Question about Transcend StoreJet 320 GB USB 20 Hard Drive
When I connect my transcend 320gb external drive to my mac, the drive light just flashes, and doesn't connect to the mac for backups
  • 63 Answers
This could be a couple things since it's an external HDD. Here's what I would try:
  1. Try another port
  2. Try another cable
  3. Remove the drive from the external case and plug it in to the MAC directly if possible. If not possible, get another external case for it (they're not expensive these days)
  4. If you still do not get the drive to come up after that, then you might want to give SpinRite a try. http://www.grc.com - it costs $89, but it is a tool everyone should have around in my opinion.
    Keep in mind that new drives are cheap. a 2 TB hdd will run you about as much as SpinRite. But getting a new drive will NOT recover your data of course. So if that data is important to you, see if you can recover it with SpinRite, the team over at GRC is awesome when it comes to support as well.
Posted on May 19, 2011
I want to format my transcend from mac how can i do it
Transcend produces different kinds of memory modules, including Random Access Memory, or RAM, chips for computer systems, USB flash drives and a variety of flash memory card formats, such as SD.
Transcend's flash memory devices are usually preformatted with either FAT32 or NTFS. Macintosh systems primarily use the HFS+ file system format.
You can format a Transcend flash memory card to the FAT format using the Disk Utility program on a Macintosh.
Insert the Transcend flash card into a card reader connected to the Mac.
Some Macintosh computers have SD card readers built in.
Open the Disk Utility program in the Utilities folder.
Click the flash card in the left column of the window.
Click the "Erase" tab.
Click "MS-DOS (FAT)" in the "Format" drop-down list.
Enter a name for the flash card in the "Name" box.
Click "Erase" to format the flash memory card to FAT.
Hope this helps
Oct 28, 2012 | Transcend ts250gsj25m storejet 25 mobile...
I just purchased a StoreJet 2M 320 GB drive. I would like to format it for use with my iMac. The MAC software doesn't seem to have a solution. How do I format the drive?
When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it using a computer with Windows OS. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy. You need to format the flash or external drive. Format thedrive as primary drive and in FAT32. (FAT32 will allow data to be exchangedbetween MACs and PCs also between XP/Vista and earlier versions of Windows).
Jul 06, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
My mac is reading my transcend storejet 25 mobile 320gb, but i cant copy files from my mac unto it
Hello Kinoshia,
It seems that Transcend external hard drive have different file system. This is because the Mac machine is not able to transfer the files on to external hard drive. Please format the Transcend external hard drive from Mac machine and then hard drive is ready to accept the data from Mac machine. The drive either has to be formatted for Mac( HFS & HFS+) or FAT32 partitions. If you want to use
Transcend external hard drive for both Windows and Macs than format the drive to be FAT32.
Jun 05, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My Transcend StoreJet 500GB harddisk is not being detected on my Mac. The blue light keeps flashing.
If you are using the USB "Y" cable that has two male ends on one side then ditch it and try a regular usb cable. Regular being a cable that is USB to USB mini, one that as short as possible e.g. 36 inches or less. This solution is what solved my problem, so simple :)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/chris_51d7c1b240c21e38
May 30, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Changed hard drive (Mac) How to restore data from SimpleTech
If you are asking how to restore a Time Machine backup, you will need to connect and turn on your drive, then open Time Machine, navigate to the drive, highlite the backup and click on the restore button. It should then restore the files from your backup.
Feb 24, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
One day i connected my Transcend storejet with Macbook laptop of my friend and when he clicked the drive,computer started to make backup.He stopped the backup process in between.After that when i connected...
This is because of the file system...Mac uses a different kind of file system, while windows uses a different one...
You need to format the hdd before using in windows machine...
because your HDD file system would have altered by MAC...
Now format the HDD from device manager and you will be able to see the HDD under windows explorer...
Feb 07, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
My borrowed transcend storejet 320GB would not open to my DELL INSPIRON 1440. the light indicator is not steady.
the usb ports on your laptop may have insufficient power to operate the drive, you could try a double usb cable, it has a mini usb at one end and two normal usb at the other, so it shares the power from two ports.
Jan 18, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Transcend StoreJet 320 GB USB 20 Hard Drive Logo
359 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
