Question about Vacuums
Wont start, is there a reset somewhere? - Vacuums
    Sergeant:
    Champion:
  • 226 Answers
Make and model needed. vacuums generally dont have reset switches. I woul try another outlet or your fuses, my vacuum trips the breaker all the time.
Posted on May 19, 2011
Bissell 687C Vacuum wont turn on
Try to check the circuit... as when there is an circuit fault it gains high amperage and hence fuse shut the current till it regain. It happens to save your device.. don't be doctor. Get it done by authorized person or somthing or it will cost your more then your device cost...
Mar 15, 2014 | Bissell Vacuums
Dyson dc04 we got it second hand 3 days ago and its fantastic butfor some reason now it wont switch on ive checked the fuse etc but its not switching on?
You will have to start with the power coming through the cord to the switch, make sure the switch is good. Then follow the power until it gets to the motor. Somewhere between the plug and the motor you will probably find your problem. There are many different things that it could be so it's really hard to determine the problem without seeing the vacuum.
Mar 05, 2014 | Vacuums
Power for riccar 1800
Start by checking the reset button on the back. It will shut the vacuum off if their is a clog or restriction somewhere.
Dec 14, 2013 | Riccar 8955 Upright Vacuum
My green light went out when i hit the wall now my vacuum wont pick up is there a reset button somewhere
green light off means the brushroll is not turning, reload the belt onto the pulley, if not sure how to do this then vid on utube
Aug 30, 2013 | Kirby G10D Vacuum
Fuller Brush FB90 Bagged Upright Vacuum not starting
Try pushing the reset button located at the bottom on the back of the machine. If the reset button has tripped it usually indicates a clog or restriction somewhere caused the motor to overheat.
May 23, 2012 | Fuller Brush FB90 Bagged Upright Vacuum
Wont turn on
Most common fault I find when repairing vacuum cleaners is that the cable is broken, however the motors do have a one shot thermal fuse on them, check the cable for continuity and breaks pay attention to where the cable goes into the vacuum body this is the most common point.
Jul 22, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Wont turn on - Plug is hot - is there a reset on the motor
IF THE PLUG IS HOT YOU NEED A NEW PLUG- ALSO MAKE SURE THE OUTLET YOU ARE USING IS OK
Jul 10, 2009 | Dyson DC07 Full Gear Bagless Upright...
Miele Solaris won't turn on after falling down 1 stair.
there is no reset on this model. look @ your miele info & it shows you where it would be. I just had to look for mine when it would'nt start. mine ended up being cord winder kink affecting motor.
good luck
linda
Mar 15, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Reset button for Eureka 431 bagless upright???Where is it?!
If the red light is one the says "check brushroll" then you have to take it apart to find out what the problem is. It might be that the roll has too much stuff rapped around it so you have to take it out and clean. It could also be the rubber belt is not properly in place. Once you take the bottom off the belt should go on the far right side. Those are the only things i can think of. I have had mine for 3 years and have never seen a reset switch. Usually when my light comes on it is because there is a lot of hair rapped around my brush roll.
Jan 17, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
