I have a 13 month old vizio VL470M, this morning when i turned it on, the bottom half of the screen is black...then fades to white...and eventually sits at a grey color. ive tried all the different inputs...the cable and RGB show half screens like i described, and the others just show a blue screen with the bottom half grey and it says "no signal"
  • 2,098 Answers
Hi Jackie,
This symptoms indicated of faulty sustain board and/or the main unit board.
First the unit must isolate from loose connection because it will produce same symptoms. It needs to open the back cover and take it apart, pull-out all the cable connectors from the main board, sustain board, power supply board and then re-insert and ensure the connection. Also the affected boards must check from bad solder joints.
If the symptoms still persist after the first steps has been done, the fault is either the sustain board and/or the main unit board. Sustain board is the one process the image came from the main unit board and once failed, same symptoms will be the result. Even if the sustain board is working but if the main unit board has no signal feeding this board same symptom also is the result.
This is not DIY and quite technical because it needs some special test instrument to determine where the fault came from. I would advice you to send it in to isolate the faulty boards.
Also, check if your unit has an extended warranty, if so, avail it because the manufacturer will fix it for free.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 19, 2011
How do I get my tv unfrozen?
Just try a hard reset to this set, and check. If it do not help you, check and replace its main board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 25, 2015 | Vizio VL470M 47 in. LCD TV
Blue line horizonally across the middle of the screen
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 01, 2015 | Vizio VL470M 47 in. LCD TV
Vizio VL470M won't turn on
see this instruction: God bless you
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
3. test the power outlet wall see the diagram
4. do not use the r.control use the power button directly from TV.
Jul 20, 2013 | Vizio 47"" vl470m 1080p 120hz widescreen...
White screen
Do you always shut down and unplug the laptop when not in use? Has it been cleaned recently? Fan, Vents, heatsink? Has there been ANY damage? It sounds like your Graphics Adapter. screen, Inverter, is going? Have to say exactly. Does the Laptop Overheat?
May 12, 2013 | Dell Inspiron 1545 Notebook
Bottom half of desktop screen fades to black
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Jul 17, 2012 | Dell Inspiron 530s Desktop Computer
Dropped my phone, half white/half black screen.
Repairing the damage to your phone cannot be performed 'at home'. You'll need to take (or send) it to a repair center to determine the amount of damage it has sustained and the exact parts that will be needed to fix it properly.
If you have insurance on your phone with your cellular provider you can have it replaced -as cell phones being dropped are covered by most insurance policies.
Take the phone to one of your cellular providers Retail Stores that has on-site tech support and repair. They will be able to perform a more accurate assessment of the damage and cost to repair it.
Apr 08, 2010 | Cell Phones
I have an acer p241w and half the screen is faded almost to black right side barely visible eventually turns all black. I turn monitor off and right side comes back on but left side is faded to almost...
HELLO I CAN HELP WITH YOUR ACER THE PROPLEM YOU GOT IS THAT CONDENTSATION HAS GOTTEN IN TO YOUR PC OR LAPTOP AND HAS GOT ONE OF THE CERCITS WET TRY THIS PUT YOUR PC OR LAPTOP IN TO YOUR AIRING COBORD FOR 24 HOURS AND THAT SHOULD RESOLVE YOUR SCREEN PROPLEM
Jul 14, 2009 | Acer Computers & Internet
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Electro Med Services...
