Question about Fuji FinePix Z1 Digital Camera
FORCED FLASH NOT WORKING - Fuji FinePix Z1 Digital Camera
  • iika Nov 09, 2008
    forced flash is not working when i've reset and reformat everything i my camera . (Fuji FinePix A820 Digital Camera)
  • 679 Answers
Hi,I know some of the common things for the digital camera. I want you to try these.
-------->If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
-------->Set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness.
IMPORTANT: If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
* When shooting MPEG movies
* When set to the Twilight mode
* If an external flash is connected
The information above should resolve your issue. However, if the issue still persists, you can try resetting the camera to factory specifications.
Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings.
Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to reset the default settings. Otherwise, continue with the manual reset procedure below.
1. Turn off the camera.
2. Ensure the camera is not connected to an AC power adapter.
3. Remove the battery from the camera for 15 seconds.
4. Reinsert the battery.
5. Turn on the camera.
If all the above fails you, then i doubt that Impact damage would have caused the flash not to work.
But i know you are not going to like this solution. No other way , you have to contact Nikon service centre for repair.
i hope this helps to fix your problem.
Thanx for using fixya.
Posted on Jan 03, 2009
Flash not working
Can be for severe; reasons.
1. There is enough light.
2. You can force the flash, with the mode switch to Flash forced on, Slow synchro and Flash forced off. Try flash forced on.
3. The battery is not fully charged. When there is not enough power in the battery, the flash can't be charged enough to fire. But if the camera tries to charge the flash, a symbol with a lightening arrow and a dot is displayed. So if you see these symbols, could be you need better batteries. Try charging the battery.
4. the flash is really defect. Could happen too, but first check if everything from 1 to 3 is as it should be. only than you have to visit the repair shop or Sony if it is still in warranty.
Nov 30, 2013 | Sony Cybershot DSC-S950 Digital Camera
My sony cyber-shot DSC-H10 flash stopped working. The flash pops up like it is going to work, but does not flash. I can take pictures but with noflash. Can you help me?
You flash is in ' Flash forced OFF ' position.Press on the flash control button repeatedly until one of the four modes are selected.
1.Flash Auto - Flashes when there is insufficient light or backlight ( Default Setting )
2.Flash forced on
3.Slow synchro - The shutter speed is slow in a dark place to clearly shoot the background that is out of flash light.
4.Flash forced off - ( Your current mode ).The flash automatically pops up and strobes when using the flash.Close the flash by hand after use.
Jun 03, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
The flash will not come on
I'm sorry that the flash on the Camera is not working. If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
- When shooting MPEG movies
- When shooting in the Twilight or Handheld Twilight mode
- If shooting with the Burst or Multi Burst mode
- Shooting with Sweep Panorama
- Shooting with the Fireworks or High Sensitivity mode.
- If an external flash is connected
Please make sure that the Camera is not in any of the above modes.
Feb 21, 2011 | Vivitar ViviCam 5022 Digital Camera
Flash does not work no apperant cause
- When shooting MPEG movies - When shooting in the Twilight or Handheld Twilight mode - If shooting with the Burst or Multi Burst mode - Shooting with Sweep Panorama - Shooting with the Fireworks or High Sensitivity mode. - If an external flash is connected
Jan 22, 2011 | Kodak EasyShare Z612 Digital Camera
Hi. I have problem with flash, dont working. Thanks.
  • When shooting MPEG movies
  • When shooting in the Twilight or Handheld Twilight mode
  • If shooting with the Burst or Multi Burst mode
  • Shooting with Sweep Panorama
  • Shooting with the Fireworks or High Sensitivity mode.
  • If an external flash is connected
Jan 02, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
Cannot get the flash to work.
If the built-in flash does not function, then the camera flash may be turned off or it is set to Auto and will only flash when taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting situation, press the flash button on the camera (or touch-screen LCD, if equipped) until the forced flash icon appears on the LCD screen. The flash button has a lightning bolt symbol on it
Jan 01, 2011 | GE X5 Digital Camera
Flash is not working
Dec 31, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Can't turn on my flash on my sony cyber shot dsc w200. when i try to change the flash it says that my flash settings cannot be changed. what do i do?
Let's try some troubleshooting steps to resolve the issue with the Flash in the Camera. The Flash in the Camera will work only with the settings which is selected.
1. Make sure that the Camera flash is set to Forced Flash ON. (Press the right arrow control button of the Camera continuously to select the Forced Flash to ON.
2. The Flash in the Camera cannot be used when the REC MODE of the Camera is set to BURST or EXPOSURE BRACKET. (To select the REC MODE, select Menu button in Camera Shooting Mode. Set the REC MODE to NORMAL).
3. Flash will not work with modes like ISO(High Sensitivity Mode), Twilight Mode, ISO+(Extra High Sensitivity Mode), Fireworks Mode.
4. Try to set the Flash Mode to Flash Forced ON when the Mode dial is set to M, Landscape mode, Beach Mode, and Scene Mode.
This will resolve the issue with the Flash in the Camera.
Thanks for using FixYa
Dec 04, 2010 | Cameras
My minolta 5600hs flash does not flash all the time.
Is your Flash on Forced Mode or auto mode? If it's on Auto mode, the camera decide that flash work or not! but if it's on forced mode, I think there is a hardware problem... I hope this helps
Nov 02, 2008 | Cameras
Flash not working
"Forced on" means the flash is forced. Try "Forced OFF". Note that there are several options and scenes when the flash is enabled by default.
Oct 23, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Fuji FinePix Z1 Digital Camera Logo
248 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
