Question about Worx GT (10") 18Volt Cordless LithiumIon Grass Trimmer WG1515
Works gt trimmer keeps stalling - Worx GT (10") 18Volt Cordless LithiumIon Grass Trimmer WG1515
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Excaliber ght180 cuts out
Rebuild carburetor or find part number for carburetor and go online some carbs. Are cheaper to buy than rebuild.
Sep 13, 2017 | Garden
My trimmer does't work longer then 20 minutes. I can only get part of my lawn done. it takes 3 days to get it done with my trimmer.
I hate to have to break the news to you, but it probably never will. The batteries sold with the Worx trimmers are very cheap. I recommend either buying a few extra batteries and keeping them all charged so you can finish the job or buying a gas or plug in trimmer.
I had one of these last year and there is just no way you are going to get any more out of it. Sorry.
Jun 02, 2011 | Worx GT (10") 18Volt Cordless LithiumIon...
The trimmer starts but will not keep running, I replaced fuel lines and filters and put a rebuild kit in the carb. Same problem, starts fine but will not keep running
Its a longshot but I had a problem with my hedge trimmer, it kept cutting out when idling.
It turned out that a clutch spring was broken so the clutch shoes had nothing to restrain them and would fly out and make contact with the clutch drum and stall the machine.
Air locks in the fuel lines will also cause this symptom. These can be caused by running the machine with low fuel level in the tank and cutting upside down or at a sharp angle.
Mar 01, 2011 | Echo Gas 20 In Bar Double Reciprocating...
I have a 128cd. The weedeater starts good but keeps stalling when switched to the full run position.
possibly a fuel starvation issue. check carb settings and possibly clean and replace diaphragms if needed.
Jan 25, 2011 | Husqvarna 28cc Gas Line Trimmer
Trimmer starts, but stall's out, and is sluggish
Get a can of starter fluid and an assistant. Start it up and spray some starter fluid into the air intake to make it run long enough to clear up the sluggishness. J.
Aug 02, 2010 | Homelite Mighty Lite Lawn Trimmer
Ryobi lawn trimmer keeps stalling out. I have
If it is a relatively new unit it should have the carburetor adjusted after the first few hours of use. If it stalls upon accelleration the low speed adjustment on the carb needs to be opened a little bit. If it runs a few minutes and then stalls it could be the high speed jet needs to be opened or the fuel filter is clogged.
Sep 16, 2009 | Ryobi Garden
Craftsman 32cc Trimmer Runs with choke at idle, then stalls
Sounds like somewhere you have a air leak. Most likely it's somewhere near the carburetor intake or maybe the carb itself. Could be a line from the primer if it has one and i do believe it should that could be leaking or loose. Good luck.
Aug 02, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Jul 05, 2009 | Garden
Worx GT (10") 18Volt Cordless LithiumIon Grass Trimmer  WG1515 Logo
43 people viewed this question
Top Worx Garden Experts
Tim Whalen
Wayne McNeil
john milligan
Are you a Worx Garden Expert? Answer questions, earn points and help others
