Question about Fellowes DM17C Shredder
What is the wattage of this powershredder DM12c. We only have 220voltage power supply so I need a transformer for it. Pleas give me specs so I can get the right kind of transformer. Thanks
We just got a Wansa TV but it has a 220V plug. Will tv convert itself to 120 if we use a regular power plug
If there is no indication in the user manual or any spec listing it may not. Most of the time the power supplies used are for the full range of voltages available. It will not damage it to try. Get a power adapter instead of chopping the wire and putting on a new plug. If this does not work, buy a step up transformer 120VAC to 220VAC. Make sure the transformer is rated to at least 30% or greater for the wattage specs. If not the transformer can run too hot.
Apr 02, 2017 | Televison & Video
What is the rated wattage for the mastercraft drill
the wattage is on the plate attached to the drill and will still be the same as before you attach a step down transformer to get to the correct voltage
get a step down transformer that has a large wattage rating for 120 volts ( say 1200 watts ) as most 1/2 drills are 750 -1000 watts )
the wattage is for the rated current through the transformer and if the drill is of low wattage , it just gives the transformer a greater degree of serviceability in the duty cycle
Nov 16, 2015 | Audio Players & Recorders
Will Freezer run overseas on a transformer?
Step Down Voltage Converters You can use this link to find a converter that should work. There are several other sites as well. You need to get a converter with enough wattage capacity to operate the freezer. I recommend you get one with a somewhat higher wattage rating than the freezer's wattage rating. For instance if the freezer is rated at 700 watts, I would get at least a 1000 watt converter. Good Luck !!! and Bon Voyage !
Mar 30, 2014 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Does a ATX power transformer makes the difference of watts of a power supply unit of a computer? Exactly I am planning to improve performance of my pc's ATX power supply unit. Trying to attach another...
NO NO NO... PC power supplies are switching supply's. The transformers use high voltage to drive other components. Increasing the power out of the supply will require you to upgrade the power supply to a higher wattage output.
Oct 23, 2013 | Microsoft Computers & Internet
How to check if my power supply is already not ''at the limit''?
1 or 2 extra hdds and ram does not require much extra power and your coolmaster should do the job. But if you intend to use a newer graphic card you should check the requirenments for wattage at your new card manufacturer product specification webpage. I am pretty sure that almost all newer graphic cards require at least 500 watt to run without problem. My advise is to buy at least a 550 watt psu although i don't know what is your hardware. Try to post your hardware specs and calculate for each component (cpu wattage+graphics wattage +etc) your power supply need to be over 50 wattage. Hope that helped!
Mar 22, 2010 | Cooler Master (RS-430-PMSR/P) (RS430PMSRP)...
Hello i have a Sony Vaio PCW-W2 that i brought to canada from uk. how do i switch voltage to 110?
u can find voltage converter connectors......try using that....u can ask for travel adapters....hope u find them
Mar 08, 2010 | Sony Computers & Internet
What is the wattage onroomba 560
The power supply isn't a transformer, its a switching power supply. The power supply is different for different locations, but you should not plug a 110V only power supply into a 220v source or vice-versa. You should contact iRobot if you wish to obtain the correct power supply for another location or to determine if they have an autosensing model that can sense and adapt to either 110v or 220v. You can also use a step down transformer to convert from 220v to 110v. The charger should be using 20W or less, but it will be pulling the current in narrow surges from the peaks of the voltage wave (aka a high 3rd harmomic current) and you will need to use a 40W or larger transformer to avoid unexpectedly overheating the transformer core.
Aug 25, 2009 | iRobot Roomba 560 Robotic Vacuum
Plug it in and there is no power
Power supply will need to be changed
Jul 09, 2009 | Office Equipment & Supplies
NEED POWER SUPPLY FOR ELITEGHROUP L7VMM2 MOTHERBOARD
There is no specific power suppl that you need. The only differce is the wattage 300, 350 , 500 etc. Your motherboard will work with all types not to worry. The only reason you get a higher wattage power supply is if you plug in a lot of stuff. say you have 3 HDD and 2 CDROMS then you would need the 500 Watt power supply.
Jan 05, 2009 | E-Machines (ATX-300GT) (ATX30012) 300-Watt...
Designing a linear regulated power supply
what you are doing is over **** for 300 mA, now if you will pulling some real wattage then you would need linear regulation.
just use a 10.00 ac adapter . or a zener diode .
the calculations in real time analysis is complex GE has the formula online . but a spike at 300ma will be assorbed by the transformer easilly. if you are protecting delicate circuit then a fuse will not work quickly enough , fry and blow is all they do.
a crowbar circuit is what most designers use nowdays.fast and efficient.
There are plenty of IC regulators on the market that will give these specs but I think your are over thinking your needs unless you have an exact spec for medical research.
Feb 13, 2008 | Computers & Internet
Fellowes DM17C Shredder Logo
42 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
