Question about Lexmark X3470 All-In-One InkJet Printer
Cover Open I have tried to fix it but no matter whaat I do it keeps saying Cover open
  • myersmichael Aug 17, 2008
    all I know is that I can't get it to work because of the (Cover Open) thingy please help!
  • mo2moon Aug 21, 2008
    Just changed the cartrige for the first time. Display keeps saying that the top is open. I've checked it several times, also the cartrige, no result. Lexmark X3470 dosn't go out either, so I've to pull the wire out.
    Scanning it doesn't do either, so all controll is gone.
    Hope you have a solution
Http://www.fixya.com/support/t235147-lexmark_x_3470 It helped me I got mine working just follow the instructions and especially the pictures when you scroll down.
Posted on Sep 04, 2008
Mfc-j825dw keeps saying scanner cover is open and its not. how do i fix this
short of returning it for another look to see if the lever where the cover closes is not got tape or something preventing it from seeing the door is shut.
Aug 27, 2012 | Brother MFC-J825DW Wireless All-in-One...
I'm tyring to print but it keeps saying "cover open" although no covers are open
hi
there is a sensor that check the door
it is under the cover try to find it
and put some paper in the hole that the sensor is paced there
May 20, 2010 | Samsung ML 1610 Laser Printer
Hiya my brother dcp 7010 printer keeps saying back cover open please shut cover but there is no cover open how can i fix it pls
This is happening because there is a paperjam in the machine and its covering the sensor for the back cover. Open the front cover of the machine and remove the drum and toner, then you can remove the paperjam.
May 06, 2010 | Brother DCP 7010 Multifunction Laser...
The LCD keeps saying 'Cover Open' but, no matter what I do, I can't rectify the problem. As a result, I can neither print nor copy. Can anyone help, please?
On the right side under the lifted cover is a little square of plastic which when the lid is closed pushes down on a plastic lever this then says the cover is closed.Its possible the lever that the plastic cam pushes against is either broken or faulty, check lever is being pushed down with your finger and it should return when released.
Jun 23, 2009 | Canon SmartBase MP360 All-In-One InkJet...
The Error says "Cover Open Front" but it is not open
Most printers have a plastic pin on all of the covers that pushes a switch when it is closed. This then sends a signal to the printer telling it "I'm closed".
Probably the pin is broken off (quite by accident I'm sure). A solution is to push a piece of paper in the hole where the pin is, closing the switch, to fool the printer into thinking that the cover is closed. You can try this by pushing a pen point into the hole to see if the message goes out. (Don't forget to remove the paper when you open the cover. The switch is there to keep things out of the mechanism while it is running. May not hurt you but will damage the printer mechanics irreparably.)
Anything else is an error with the printer software and processor and can't be fixed easily.
Sep 02, 2008 | Konica Minolta Magicolor 2530 DL Laser...
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
N72
Hi , Before go to nokia care for motherboard do 1 think open the different parts of ur mobile carefully and place that parts in Sunlight then afte r sometime fix the all parts then try to switch it on mobile will work
Gizmo1
Oct 16, 2007 | Nokia N72 Cellular Phone
Lexmark X3470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
