Question about Homelite ZR10926 16" Chain Saw
Won't stay running, we changed the spark plug and changed the gas. will run for a few moments, if you turn the choke off or press accelerator it dies
    Sergeant:
  • 281 Answers
HI,
Use a stiff piece of wire and form a hook on one end and use it to fish the filter that is on the end of a tube in the gas tank.Buy a new one and you should be back in business.Hope this helps and thank you for choosing FixYa.com.
Posted on May 19, 2011
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Weed eater wont stay running
Here are a few things to check, that are solutions for your symptoms. Check, then clean or replace:
  • Fuel Filter - located in the fuel tank
  • Spark Arrestor - at muffler
  • Spark Plug
  • Carburetor - may need rebuild kit?
Look here...
And...
Sep 02, 2012 | Garden
My craftsman p2 weed eater won't stay running
remove the muffler and run it if ok open the muffler and cllean the screen inside a resticted exhaust will not allow exhaust flow then the engine can't rev up
Aug 06, 2012 | Craftsman Garden
21A-121R900 Won't stay running
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ~~
Feb 14, 2012 | Yard Machines Garden
91 Lumina won't stay running; see lots of same question for same car but no problem solvers....Please help.
On electronic fuel injection pumping an pumping an pumping the gas pedal does nothing without the engine running ! Pushing the gas pedal to the floor will cause the PCM - engine computer to go into clear flood mode .
You have some very interesting ideas here , but not really how it works or is !
The vehicle will go into closed loop fuel control when the engine coolant temp reaches a definded temp an the O2 sensor get hot.
She would run for a couple minutes and die which is open loop when running, closed loop is when the sensors kick and it would die. Pulled spark plugs, they were black meaning no spark. Can only be 2
Black spark plugs indecate a rich condition , over fueled , wet spark plugs indecate no spark .
Mar 07, 2017 | 1991 Chevrolet Lumina
Have a 89 jeep Comanche starts but won't stay
If is fuel injected try checking the fuel regulator and if is has a carburetor possible bad choke or needle seat / worse case jump timing
Dec 19, 2011 | 2006 AMC Comanche
I have a 1985 Yamaha maxim that hasn't been ran
Spray starter into the carb intake with no choke, if she runs for a few seconds then you know its fuel starvation
clean jets & airways & blow through with compressed air
Nov 20, 2011 | 1985 Yamaha XJ 700 S Maxim
Sears GT 5000 garden tractor with Kohler 26 HP Courage engine. It won't start when it gets hot. It turns over, and sometimes just barely runs for a few seconds, but then dies. Choking it a little...
check spark plug sounds it s heating up to much make sure of oil level and if it has been sitting a while dump the gas in it and fill it with new and buy some sea foam and add a little to the gas
Jul 19, 2017 | Craftsman GT 5000 26 HP54" Garden Tractor...
Homelite ZR10926 16" Chain Saw Logo
205 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
