Question about Acer Computers & Internet
Computer boots up to the Acer screen and then instantly the monitor goes black. I will not boot-up into safemode
    President:
  • 3,278 Answers
Hello.
Since Safe Mode doesn't work, the problem could be memory.
Disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
Hope this helps.
Posted on May 19, 2011
Acer Travelmate 230 laptop starts up shows the Acer screen then gets to the windows loading screen after that the screen goes black and does nothing else. what can i do?
What operating system do you have?
What happened prior to the issue? Did you do an update/ installed a new software in your computer?
Try to boot to safemode:
1. Turn your computer on and tap on F8 before the splash screen appears. 2. You will get a black screen that says Advanced Boot Options. Choose Safe Mode with Networking. 3. If the issue does not reoccur there, the problem might be related to the video card driver. Uninstall the video card driver:
a. Click start, right click on My Computer. Choose properties b. Go to Advanced tab and click on device manager. c. click on the plus sign beside display adapter. d. right click on the video card driver found there and uninstall. It will prompt you is you are sure you want to delete it. Click yes. e. Then restart your computer. Boot to normal mode (just let it boot and do not press anything as you boot the computer)
The issue should not be present in Normal Mode but your screen resolution will be very different (bigger). Download the correct driver for your computer from the links posted below:
video driver 1 or video driver 2
Jul 05, 2011 | Acer TravelMate 2300 Notebook
When I boot up my PC my Acer monitor says "auto config please wait" then goes black. It works just fine through the boot up until it gets to the login screen. That's where it eventually goes...
Try power off then power on your PC press F8 choose highlight safemode press enter. if nothing happen no display on screen your CPU have problem contact service center for that CPU.
May 28, 2011 | Computers & Internet
Computer starts but screen goes blank
- You can try to fix this by performing steps below:
Boot Computer in Safemode:
- turn off the computer
- press the power button and after 2 secs tap F8 key repeatedly
- select safemode
- computer will boot in to safemode desktop
Perform system Restore
- click start > all programs > accessories > system tools > system restore
- select a date that you computer is working fine
- click next
- computer will automatically perform system restore and restart back to normal mode
Mar 17, 2011 | Acer Computers & Internet
Hi When I boot it up , the acer emblem comes up then the screen goes black with a small cursor flashing in the top left hand corner
If you are having just a blingking cursor on boot up you must check if there is a disc inside the disc tray, or kindly check as well if there is a USB flash drive plug in on your computer and if there is any please remove them while your computer boots up as your computer might boot from it and it may cause just blingking cursor.
If there is no disc or USB flash drive installed, what you can try is to boot your computer in safemode and perform a system restore. Atleast restore back your computer 2 to 3 days back before this problem happen.
To perform safemode:
- turn off computer
- press the power the botton and after 2 sec tap F8 repeteadly until you see all the safemode options
- select safemode with networking/safemode use the arrow keys to highlight it then press enter
- computer will automatically boot into safemode desktop.
To perform system restore:
- click next then select desired date then follow the on screen instructions
- once system restore is done it will automatically restart and boot your computer in normal mode.
Cheers . . .
Mar 14, 2011 | Acer Aspire 5920-6727 Notebook
Screen goes black. the power light is on, but the picture goes out. if i turn the power off, then on again it comes back for about 5 seconds, then goes black again.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
Sep 08, 2009 | Dell Dimension E510 PC Desktop
Dell d520 monitor goes blank while booting up(goes blank when starting windows). Everything boots up(I can hear the audio in the background)except its a black screen. I tried all safemode possibilities but...
just had this experience myself on a smasung monitor. I originally thought of power management but Samsung assure me it is a monitor sync problem and have yaken it away. Theyhave replaced the monitor. So conclusion is that your monitor is also in need of repair
Aug 19, 2009 | CMS PRODUCTS 80GB 7200RPM NB HD SATA-DELL...
Acer Monitor boots up w/computer then "no signal"
you must have disconnected it while the pc was running.damage can occur while doing this as can a keyboard (they are not like USB devices that can be plugged and unplugged while "hot".)
Jul 20, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1511 15" monitor Screen Menu Problem
What operating system do you use? If it is a windows OS press F8 while the system is booting to access the Boot Manager, choose to boot to last known good configuration and if this does not work retry but select safe mode and change the resolution back to the previous one.
Jan 19, 2008 | Acer AL1511 15" LCD Monitor
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
