Question about Xerox WorkCentre 4118X All-In-One Laser Printer
When turning on the xerox centre 4118 series there is a warning saying SCANNER IS LOCKED... how do I unlock it?
The belt that drive the scanner unit might be worn or out of place check or replace
Posted on Sep 29, 2012
JackHeath
  • 1049 Answers
SOURCE: Scanner locked - unlock scanner
To unlock a scanner open it where you would put cartridges in and look for a red or green colored tab hanging down. There should be a little picture of a padlock. You can switch it from lock to unlock. It's kept locked to protect the scanner during shipping.
Hope this is helpful...
Posted on Jul 28, 2008
  • 2072 Answers
SOURCE: scanner locked
There is a lock that has been hit and has the scan lamp locked.
Where to look is on the botom of the scanner. Look in where you remove the copies, on the bottom of the scanner you will see the only green part there, it is about 2 inches long and a half inch wide.
Turn the machine off, reach in and push the latch full IN, toward the back of the machine, then pull it our toward you until it snaps into place fully forward, It may be a little tight with it against the lamp carriage, but once you get it latched forward it will return to normal.
That latch is easy to hit when you are removing your copies from the tray.
Posted on Dec 22, 2008
  • 35 Answers
SOURCE: printer is saying scanner is locked, unlock scanner
In the section where the paper exits the printer, there is a blue latch. Pull it towards you. It does take a little pressure to pull. You may need to press cancel a few times. That should clear it out. If it doesn't, The scanning unit assemply needs replaced...or the printer itselft which ever is cheaper.
Posted on Jan 30, 2009
  • 23 Answers
SOURCE: xerox 6110 MFP scanner locked
on the left side of the device should be a mechanism to release the scanner
Posted on Feb 27, 2009
SOURCE: display says Scanner locked
There is a green switch located under the scanner area of the machine. You will also see a diagram of locked and unlocked padlocks. Just slide the switch to the unlocked position. Hope this helps.
Posted on May 17, 2010
My scanner xerox 3210 scanner locked and I con't find the unlock switch
It's located where the paper comes out above the toner door. It's on the top side on the left. Put your hand inside where the paper exits on the left side and it's above your hand.
Jun 27, 2016 | Xerox 3210/N WorkCentre series 3210/N MFC...
How to solve mismatch paper size on xerox 4118
Set the paper size correctly.
http://www.fixya.com/support/t5246564-paper_size_mismatch_xerox_workcentre Paper size Mismatch on Xerox workcentre 4118 cant print
Mar 06, 2016 | Xerox Office Equipment & Supplies
My xerox work centre 4118 is locked How am I going to unlock it
Do you mean your "Scanner" is locked? Were the paper exits to the left of the opening there should be a sliding switch. I suggest that you should use a flashlight to locate it This is the locking mechanism that once toggled , it will unlock the scanner. Remember to turn-off the printers power before attempting this.
I hope this resolves your problem, Steve
Nov 06, 2015 | Xerox WorkCentre 4118x multifunction ( fax...
Changed drum on workcentre 4118, and still says change drum
TURN ON MACHINE. PRESS MACHINE STATUS; PRESS ADMINISTRATIONS TOLS;PRESS ARROW HIGHT UNTIL APPEAR M ANUTENCE; PRESS OK; PRESS ARROW HIGHT UNTIL APPEAR "NEW DRUM". PRESS YES.
PRESS OK. THATS IT.
TURN OFF THE MACHINE; WAIT FOR 30 SECONDS; TURN ON.
Feb 12, 2013 | Xerox WorkCentre 4118 Network Kit...
Display says Scanner locked
Apr 26, 2010 | Xerox WorkCentre M20i All-In-One Laser...
SCANNER LOCKED IS ON THE DISPLAY SCREEN I HAVE CHECKED THE GREEN BUTTON UNDER THE PAPER TRAY AND THAT IS SET TO UNLOCK. WHEN I TRY TO PRINT THE DISPLAY SCREEN SAYS SCANNER ERROR AND THE SCANNER LOCKED
Hi, what you want to do is, first; (shutdown) your Scanner, next (shutdown) the computer. Disconnect the scanner, and unplug it from the outlet. Disconnect scanner cables from the computer; Note: do not change anything on the computer. Reconnect cables to the computer. Plug scanner back into the power outlet; turn on computer, turn scanner on. This may clear the (Freeze); but the (Error) might appear again. Thanks paul7of9
Jan 05, 2010 | Xerox Phaser 6110 Laser Printer
Xerox 6110 MFP scanner locked
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
75884d7.jpg Front of the Xerox 6110MFP howing paper output tray and control panel.
7020767.jpg Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
Feb 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Iam trying to scan a document on my flatbed xerox 4800 but it keeps saying please unlock your scanner then it gives me time to do it but i dont know where to unlock it
you might have two program trying to use the scanner at the same time & the scanner is confused.Find out what programs you are using.Hint...even printer programs may use scanner drivers. 2nd.you MUST use the EXACT scanner driver for your scanner. Windows will see the scanner "locked out"
Jan 06, 2009 | Xerox One Touch 2400 Flatbed Scanner
At the lcd screen you can read this message: "ESCANNER DESABILITADO"what should I do?
The scanner probably got accidently locked. Turn the machine off, unlock the scanner, then turn back on.
Instructions on how to unlock the scanner are found here:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=143,E=0000000001181477675,K=8219,Sxi=11,Case=obj(349)
Dec 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox One Touch 2400 - Problem please help
Shut the computer down.
This makes sure the message is cancelled
Unplug scanner.
move the lock to -unlock
plug scanner in
restart compute
tell us what happens
Aug 18, 2008 | Xerox One Touch 2400 Flatbed Scanner
Xerox WorkCentre  4118X All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
