Question about Dishwashers
We have a jenn-air dishwasher, model du 451. I am pretty sure its over 20 years old! Is there a cold & hot water line into the machine or just cold. The home warranty company is blamming the house water temp as problem for not heating up enough to sanitize. I appreciate your expertise as I think I am getting taken advantage of.
  • Dishwashers Master
  • 43,501 Answers
You should be getting only hot water to that machine... if you are only getting cold then it was hooked up wrong...
heatman101
Posted on May 19, 2011
What does the inlet hose end look like?
Let's make sure we're in the right category. Is this a clothes washing machine or a dishwasher? If a clothes washing machine, there should be a hose inlet for the hot water and another for the cold water. The fittings will be the same, but one should have a C or "Cold" stamped or labeled next to it and the Hot an H or "Hot" next to it. Unless the machine is really old or maybe not from this country, the hose fittings should be standard.
If you're referring to a dishwasher, then there will only be one inlet for a hot water line. The fitting is probably a 3/8" MIP and will require a 3/8" MIP line. There a special dishwasher installation kits that come with the hose and common fittings which might be your best bet.
Nov 21, 2016 | Washing Machines
My washing machine is a Whirlpool Model LA5800XS. It came with our condo unit. Its probably about 20 years old and gets only about three month's use each year. Mechanically it runs fine but the cold...
hmmm..that's really odd...is the pressure from the cold water the same as the hot? you can test this first, then we can look at the cold /hot mix system
Mar 10, 2008 | Washing Machines
My LG dishwasher counter doesn't count down
Since you didn't give the model number, I looked at a general user manual for an LG dishwasher. It suggested that if the water is cold, it would take longer to wash the dishes. That suggests to me that a cold water temperature might prevent the timer from starting till the desired temp is reached. Could that be the problem? Could it be connected to a cold water supply rather than hot? Is the hot water set too low?
Mar 10, 2014 | LG Dishwashers
Dishwasher installed correctly? One year old jenn air dishwasher leaves brown **** and water film on plastic components inside, rinse agent used regularly
you must contact to jENN-aIR FOR get customer support, about the material recommend. About some agent used, or if some bad design material from factory.
God bless you
May 09, 2012 | Jenn-Air Dishwashers
Does the water supply hook up to hot or cold input line?
Cold water in ... the machine will heat it if necessary ...
Nov 16, 2010 | Jenn-Air 24 in. JDB2150AWP Built-in...
When dishwasher drains the water not all the water is drained. Some stays standing at the bottom and starts getting an odor after awhile. This is a replacement dishwasher in a 35 year old house. How...
It's most likely that the filters in your dishwasher are blocked, the best way to clean them is to remove the filters from the bottom of the dishwasher, place them in the racks and run through the hottest wash cycle. It also helps to have a dishwasher cleaner inside the machine at the same time, these are available from most places that sell the dishwasher powder.
May 15, 2017 | Whirlpool DU1055XTS Built-in Dishwasher
I have a jenn-air dishwasher, at least 11 years old, that suddenly doesnt drain. any do it yourself suggestions to try?
make sure the drain line is clear all the way through. also check the drain itself at the bottom of the wash area. They can get clogged there if large amounts of food or other objects get stuck on the grate. If it is not a clog issue, it is probably the pump. After 11 years I would not be surprised to see a pump let go. A pump replacement may or may not be worth doing. With the machines I work with it is more cost effective to replace the entire machine. I hope that isn't the case with you.
Dec 16, 2009 | Jenn-Air Dishwashers
Food residue on all dishes
The filter systems on the Maytag line of dishwashers which includes Jenn Air is very fine. In most causes the pump needs to be torn down and washed in a sink and a shop vac is also a great tool I use to clean the rest of the pump out that will actually stay in the dishwasher. The spray arms also need to be cleaned in the sink. Check your drain line under your sink as well and make sure that the drain line coming from the dishwasher has a high arch or bend that is higher than the base of the sink. This will prevent sink water from backing up in the dishwasher which can be nasty. Also make sure to run your hot water to the sink before starting a cycle to assure hot fills and the water temp. is best if set at 130 degrees on your water heater instead of 120 or 125 degrees. I hope this is helpful. This kind of problem can be agrivating to solve at times. Scott (North Caolina)
Apr 20, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
Owen Barnes
