Question about iLO 3200 32 in. LCD Television
What is the RS232 port for? - iLO 3200 32 in. LCD Television
  • 10,515 Answers
RS232 is simply a serial data transmission / communication port. It has never had any signals involved in video. It has been used for data exchange between computers and for connecting peripheral devices like modems and printers to computers. It also has been used to connect a remote keyboard / screen, such as a "dumb terminal", to a computer as an additional I/O device.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 19, 2011
Why cant I get my computer to accept it
you might have to set up the serial port settings with speed (baud rate) number of stop bits, even or odd parity. suggest google how to set up serial port on whatever operating system you have. does the p.c even have an rs232 port may need a usb to rs232 adapter device.
Apr 20, 2015 | Honeywell MS5145 Eclipse with Codegate...
RS422 or RS232
As far as I know ALL Panasonic Toughbook
(which have a bult-in serial port)
the serial ports (DB9) are RS232.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jul 06, 2014 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
Rs232c port hitachi use as input
the RS232 port is not for viewing video. You want to use the VGA port. RS232 is a way for you to control your TV from a remote location via a computer.
Jun 06, 2012 | Hitachi Televison & Video
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
I need a laptop with RS232 port. What model should I get?
RS232 is now not being fitted to laptops This has become old technology. If you have devices that require connecting via an RS232 There are USB cables that emulate the connections of an RS232 that can be set to a com port to fool the device that it has the rightr connection. Look on Ebay there are quite a few at various prices, most from Hong Kong. I have bought aqnd used them to connect my radio scanners and Scancat software to program Amateur radios quite succesfully, as well as to run my old HP A3 scanner
Please rate my help++++Thanks for using FIXYA
Jun 20, 2010 | Toshiba Satellite M35X-S149 Notebook
CANT CONNECT TO THE RS232 CONSOLE PORT. WHAT IS
Just click on default settings in hyperterminal?? if u had not set any in ur router??
Mar 24, 2010 | Computers & Internet
Hi I'm Kandy When I try and load a card stitch I keep getting the following error message: PCDWIN22 Caused a General Protection Fault in Module PCD_WIN.EXE at 0005:38F6. The software then shuts down. I...
I replaced my USB/Serial RS232 port adapter with a genuine RS232 serial port on the PC. THis solved the problem. Further reasearch on the net indicated that USB to RS232 - serial port converters do often have problems. I previously had not had a problem running on Windows XP and this is what alerted me to the possibility of the USB/RS232 port adapter as a possible reason for the "new" problem.
Oct 24, 2009 | PfaFF Creative 7570
I have an rs232 cable attached to kyrptview cable box via a usb adaptor.. Cant get my pc to see the box.. its a dell pentium 4 on windows xp.. any help pls
I assume the RS232 cable is going to a serial port? I think you should add a USB card to your system. The old async chips used to support RS232 ports are not fast enough to take USB info.
Mar 28, 2009 | Computers & Internet
Need a motherboard with DB25 male RS232 serial port
to get ur motherboard just go to the website of that ,,u can find it bt surfing
Dec 06, 2008 | Intel Server Board S5000PSL - Motherboard...
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
iLO 3200 32 in. LCD Television Logo
120 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
