Question about Coleman Camping, Backpacking & Hiking
I have a coleman 228e gas latern that seems to be loosing pressure and the light dims quickly. i can't find schematics to rebuild it
    Problem Solver:
  • 5 Answers
First thing,maybee you have a smal hole in the burning pocket (if so change the pockets). if not, you migth loose pressure because the o rings of the pump are dryed out. you need to open the pump,lubricate it and replace it. to open the pump, there is a little metal handle to this pump, slowly open it by pulling one side out and the other side of it after. then you should have to unscrew the entire pump out of the gas canister, lubricate everything that is made out of rubber whit vaseline and rescrew it back in the same order you've found it. if this does'nt work, you need to clean the entire conduct system of your lantern, you can do that whit naphta, just soak it in for 2 or 3 hour (do that outside for safety, really) and let it dry, then try again, if its not working, you migth have to clean it manually
Posted on May 19, 2011
I have a coleman 5317 RC series lantern that wont go into the dim mode what can I do
Hello. I've just looked at several Coleman lamps, some have krypton bulbs (mainly battery powered), some spiral fluorescent bulbs (mainly mains powered/charged). If this one is yours http://www.coleman.com/Parts/100/parts-lanterns/5317-702/remote-control-pack-away-family-size-lantern# then it appears yours has a spiral fluorescent bulb. Gas discharge bulbs commonly are fired up by an initial high voltage pulse then followed by a continuous ac medium voltage (say 80 volts or so) to give a FIXED LIGHT OUTPUT.
THIS DOES NOT ALLOW CONTROLLED DIMMING. Dimming can usually only be done on an INCANDESCENT TYPE bulb eg an older type tungsten filament bulb. These are however much less efficient.
So in summary, if you do have a fluorescent bulb, I don't know why your remote indicates you can dim it. You could try switching the bulb for an incandescent type, but this should only be attempted by qualified persons. Check over the user manual again. Good Luck.
Jun 17, 2014 | Coleman 5317-700 lantern - 8d square...
Replacing Batteries in a Coleman Latern 5359 SERIES
I believe that the battery replacement is at the bottom. There is a black knob, turn it to the left to open. Uses 8 D Alkaline batteries only.
Thank you for contacting Fixya. Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Feb 16, 2014 | 2014 Expedition Lt Cts16bh
Honda 8hp motor only starts with quick-start fluid
if you have gas to carb rebuild carb or relace
Jul 07, 2012 | Honda 8 HP Engine
My air compressor doesn't seem to want to shut off. how do i know i have it set correct
turn pressure regulator all the way to the left, therefore requiring the least amount of air pressure(psi) in the tank so it will shut off at its minimum. If it still continues to run, its probably a bad regulator pressure switch and your going to need a new one. Good Luck
Jun 07, 2012 | Coleman Air Tools & Compressors
My 1994 nissan altima dash lights dim and paking lights dim when i press on the brake pedal. doesn't matter if the car is off or on. loosing my mind whats left of it. please help.
Gday ate, geoff here, well it would seem that the brake lights are trying to earth through the park light system as they are in the same socket in the rear, check the earths from the light pack at the rear, and the then go from there tracing the earth circut even to the point of cleaning rust, mould/moss from them,geoff.
Feb 11, 2012 | Nissan Altima Cars & Trucks
I have a full bottle of gas but there doesn't seem to be any pressure.All the burners light but i don't get temps over 180
hi barty1950...
Check your burners to see that they are not plugged up.
I suspect that the regulator is the problem...take a hammer and lightly tap on the top and the bottom of the regulator as the flame is burning...it may loosen uop the needle valve and allow it to get more gas, if this did not work then replace your regulator as it is faulty.
Please take time to rate me
Sep 05, 2011 | Coleman Gas Grill Stove
Coleman Pressure Washer gets no pressure even when running.
It sounds like your pressure regulator or back flow preventer is stuck closed either by corrosion or trash . Try tapping it and see it will open. If this does not work you can try rebuilding or replacing it.
Nov 18, 2009 | Coleman Powermate Powermate 5000W...
Coleman 424 Dual Fuel -- High, yellow flame
Are you pumping the tank up all the way? I have the same problem if I have too little pressure in the tank. The instructions say pump 35 times. Try pumping 50 or 60 times- that seems to help.
Also, you can't light this one like an old 425. My old stove you could turn the gas on and then take a match neat the burner. For this stove, hold the match near the burner with the gas off and quickly turn it on.
These are two things that seemed to help me with the same problem.
Jul 11, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Camping, Backpacking & Hiking Logo
186 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
weirdtop
oldhess
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
