If the seat is not at its lower limit the adjustable portion could be dirty or corroded and may need some lubrication to free it up.
Jan 10, 2014 | Cycling
Move saddle forward
Undo the fixing bolts and the saddle will slide forward
Make sure to tighten it up
Mar 04, 2013 | Cannondale Cycling
Cannot raise seat on Clear Creek Loosened quick release and pulled up but rod doesn't budge. How to raise seat?
use a pair of channel locks or a pipe wrench tohelp pull the stem up little by little without deforming the head....should work now with quick release adjustment...
May 22, 2011 | Cycling
Why does bike size is important?
It is clear that wearing a shirt two sizes too small would be uncomfortable, and wearing a shirt two sizes too large wouldn't be good either. In the same way, riding a wrong size bike will fit badly and make you uncomfortable, too. There are two main problems, one obvious and one a little more subtle.
The first big problem with a bike that doesn't fit is saddle height. You need the saddle to be just high enough to give your legs the right extension when you pedal. Too low and your legs stay bent too much all the way around; this doesn't use your leg muscles well and you wear out quickly. Too high and you rock back and forth on the saddle as you pedal, very uncomfortable. Either extreme (too high or too low) can also be very hard on your knees.
Saddle height is adjustable, of course, and if the bike frame is at least close to the right size, you'll be able to adjust the saddle to the proper height. If the frame is a lot too small, you can usually overcome this problem by buying a longer seatpost to move the saddle back up to where you want it. (But that causes other problems we'll talk about soon.) If the frame is much too large, you won't be able to drop the seat far enough to be usable, and there is no practical way around that problem.
The saddle on a bike can be adjusted up and down several inches, even as much as a foot if you consider replacing the original seatpost with a longer one. But the handlebars can't be moved nearly as far as saddles can. Most handlebars can be adjusted up and down or forward and back only two inches or so, and even this small change is often a complicated operation of replacing parts, not just loosening a few bolts.
This can lead to all sorts of problems. If the handlebar is too far away from the saddle, you have to bend down further and reach far out to grab the bars. This puts more weight on your back, arms and hands, which is uncomfortable. Having the handlebar too close to the saddle is less of a problem, but in extreme cases it can cause your knees to bump the handlebars when you are standing up to climb a hill. Having the handlebar a lot lower than the saddle is similar to having it too far away-you have to bend far over and reach further to grab the bars, an uncomfortable position. Having the handlebars high up is not a big problem, except that sitting upright slows you down. Your legs aren't as strong when you are sitting up, and that position causes more wind resistance when riding fast or into a wind.
Bike size has a big effect on handlebar position. If the frame is too small, you'll have to push the seat up high to fit your legs. You won't be able to move the handlebar up as much, so it will be a long reach back down to grab the bars, and your back will be quite bent over. If on the other hand the frame is too large, the bars will be up high but might be too far forward (since the frame gets longer as well as taller).
Dec 21, 2010 | Cycling
My motor cycle will not start if you turn the key it just makes a clicking noise
It sounds a lot like the battery is dead. You can either try jump starting it (12 volt) or replacing the battery. The battery itself is locaated under the saddle. Remove the rear seat by removing the allen head screw that attaches the rear seat to the rear fender. When you remove the rear seat, you will see an odd looking hex head bolt with a cylindrical cap that holds the main saddle in place; remove that also. The main saddle will lift up and back to reveal the battery.
If it starts and the battery charges (run the motorcycle for 20-30 minutes), you are good to go. If the battery does not charge after running it for that amoount of time, you will need to replace the battery.
Oct 18, 2010 | 2003 Suzuki VL 800 Volusia
Raise the seat
First take off the seat, turn it upside down, unscrew the two screws and two bolts that hold the two parts of the seat together. Separate the pillion and rider seat (takes a bit of wiggling), now you can concentrate on the riders seat. undo the four screw that hold all the rubber gromets down (make a note of the direction they are facing), and unbolt the two small bolts on the front. The seat should now come apart, move the bracket at the back of the seat down a hole. Re-attach the two halfs of the seat at the front but this time one hole up. You should see a gap between the two halfs. Put the rubber gromets back on, this is where I went wrong the first time, TURN THE FRONT TWO 180 degrees and leave the back ones how they are. Screw everything back together and you have one raised seat my long legged friend.
Nov 10, 2008 | 1997 Suzuki GSF 250 Bandit
How to adjust saddle postions
you can loosen the bolt under the saddle, and adjust it...
for me, the best saddle position for long distance is when it's facing downwards a little bit, so that you can move your legs freely.
Oct 29, 2008 | Bravo Sports /Bike Access 1001782 Racing...
Cycling Logo
243 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
