Question about Hotpoint 24 in. DWF32P Free-standing Dishwasher
Hotpoint Dishwasher DWF 30, has power to the machine's switch on and off. The LED lights on control panel do not alluminate. There is no sound of pump working, or filling of water. all water ways are clear, impeller turns freely by hand. Any clues?
    Scholar:
  • 59 Answers
Just one question is the water to the unit turned on ? some times a unit will have a fail safe protection device where it would not start the system if there was no water pressure to prevent damage to the unit, but given the symptoms i really don't think thats it.
It sounds like there may be an internal fuse in the dishwasher circuitry that has blown and needs to be replaced.
Unfortunately without the circuuit diagrams its impossible to say if that is so. the manufacturers today don't supply circuit diagrams with the appliance and they tend to send a repair agent out who changes the whole board rather than just fixing the one problem.
If your adventurous you can try starting to apply power to various parts of the unit to see if they work - i.e. i am sure the pump works if you can get the appropriate power supply to it - but your risking some serious electric shock and issues with blowing things up.
Posted on Aug 14, 2008
My hotpoint Aquarius washing machine keeps tripping out and won't stay on
Hello Russell;
My name is Peter. I am a retired field service appliance technician.
You did not provide your model number so I have to be general.
There are 2 components that will shut the dishwasher down after start-up.
Door latch contact switch.
images?q=tbn:and9gcrmzmahngpjk6jot1w429lw3ev-0sqso8t6pqbfm9ukveqmbaus
Turn the dishwasher power off at your breaker box. Check to make sure the power is off by turning your dishwasher on.
Remove the front of the control panel. Some units have a small front panel and other units you have to remove the whole front of door. Generally the fasteners are torque screws.
Remove the door switch. Using a multi-meter set to the lowest Ohm setting touch both contacts on the switch with the meter leads and depressing the switch in. If the meter reads 'O' the switch is good. Anything else the switch is bad.
Ohm these components the same way.
Nov 22, 2014 | Hotpoint Washing Machines
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher keeps pumping out - won't start cycle - green light flashing on panel
I had same symptoms on a Hotpoint dishwasher.
Turned out to be a failed water heater.
The logic in this case goes like this:
When wash cycle starts, the first thing the machine does is pump out any water that has collected in the sump since it was last run.
It then allows a small amount of clean water in and enables the water heater.
If heater okay, it then continues with the rest of cycle.
In this case, the control board detected failed heater so pumps out the water and then stops with an error code shown by a flashing lamp.
No simple fix I'm afraid - machine had to be turned on its side, bottom panel removed, several items had to be removed to get at the water heater which was then repalced with a new one.
You dont state what make/model your dishwasher is so maybe worth adding this information as someone else may recognise your fault and have a quick fix.
Oct 02, 2009 | Dishwashers
FDW60P dishwasher. Hotpoint Aquarius Control panel not working
I phoned Hotpoint. Was told to switch everything off and take the plug out for ten minutes - I didnt do that before, I just plugged it straight back in. I did this and was able to run the machine during the night on the programme I wanted. At least if it happens again I know what to do.. This solution will cost you nothing.
Jun 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dishwasher
Switch the machine off and unplug at the mains. Leave for ten minutes, then plug in and switch on. My dishwasher control panel had a mind of its own and did what it wanted including leaving water in the bottom of the machine. The electrics sometimes need re-booting! Hotpoint suggested the solution and it worked for me. Saved me £99 call out charge. Good luck.
Jun 04, 2009 | Hotpoint 24 in. FDW60 Free-standing...
SDW60 - AL08 Error - No Hot Water
First switch off the machine and unplug it at the mains. Leave for 10 minutes then plug back in and re set your machine to the programme you want. It might be that the control panel needs re-booting. They are a bit sensitive and mine had a mind of its own, washed to its own agenda, left water in the bottom etc etc. so that might be the problem with yours. If that doesnt do it, go on the Hotpoint website and find the customer service number. Ask if there is anything you can do to solve the problem yourself before paying for a service call. It could be your heating element has packed up but try the easy fix first. Thats what I did and it cost just the price of a phone call. They were really helpful.
May 29, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Manual for Hotpoint Aquarius dishwasher - DWF 34
hi
you want
Hotpoint Aquarius dishwasher - DWF 34 manual no.dont wory go to how stuffworks.comyou can get all info you want.please rate it
Nov 21, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
Hotpoint Ultima dishwasher dwf70
Press and hold the start and the on/off buttons together. It should come out of demo mode.
Aug 25, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
499 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
