Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Fabric softener dispenser
The fabric softener dispenser is built into the center column on my Whirlpool Ultimate Care II washer. (Bought in 2002.) I wanted to clean it, so I removed the dispenser and saw that inside the column was gunked up. I got that all cleaned out, but now I want to clean the INSIDE of the dispenser itself. How do I get the dispenser open? I've tried twisting and pulling the top off, but no luck. If it doesn't open, how do I clean the inside out? It looks like there's some build-up right around the bottom opening and I want to be sure it's not blocked.
  • 1 more comment
  • hawkeimen Dec 27, 2008
    Is the dispenser supposed to come apart? It looks like is should. Would running it through the dishwasher work?
  • mnitch Jan 19, 2009
    I'd like to know how to get the dispenser cup removed from the column. I have a top load Maytag
  • Kevin Apr 30, 2013
    I have a piece that the repairman gave us that is supposed to go in the back of the dispenser cabinet to stop the leak. It is a small round piece with a couple of openings and supposed to fit on the small tube in the back of the cabinet. It won't. What should I do?
  • 5,911 Answers
If you cannot get the dispenser cap opened, submerge and soak it in some hot water. Liquid fabric softener is a type of wax that, over a period of time, will harden and clog the dispenser (as you well know by now). In many cases you do not have to take it apart if you just use the hot water method. You may have to rinse and repeat several times. Try this and let me know if you have any luck. If you require further assistance, please post back with your complete model number, so I can see what type of dispenser cap we are talking about. I hope this helps you.
Posted on Aug 14, 2008
  • BAM BAM59 Jan 02, 2011
    you still don't explain how to get the cap off! how do I do that. I have repeatedly rinsed with boiling water only to see gunk still clinging to the sides... HELP!
I have the same issue. Model is Whirlpool LSQ9010LW0
Posted on Sep 02, 2008
My ultimate care II washer does not have a fabric softener dispenser, is this a manufacturers defect?
are u sure its not just the cap to place fabric softner is missing? possibly in the center of agitator
Sep 05, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Hello, the agitator seems to work (and turn) well at the bottom but it seems stuck at the top (hardly turns. What can I do? Thanks, Isa
If it has a fabric softener dispenser in the top, it is most likely a waxy buildup from the lanolin in the softener. Disassemble and clean.
Sep 11, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
It did not come with the manual. How do you use the Fabric Softener Dispense?
just put the softener in the disp. it will dispense in the machine automaticaly
Sep 02, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Cleaning Fabric Softener Dispenser
it does come apart it is stwited in from the bottom up . but you can soak it in some hot water and shake it it will come clean after a bit
Jun 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
How do i disassemble the fabric softener dispenser? already popped off of agitator
This softener cup doesn,t come apart.The easiest way to clean it is to throw it in the wash cycle with rags and hot water. Then from here on use less softner . Mix it 50/50 with water.
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Fabric softener dispenser not working
If the model number you have this listed under is correct, you should have the softener dispenser on the center post of the agitator. If this is the case, you need to remove it by popping it off the center post and take it apart. Soak it in some hot water to dissolve the softener residue and reassemble. Most dispenser related problems are attributed to softener that hardens and clogs up the dispenser. Liquid softener is essentially a wax and will do this over time. You will need to clean it from time to time.
Apr 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Softener getting all over top rim of washer
i tell people to dilute it with water so it is not as thick.
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frabric softener dispenser
try adding the reccomened amount then filling the rest of the way with water also just pull up on the dispencer cap to remove it and clean
Jul 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer leaves spots on clothing
It most likely is fabric softener. You need to clean dispenser with hot water, if this has one. In real cold water the softener won't disolve properly and will cause this to happen.
Oct 08, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
1,325 people viewed this question
Dan Webster
Dan Webster
Sal De
