VCR running badly
About half way through an E180 tape, the spools slow down and stop. The VCR then goes into REWIND automatically. The cassette also stops when there is a change from an LP to an SP recording and vice versa, and stops and switches to REW. The machine isn't new, but it isn't old and much used either. Thankyou.
    Scholar:
  • 49 Answers
The 180 tape is thinner than regular 120's, and they tend to stretch. Your VCR "knows" the speen and that there is information on the tape by looking at and counting the pulses on the "control track" which is like the sprocket holes on a film. The control track is a series of pulses (regularly spaced pips or electronic clicks) on the edge of the video tape. (They are magnetic and can't be seen with the naked eye.) There is a counting mechanism which - based on HOW MANY pips there are - helps the machine to determine whether it an SP, EP or LP recording, and whether there's a recording at all.
If the tape stretches, the number of pulses becomes very irregular and the machine goes haywire. (There are normally about 60 pulses in one second of tape - 59.94 to be exact!)
If the count - because of stretching - is too far away from the norm the machine the machine will "hunt" (and never find out the real speed) - trying to figure out what speed the tape ACTUALLY is running at. If there's no control track at all the machine will just stop.
Your problem is any or all of the above. Throw the tape away.
Sorry!
Posted on Aug 14, 2008
I start to play a VCR tape and it just stops playing and the machine turns off. This doesn't happen with a DVD, however.
The VCR tape will turn off when spools are Jammed to prevent breakage of the tape. Take out the VCR cassette and put a thick pencil in the each sprocket hole and try winding in the right direction (which means when you manually wind the tape the other spool should unwind without resistance). If you feel resistance the sprockets are jamming. Knock the cassette on a hard surface without breaking it and usually it will free the jam. If does not help then carefully open the the cassette screw and re-position the sprockets.
Mar 29, 2015 | Televison & Video
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
GE VG4056 will not rewind
The photo sensor that senses the tape end has blown or dry soldered.It is on the right side of the mechanical deck and senses the transparent end of the tape through the square hole in the video cassette.
Apr 27, 2008 | GE VG4056 VHS VCR
Basic Functions Don't Operate Near End of Tape
Defective optical end-of-tape sensor, or alignment of those related component....accordianman
Dec 01, 2007 | Mitsubishi HS-U775 S-VHS VCR
Tape stuck
Your takeup spool isn't moving.  Before tearing into it further try putting the cover back on the deck and power cycling it.  Hit REW and then try ejecting the tape.  If this works, you'll get the tape back but it's likely the deck is dying.
If not, you need to be very careful to get the tape out:  You may be able to turn the wheel that moves the tape basket to gently ease it out;  otherwise, there are screws on the top of the tape basket.  Remove them and gently lift the tape out while carefully unthreading the tape from the tape guides around the head.  There'll be two feet of exposed tape--pretend it's glass, it's delicate!
Now the tape is out and you need to thread it back in the cassette.  This needs patience, but here goes:
On the front of the cassette, there's a door to protect the tape.  Feel the right hand side of the cassette for a small button;  hold it down to open the door and keep it open
With the other hand (or with three hands! :) ) put your hand under the right-hand tape reel under the cassette.  Carefully turn it clockwise.  It will make clicking noises, but it should ease the tape back into the shell.
Beyond that, the cause of the original malfunction will be a bad reel motor, which is probably not fixable, or a bad belt, which you may be able to locate through mcminone.com.  You'll have to unscrew the bottom cover to investigate further.
Oct 20, 2007 | Televison & Video
VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
Machine won't stay on
Hi I'm not familiar with your model, but what it sounds like is a bad "end sensor" on your machine. There are photo sensors on either side of the cassette basket which is what holds the tape in the machine. There is a light source that ends up inside the cassette when loaded, which shines both left and right. There is a section of clear tape inside the cassette at both the beginning and end of the tape. When the sensor on the left side sees light through the clear tape, the VCR knows you have reached the end and goes into rewind, when it sees light on the left side, it knows you have reached the beginning of the tape, and stops rewinding. This sensor is also used in some models to sense when you insert a tape in the basket. In that case, if the right side end sensor goes bad, the VCR always thinks you are trying to load a tape, so it doesn't want to give them up, and when you rewind, it never senses the beginning of the tape, so it will shut down when it reaches the beginning, and could even snap the tape. I'm 99% positive that is what is wrong with your VCR, it is an easy fix, but unfortunately, you won't likely find a repair shop that will sell you the proper sensor. I hope this helps in some way. Good Luck!
Jan 13, 2007 | JVC HR-A592U S-VHS VCR
Video tape gets eaten on rewind
Does the machine play tapes well? Clear steady picture and all? No tracking bars? wavering sound? Tape chewing is generally a problem with a bad Capstan Pinch Roller, Associated symptoms are as above. Please do recheck or confirm if any of the above problems are also present.
Aug 30, 2006 | JVC HR-VP650 VHS VCR
The unit will fast forward and rewind, but won't play
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but
Nov 22, 2005 | Sharp VC-H810U VHS VCR
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
