Question about GE Energy Star PDS20MCR Bottom Freezer Refrigerator
I have a GE Energy Star Refrigerator with bottom freezer and external ice dispenser on the door. There is an LCD control panel with 7 buttons. The icemaker on/off switch goes on and off randomly and chimes. The lock buttom keeps going on and off also. We can't stop it.
  • 979 Answers
SOURCE: GE refrigerator wiring diagram
Icemaker must be at 28 degrees to make ice. The harness supplying the power should have 120 volts there at all times, and the icemaker itself is the device that switches the power off and on once all requirements are met. Your diagram for the fridge is on the rear service panel, or in a packet on the insisde rear..accordianman
Posted on Apr 03, 2008
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
peyton32034
  • 410 Answers
SOURCE: Replacing icemaker in GE GSH25JSTE side by side refrigerator.
generally its very easy. for your model it looks like the icemaker goes across the rear of the freezer section. if you will look on the left hand wall on the icemaker you will see a philips head screw remove this screw and pull the icemaker towards you and it will come out then unplug the wiring harness (this is probably the hardest part) there are 2 clips that keep the harness connected securley and you sometimes have to use a small blade screw driver to release them. onec icemaker is removed you have to remove the fill cup and the end stop off of the icemaker and reinstall on the new icemaker. one done just reinstall and turn it on. youre done!! BTW the new icemaker mostlikely will not have the green light the old one did so dont think youve got the wrong icemaker.. let me know if you need any further help Thanks Peyton
Posted on Mar 16, 2009
bobicehouse
  • 1524 Answers
SOURCE: I have a side by side refrigerator/freezer with
Check the defrost, if the coils have frost no cold air will circulate. Freezer must be 12 degrees F. for ice maker to work.
Posted on May 01, 2009
adnanbhatti
  • 1188 Answers
SOURCE: GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Posted on Aug 27, 2009
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore French door refrigerator will not start up, control panel will not light up, wont come on
Have you tested the outlet? The power cord itself could have a broken or burned wire. Even if boards are bad, there should be lights.
Oct 03, 2014 | Kenmore 2537031321 Stainless Steel 26.7 Cu...
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Nov 26, 2013 | Star Manufacturing GE Profile PFSS5NJX...
Re ice dispenser. The flap is not opening to release the ice cubes. I can put my finger up and open the flap and ice drops. Is there a spring or something. Pls advise.
HI there is a solenoid behind the the little control panel there that is bad or rusted, The part is $30-50.00, You will need to remove the control panel on the freezer door to change it.
Sean
Mar 28, 2011 | GE Profile¿ Arctica® Energy...
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
GE Energy Star PDS20MCR Bottom Freezer Refrigerator Logo
14 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
