Question about Gateway PLSM42TV 42 in. HD-Ready Plasma Television
GATEWAY PLASMA TV Model # P420142V5 It shows good picture, but has a 1" black line on the middle the screen from top to bottom. Any idea what this means?
  • Anonymous Mar 24, 2014
    when using tv as monitor get not supported error
  • 10,515 Answers
Image problems on Plasma TVs can be a result of a failure of fault in the screen buffer boards. There are several buffer boards and each controls a section of the screen: either a column so many pixels wide or a row so many pixels wide. When the buffers start to fail, it is common to see lines either from top to bottom, or from side to side or just portions of a line going halfway across ( starting with 1" black line and after some time few more lines would start appearing there ).
It could also be a problem with one of the SUS boards.
You are going to have to call in a pro to check this out. There is no way that someone over the internet can correctly diagnose the TV without being there in person and then it would likely take hours of diagnosis to narrow down the bad part.
To have this looked at is going to start at about $100 and I would guesstimate the repair cost around $500. It could be more unfortunately so it comes down to not only a technical issue but one of economics - I don't know how much the TV cost or how long you have had it but you should consider whether or not to repair or replace.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 20, 2011
Sanyo TV model T27547 has horizontal lines across the top of the screen in front of what is being showed on tv. Is the tv worth trying to fix the picture is still very good.
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 02, 2017 | Sanyo Televison & Video
Gateway 42in plasma p420142v5
try check its settings, maybe its not configured properly..if you have remote control on it, locate the menu button then go to picture settings or video settings then adjust the contrast, brightness, and the color of course to your desired level..
Jan 24, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
LG 50PK250 shows only 1/2 top screen while the bottom 1/2 screen is black which board do I need to replace??
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 08, 2015 | LG 50PK250 50 HDTVReady Plasma TV
I have a LG 32LH30 TV. When I power on the TV I get a picture in the top half of the screen and vertical lines in the bottom half. Also I get a thin white dashed line across the middle of the screen....
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Plasma TV has a black uneven splotch in the middle of the screen
hmmm. sounds like the screen might be damaged. You might have to get a new one. But before you do that I would try leaving it off for a while maybe a few hours or so and see if that helps.
Jul 10, 2017 | Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Black line in center of screen
These black lines on the plasma screens are very fixable.  There is a dry solder joint on a circuit board at the bottom of the plasma that needs resoldered.  There are 6 or 7 "ribbons" along the bottom of the screen that correspond to vertical sections of the display, so you just follow the black vertical line down to figure out which one is faulty.  I just performed this fix successfully on my first attempt on a Gateway plasma, but it will work on most plasma's, specifically Hitachi, gateway, LG, Hyundai, & Akai. I think they may all have LG boards, my gateway did.
I can't really describe very well what to do, but I assure you it is fixable.  If anyone is near nashville, I might be able to help you out.  My email is tomp2000@juno.com.
thanks,
ST
Jan 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Gateway PLSM42TV 42 in. HD-Ready Plasma Television Logo
231 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
